[Plugin][$] RoundCorner - v3.3a - 18 Dec 18
@boilingsnow said:
I tested it just now, it seems this ruby is still not very stable?
It couses frequently sketchup errors and the program quits automatically everytime. Sometimes even when I was just do simple round corner on two sides, not to mention other more complicated objects. Perhaps that's only my problem due to my PC or some other personal settings? I don't know.But fredo I think you can make it better.
It seems you are one of the users who get a bugsplat with SU7 (even with simple geometry).
Would you mind to refer to this link http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a&start=15#p171844, use the modified file and report the txt.I am unable to reproduce the bugsplat in my environments (actually I never got a splat when writing and testing teh plugin), so I need users getting it to give me some hints on where it could come from.
Thank you for you reply.
hier is the first error report I got.[0.000000 ms] : Sat Jul 11 00:28:24 2009 - RUBY_PLATFORM = i386-mswin32
[0.000000 ms] : Preparing geometry
[0.000000 ms] : Compute corners 24
[0.030000 ms] : Compute edge roundings 36
[0.040000 ms] : Compute triangulated 0
[0.040000 ms] : End Preparing geometry
[0.040000 ms] : Launching the processing of geometry Nbsteps = 277
[0.040000 ms] : Scheduler processing: Step = 0 ipos = 0
[0.040000 ms] : Processing chunk: Init Step = 0 ipos = 0
[0.711000 ms] : Processing chunk: Terminate Step = 0 ipos = 0
[0.711000 ms] : Processing chunk: Init Step = 1 ipos = 0
[0.731000 ms] : Processing chunk: Terminate Step = 1 ipos = 0
[0.731000 ms] : Processing chunk: Init Step = 2 ipos = 0 grptempo = #<Sketchup::Group:0x11751360>
[0.901000 ms] : Processing chunk: Terminate Step = 2 ipos = 0
[0.901000 ms] : Processing chunk: Init Step = 3 ipos = 0 grptempo = #<Sketchup::Group:0x11751360>
[0.901000 ms] : Processing chunk: Terminate Step = 3 ipos = 0
[0.901000 ms] : Processing chunk: Init Step = 4 ipos = 0 grptempo = #<Sketchup::Group:0x11751360> -
Fantastic Fredo....very smart ....Thanks very much.
Works great, Thank you VERY much.
As always, fantastic job Fredo. SU woudln't be what it is without all these fantastic community-made plugins.
Just amazing!!!!!!!
Thank you very, very much, Fredo!!!!!
Jörg -
Has anyone got this to work on a Mac?
I cannot get the plugin to show.
I have tried installing to the following locations:
Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
User/Library/Application Support/Google SketchUp 7/SketchUp/plugins -
Splats as before, hourglass appears very briefly before splat-screen.
Here's latest report...FredoTraceRoundCorner[TIG-20090711].txt -
With which words I could thank for your work, Fredo6? Simply fantastic.
And with me again, in SU 7 bug splat, SU 6, works fine.
Thanks again.
WOW! This is incredible!
Great Work!
Thank You very very much!!!!the whole skp dev team (if there is one existing - don't know, after seeing v7) should quit developing new functions and concentrate on x64 and highpoly support ...or go home instead.
Sketchup v6.9 "Community Edition" rockz!!!
I have been trying in SU7 on more complex models. Still does not get a bugsplat.
On 3D letters, RoundCorner gives better results than the old RoundEdge.
I have using SU 7 on Windows Vista x64 SP1 and I have always bug splat.
I have instaled Windows XP SP3 x86 on another HD and until now I don't have Bug Splat.Maybe the problem is with Windows Vista.
I doubt this comes from the operating system. I have myself Vista x64 and does not have problem. Did you try with the latest ruby files I posted (2 messages above)?
This plug in works incredible and very easy to use ... Thank you very much Fredo6...
I don't know what you did exactly to the files BUT all of the options now work perfectly... without a single bugsplat - despite my best [worst] efforts to make one !Well fixed !!!
[Now all you have to do is stop it writing the 'FredoTraceRoundCorner.txt' file into Plugins and it'll be 'perfect'...]
I have tested the new version and it works perfectly too... even tried a very small bevel <1mm OK...
It still writes the temp txt file...
Only relevant for bugsplats issues
I still don't understand what is the exact problem. I tried under SU7 with a cube of 10 meters dimensions and a 1 mm bevel, and it works without any splat (though you hardly see the bevel).
In any case, as the origin might be subtle, I have equipped the processing methods with a file trace (file FredoTraceRoundCorner.txtin the Sketchup Plugins directory). You just drop the attached file in the ROUNDCORNDER_Dir_20 folder.
If you are able to reproduce a bugsplat, could you please send me the text file.
[Edit 11 Jul 09] Attachment removed. Fix in release 2.0b
@tig said:
Here's my error message...[attachment=0:nm089gv7]<!-- ia0 -->FredoTraceRoundCorner[1mcube100mmbevel all edgesTIG].txt<!-- ia0 -->[/attachment:nm089gv7]
TIG,
Very strange. The trace files says that you executed the whole operation with no problem.
That was the same for Pilou's trace file.Please keep the model where you can reproduce the bugsplat until I can identify the problem and find a solution.
If so, could you try again with the attached file (it still contain traces).
Also, do you see the hour glass before the splat?Fred
About the bugsplat in SU7
@tig said:
Here's latest report...[attachment=0:2kckf8n5]<!-- ia0 -->FredoTraceRoundCorner[TIG-20090711].txt<!-- ia0 -->[/attachment:2kckf8n5]It seems that the whole operation completes normally. The bugsplat may be right afterward.
I have tweaked the code, just in case, with the attached files.
If you can reproduce again the same situation you had before, would you mind to test.
ThanksFredo
@tig said:
**[Now all you have to do is stop it writing the 'FredoTraceRoundCorner.txt' file into Plugins and it'll be 'perfect'...]
**Apparently SU7 does not like calling GUI functions via UI.start_timer.
Before I release the fix, would you mind to test the attached file (still with traces) so that I am sure this is the problem (whether you get or not the splat, I would know what it is).[Edit 11 Jul 09] Attachment removed. Fix in release 2.0b
Again, thanks very much for your help.
NEW version 2.0b, hopefully fixing the bugsplat problem in SU7.
Thanks to TIG and others for helping debug this one.See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721
