by mfseeker » Tue May 19, 2009 9:09 pm
I think I have followed the manual instructions for installing LibFredo6_3.1f to the letter. I have tried it several times this afternoon. Whatever I do, I do not get the LibFredo6 Settings menu to appear when I start SU7. SU7 starts normally without any error messages. I am at a loss to know what to do next to troubleshoot my installation.
mfseeker
- Name: Stan Armstrong
by fredo6 » Tue May 19, 2009 11:03 pm
mfseeker wrote:I think I have followed the manual instructions for installing LibFredo6_3.1f to the letter. I have tried it several times this afternoon. Whatever I do, I do not get the LibFredo6 Settings menu to appear when I start SU7. SU7 starts normally without any error messages. I am at a loss to know what to do next to troubleshoot my installation.
This might be because you did not install FreeScale or HoverSelect. Actually, I arranged that, unless a script using LibFredo6 is used, the library itself is not loaded, in order not to pollute Sketchup, not even with the menu (except a very small bootstrap code). Remember that, alone, LibFredo6 does not provide any functionality. Fredo
- PluginStore Author
- Name: Fredo6
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Intermediate
by mfseeker » Wed May 20, 2009 1:58 am
I only wish it were that simple. I tried both with and without putting FreeScale in the Plugins folder. When FreeScale is in the folder, I get:
"Error Loading File FreeScale_Common.rb (eval):1: uninitialized constant FreeScale::T6"
Where do I go from here?
mfseeker
by fredo6 » Wed May 20, 2009 7:42 am
It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
- Name: Fredo6
- License type: Pro
by mfseeker » Wed May 20, 2009 11:07 am
Fredo6 wrote:It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
Yes. The file "LibFredo6.rb" is here "C:\Program Files\Google\Google SketchUp 7\Plugins" The size is "3.03 KB (3,108 bytes)" The modification date is "Tuesday, February 10, 2009, 9:29:56 PM"
mfseeker
by fredo6 » Wed May 20, 2009 1:32 pm
Then, I would suggest you resinstall with the Zip files, because your current settup is missing something, or files may not be in the right place. For FreeScale, the footprint at the Sketchup Plugin Directory level should be Snap12.jpg Although you don't really have to care, here is the inside. But the rule is not to modify or rename any of the files. FreeScale footprint.jpg I hope this helps. Fredo
- Name: Fredo6
- License type: Pro
by mfseeker » Wed May 20, 2009 5:06 pm
You were right, of course. I was missing files. Once, I found the latest I was able to install and run FreeScale. Thanks so much for your help.
The reason I found your wonderful plugin in the first place was that I was looking for a way to model bending 1 1/2" x 1 1/2" x 78" vertical wooden elements so that their tops would be offset in both the x and y directions by perhaps 4", creating a gentle bow.
When I try the Radial bending tool, what I get is not a curved bend (similar to the one shown in the tool's icon) but a skewing. The documentation didn't help me. What am I missing?
mfseeker
by mfseeker » Wed May 20, 2009 5:48 pm
Ah, I found the video. Bend works with embedded slice F4. Thanks.
mfseeker
by mpowell1234567890 » Sun May 24, 2009 9:59 am
Wow! This plugin is amazing. Love it a lot - very easy to use too. When is the next update? Fredo6 wrote:[Edit - 04 May 09 - 23:00 CET -> LibFredo6 3.1f] bug fixing for Mac compatibility and updated Italian translation. Required by FreeScale 2.0f. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180. [Edit - 28 Apr 09 - 22:20 CET -> LibFredo6 3.1e] bug fixing required by FreeScale 2.0e. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180. [Edit - 17 Apr 09 - 06:05 CET -> LibFredo6 3.1d] bug fixing required by FreeScale 2.0d. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180. [Edit - 11 Apr 09 - 16:25 CET -> LibFredo6 3.1c] various bugs fixed and some small evolutions required by FreeScale 2.0c. NOTE: again, download the zip file, Open it, then Select All, then Extract in the Sketchup Plugins folder, answering YES to any request for replacing files. This way you are sure to recreate the proper folder hierarchy. [Edit - 01 Apr 09 - 08:30 CET -> LibFredo6 3.1b] various bugs fixed and some small evolutions required by FreeScale 2.0b. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180. --------------------------- LibFredo6 is a Shared Library which is used by some of my scripts. The first one to use it is FreeScale. It used to be called LibTraductor in previous times. Version 3.1 or higher is necessary to run FreeScale 2.0 As a user, you should not bother too much, except to install it and respect the versions required by the Plugins. The current version of LibFredo6 is 3.1 (so 31 in integer form). I maintain backward compatibility so plugins using an older version of LibFredo6 should work with a new version. LibFredo6 takes care, among others, of enriching the plugin with a few capabilities: - Default parameters
- Language translation via external files (please, read the doc if you wish to contribute)
- Extra information and external links available in the “About…” box and menus
LibFredo6 installs a submenu “LibFredo6 Settings…” in the Sketchup Windows menu. It contains a command to set the language preferences, to set a few default parameters (inference colors) and to access the documentation (as a PDF).
mpowell1234567890
by matteo » Fri Jul 10, 2009 7:44 am
Thank you very much for this essential tool.
matteo
- Name: matteo bignozzi
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Bob James » Sat Jul 11, 2009 3:32 am
I can find no place to download 3.2a
Bob James
- Premium Member
- Name: Robert James
- SketchUp version: 2018
- License type: Pro
- SketchUp use: engineering and mechanical design
by •BTM » Sat Jul 11, 2009 3:41 am
Bob James wrote:I can find no place to download 3.2a
… Bottom of first post of this thread.
•BTM
- Name: •BTM
by Bob James » Sat Jul 11, 2009 3:43 am
•BTM wrote:Bob James wrote:I can find no place to download 3.2a
Clicking on that just takes me back the same page
Bob James
- Premium Member
- License type: Pro
by •BTM » Sat Jul 11, 2009 3:57 am
Bob James wrote:•BTM wrote:Bob James wrote:I can find no place to download 3.2a
The attachment at the bottom of the first post.
•BTM
- Name: •BTM
by Bob James » Sat Jul 11, 2009 8:22 am
•BTM wrote:The attachment at the bottom of the first post.
Maybe I should change my user name to "Dumb and Dumber". The only thing at the bottom of the first post " [Plugin] RoundCorner 2.0a - 9 Jul 09" was RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf. At the top of that post was: "RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf ... 47#p144178". That took me to this post where there is no LibFredo6 3.2a download
Bob James
- Premium Member
- License type: Pro
by COSEDIMARCO » Sat Jul 11, 2009 8:45 am
Hi Bob at then end of the first post in this 3D there's the attachment with the new Libraries
COSEDIMARCO
- SketchUp version: 2015
- License type: Free/Make
- SketchUp use: game and/or sci-fi modelling
by free agent » Sat Jul 11, 2009 8:35 pm
through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
free agent
- Name: Free Agent
by fredo6 » Sat Jul 11, 2009 9:00 pm
Free Agent wrote:through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
I answered your question in the main thread related to RoundCorner. See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
- Name: Fredo6
- License type: Pro
by Bob James » Sun Jul 12, 2009 9:05 am
COSEDIMARCO wrote:Hi Bob at then end of the first post in this 3D there's the attachment with the new Libraries
Egads!! Was that there all the time. Arrrggghhh.
Bob James
- Premium Member
- License type: Pro
by Zante » Mon Jul 13, 2009 12:24 pm
The bend modifier seems to add a load of geometry to things. : [
Zante
by szanini » Sat Jul 18, 2009 12:20 am
You're the man!!!
szanini
- Name: Sandro Adriano Carbone Zanini
by pierrearchi » Sat Jul 25, 2009 10:06 pm
Fredo, I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !! I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b. I have put them in the right folder : Both in plugins file inside Application support file path. Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!. Bye, Pierre.
pierrearchi
by mariocha » Sun Jul 26, 2009 4:17 pm
pierrearchi wrote:I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b. I have put them in the right folder : Both in plugins file inside Application support file path.
Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in / user/Librairy /Application support/ etc... Ce que j'ai fait, et tout baigne nickel ( comme disent les français). Fredo must be complimented .... again.
Mario C. Certified SketchUp Trainer, QC CA. Every rule has exceptions, but some.
mariocha
- Premium Member
- Name: mario chabot
- Operating system: Mac
- SketchUp version: 2019
- License type: Pro
by Bob James » Mon Jul 27, 2009 6:24 pm
mariocha wrote:Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc...
That certainly is true of Profile Builder and Podium, but LibFredo6.rb works just fine in the usual place (Mac/Library/Applications Support/Google SketchUp 7/plugins).
Bob James
- Premium Member
- License type: Pro
by fredo6 » Thu Aug 27, 2009 11:03 pm
NEW VERSION 3.3a - 27 Aug 09Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect). Small evolutions (some for Palettes), bug fixing, ... see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
- Name: Fredo6
- License type: Pro
by COSEDIMARCO » Fri Aug 28, 2009 5:17 am
Hi Fredo. Where can I find new version of Tools on surface?
COSEDIMARCO
by fredo6 » Fri Aug 28, 2009 3:04 pm
COSEDIMARCO wrote:Hi Fredo. Where can I find new version of Tools on surface?
Not yet ready. It will be a refresh, with a palette for better visualizing the options, some improvements to the Freehand tool and a few other evolutions. Fredo
- Name: Fredo6
- License type: Pro
by massimo » Fri Aug 28, 2009 4:43 pm
Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
massimo
- Name: Massimo Siracusa
- SketchUp version: 2014
- License type: Pro
- SketchUp use: other
by pilou » Fri Aug 28, 2009 5:59 pm
Sorry what is "GhostComp 1.0"?
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- SketchUp use: hobby
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
