SketchUcation Premium Membership
[Plugin Library] LibFredo6 - v4.9a - 18 May 13
Re: [Library] LibFredo6 3.1f install problem
Postby mfseeker » Tue May 19, 2009 9:09 pm
I think I have followed the manual instructions for installing LibFredo6_3.1f to the letter. I have tried it several times this afternoon. Whatever I do, I do not get the LibFredo6 Settings menu to appear when I start SU7. SU7 starts normally without any error messages. I am at a loss to know what to do next to troubleshoot my installation.
mfseeker
Name: Stan Armstrong
Postby Fredo6 » Tue May 19, 2009 11:03 pm
mfseeker wrote:I think I have followed the manual instructions for installing LibFredo6_3.1f to the letter. I have tried it several times this afternoon. Whatever I do, I do not get the LibFredo6 Settings menu to appear when I start SU7. SU7 starts normally without any error messages. I am at a loss to know what to do next to troubleshoot my installation.
This might be because you did not install FreeScale or HoverSelect.
Actually, I arranged that, unless a script using LibFredo6 is used, the library itself is not loaded, in order not to pollute Sketchup, not even with the menu (except a very small bootstrap code). Remember that, alone, LibFredo6 does not provide any functionality.
Fredo6
Top SketchUcator
Re: [Library] LibFredo6 3.1f (04 May 09)
Postby mfseeker » Wed May 20, 2009 1:58 am
I only wish it were that simple. I tried both with and without putting FreeScale in the Plugins folder. When FreeScale is in the folder, I get:
"Error Loading File FreeScale_Common.rb
(eval):1: uninitialized constant FreeScale::T6"
Where do I go from here?
mfseeker
Postby Fredo6 » Wed May 20, 2009 7:42 am
It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
Fredo6
Top SketchUcator
Postby mfseeker » Wed May 20, 2009 11:07 am
Fredo6 wrote:It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
Yes.
The file "LibFredo6.rb" is here "C:\Program Files\Google\Google SketchUp 7\Plugins"
The size is "3.03 KB (3,108 bytes)"
The modification date is "Tuesday, February 10, 2009, 9:29:56 PM"
mfseeker
Postby Fredo6 » Wed May 20, 2009 1:32 pm
Then, I would suggest you resinstall with the Zip files, because your current settup is missing something, or files may not be in the right place.
For FreeScale, the footprint at the Sketchup Plugin Directory level should be
Although you don't really have to care, here is the inside. But the rule is not to modify or rename any of the files.
I hope this helps.
Fredo6
Top SketchUcator
Postby mfseeker » Wed May 20, 2009 5:06 pm
You were right, of course. I was missing files. Once, I found the latest I was able to install and run FreeScale. Thanks so much for your help.
The reason I found your wonderful plugin in the first place was that I was looking for a way to model bending 1 1/2" x 1 1/2" x 78" vertical wooden elements so that their tops would be offset in both the x and y directions by perhaps 4", creating a gentle bow.
When I try the Radial bending tool, what I get is not a curved bend (similar to the one shown in the tool's icon) but a skewing. The documentation didn't help me. What am I missing?
mfseeker
Postby mfseeker » Wed May 20, 2009 5:48 pm
Ah, I found the video. Bend works with embedded slice F4. Thanks.
mfseeker
Postby mpowell1234567890 » Sun May 24, 2009 9:59 am
Wow! This plugin is amazing. Love it a lot - very easy to use too. When is the next update?
Fredo6 wrote:[Edit - 04 May 09 - 23:00 CET -> LibFredo6 3.1f]
bug fixing for Mac compatibility and updated Italian translation. Required by FreeScale 2.0f. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
[Edit - 28 Apr 09 - 22:20 CET -> LibFredo6 3.1e]
bug fixing required by FreeScale 2.0e. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
[Edit - 17 Apr 09 - 06:05 CET -> LibFredo6 3.1d]
bug fixing required by FreeScale 2.0d. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
[Edit - 11 Apr 09 - 16:25 CET -> LibFredo6 3.1c]
various bugs fixed and some small evolutions required by FreeScale 2.0c.
NOTE: again, download the zip file, Open it, then Select All, then Extract in the Sketchup Plugins folder, answering YES to any request for replacing files. This way you are sure to recreate the proper folder hierarchy.
[Edit - 01 Apr 09 - 08:30 CET -> LibFredo6 3.1b] various bugs fixed and some small evolutions required by FreeScale 2.0b. See that post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180.
LibFredo6 is a Shared Library which is used by some of my scripts. The first one to use it is FreeScale. It used to be called LibTraductor in previous times.
Version 3.1 or higher is necessary to run FreeScale 2.0
As a user, you should not bother too much, except to install it and respect the versions required by the Plugins. The current version of LibFredo6 is 3.1 (so 31 in integer form). I maintain backward compatibility so plugins using an older version of LibFredo6 should work with a new version.
LibFredo6 takes care, among others, of enriching the plugin with a few capabilities:
  • Default parameters
  • Language translation via external files (please, read the doc if you wish to contribute)
  • Extra information and external links available in the “About…” box and menus
LibFredo6 installs a submenu “LibFredo6 Settings…” in the Sketchup Windows menu. It contains a command to set the language preferences, to set a few default parameters (inference colors) and to access the documentation (as a PDF).
mpowell1234567890
Re: [Library] LibFredo6 3.2a (09 Jul 09)
Postby Fredo6 » Thu Jul 09, 2009 10:52 pm
NEW VERSION 3.2a
Needed for for RoundCorner 2.0 (and compatible for FredoScale and HoverSelect).
see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
Fredo6
Top SketchUcator
Postby matteo » Fri Jul 10, 2009 7:44 am
Thank you very much for this essential tool.
matteo
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Bob James » Sat Jul 11, 2009 3:32 am
I can find no place to download 3.2a
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby •BTM » Sat Jul 11, 2009 3:41 am
Bob James wrote:I can find no place to download 3.2a
… Bottom of first post of this thread.
•BTM
Postby Bob James » Sat Jul 11, 2009 3:43 am
Clicking on that just takes me back the same page :?:
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby •BTM » Sat Jul 11, 2009 3:57 am
The attachment at the bottom of the first post.
•BTM
Postby Bob James » Sat Jul 11, 2009 8:22 am
•BTM wrote:The attachment at the bottom of the first post.
Maybe I should change my user name to "Dumb and Dumber".
The only thing at the bottom of the first post "[Plugin] RoundCorner 2.0a - 9 Jul 09" was
RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf.
At the top of that post was:
"RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf ... 47#p144178".
That took me to this post where there is no LibFredo6 3.2a download :?:
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby COSEDIMARCO » Sat Jul 11, 2009 8:45 am
Hi Bob
at then end of the first post in this 3D there's the attachment with the new Libraries :D
COSEDIMARCO
Postby Free Agent » Sat Jul 11, 2009 8:35 pm
through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
User avatar
Free Agent
Postby Fredo6 » Sat Jul 11, 2009 9:00 pm
Free Agent wrote:through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
I answered your question in the main thread related to RoundCorner.
See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147
LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
Fredo6
Top SketchUcator
Postby Bob James » Sun Jul 12, 2009 9:05 am
COSEDIMARCO wrote:Hi Bob
Egads!! Was that there all the time. Arrrggghhh.
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Zante » Mon Jul 13, 2009 12:24 pm
The bend modifier seems to add a load of geometry to things. : [
Zante
Postby szanini » Sat Jul 18, 2009 12:20 am
You're the man!!! :sketchstatic:
User avatar
szanini
Name: Sandro Adriano Carbone Zanini
SketchUp version: 8
License type: Free
Postby pierrearchi » Sat Jul 25, 2009 10:06 pm
Fredo,
I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !! :roll: :roll: :roll:
I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b.
I have put them in the right folder : Both in plugins file inside Application support file path.
Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!.
Bye,
Pierre.
pierrearchi
Postby mariocha » Sun Jul 26, 2009 4:17 pm
pierrearchi wrote:I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b.
Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc...
Ce que j'ai fait, et tout baigne nickel (comme disent les français). :thumb:
Fredo must be complimented .... again.
Mario C.
Certified SketchUp Trainer, QC CA, Mac Pro 2xQuad core & MacBook Pro 3.06 Ghz.
User avatar
mariocha
Premium Member
Premium Member
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby Bob James » Mon Jul 27, 2009 6:24 pm
mariocha wrote:Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc...
That certainly is true of Profile Builder and Podium, but LibFredo6.rb works just fine in the usual place (Mac/Library/Applications Support/Google SketchUp 7/plugins).
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: [Plugin Library] LibFredo6 3.3a (27 Aug 09)
Postby Fredo6 » Thu Aug 27, 2009 11:03 pm
NEW VERSION 3.3a - 27 Aug 09
Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect).
Small evolutions (some for Palettes), bug fixing, ...
Fredo6
Top SketchUcator
Postby COSEDIMARCO » Fri Aug 28, 2009 5:17 am
Hi Fredo. Where can I find new version of Tools on surface?
COSEDIMARCO
Postby Fredo6 » Fri Aug 28, 2009 3:04 pm
COSEDIMARCO wrote:Hi Fredo. Where can I find new version of Tools on surface?
Not yet ready. It will be a refresh, with a palette for better visualizing the options, some improvements to the Freehand tool and a few other evolutions.
Fredo6
Top SketchUcator
Postby massimo » Fri Aug 28, 2009 4:43 pm
Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby Pilou » Fri Aug 28, 2009 5:59 pm
Sorry what is "GhostComp 1.0"? :oops:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: cubcrafter, Dave R, gclarke123, Khai, LUCAARTS, Rich O Brien, TIG, yaseenalastal and 11 guests
