by Pilou » Fri Jul 03, 2009 1:31 am
another try found: undefined method ‘[]’ - Code: Select all
model = Sketchup.active_model entities = model.entities selection = model.selection
z=0 zeds=[] index=0 sorted_groups=[]
groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::Group)}
groups.each{|group|zeds.push(group.bounds.min.z, index) index+=1 } zeds.sort! zeds.each{|z|sorted_groups.push(groups[z[1]]) } ### sorted_groups is now groups sorted by
sorted_groups.each do |e| # update! # Now we process the groups point = Geom::Point3d.new 0,0,z t = Geom::Transformation.new point # Apply the transformation e.transform!(t) z = z + 100.cm end
Pilou
- Top SketchUcator
- Operating system: Windows
- SketchUp version: 6
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Advanced
by thomthom » Fri Jul 03, 2009 9:49 am
Is that the only error message you get? Pilou wrote:it's like a snowball on the top of the mountain
You're hooked now! No way back!
- Global Moderator
- Name: thomthom
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
by TIG » Fri Jul 03, 2009 9:51 am
Here's some tweaked code - Code: Select all
def test() model = Sketchup.active_model model.start_operation("Move in Z") entities = model.entities selection = model.selection
groups.each{|group|zeds.push([group.bounds.min.z, index]) index+=1 } zeds.sort! zeds.each{|z|sorted_groups.push(groups[z[1]]) } ### sorted_groups is now groups sorted by
z = 0.0 sorted_groups.each do |e| # update! # Now we process the groups t = Geom::Transformation.new(Geom::Point3d.new(0,0,z)) # Apply the transformation e.transform!(t) z = z + 100.cm end model.commit_operation return nil end#def
Runs as ' test'. I made a typo - it needed an array [] of two items adding to zeds: zeds.push([group.bounds.min.z, index]) not two 'loose' items as in zeds.push(group.bounds.min.z, index). I made your z = 0 into z = 0.0 as it needs the number as a float, not an integer... Removed 'point' variable and set the point definition directly inside the transformation - not necessary but fewer variables... I added a model.start_operation("")...model.commit_operation so it becomes a one step undo. I added return nil at end so the Ruby-Console doesn't get clogged with info... Tested it - it works...
- Global Moderator
- Name: TIG
- SketchUp version: 2013
- License type: Pro
by Pilou » Fri Jul 03, 2009 3:41 pm
Seems indeed that some corrections were necessary This time works like a charm! Excellent! TIG + Thomthom! Bravo! I will see all that more in detail for learn this little cryptic language ! Very funny plug!  For the next Pilou's foolish... ...I need to know the "centroïd" (xyz) of a "bounding box's group" Here of course without different measure, just for little test!  (click image)
Pilou
- Top SketchUcator
by TIG » Fri Jul 03, 2009 5:03 pm
- Code: Select all
centre_point=group.bounds.center
See http://code.google.com/apis/sketchup/docs/ for all these details
- Global Moderator
- Name: TIG
- License type: Pro
by Pilou » Sat Jul 04, 2009 1:15 pm
Thx I had missed this one
Pilou
- Top SketchUcator
by Pilou » Tue Jul 07, 2009 11:52 am
I have replaced "Group" by "Component" but seems that is not so simple - Code: Select all
groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::Component)}
groups.each{|component|zeds.push([component.bounds.min.z, index])
Else I can yet nest a component inside a group color transparent That works fine (just disable Edges visible) but I suppose there is another thing
Pilou
- Top SketchUcator
by thomthom » Tue Jul 07, 2009 11:58 am
It'd help if you posted the error messages.
However, I can still see the problem here. Sketchup::Component isn't an SU object. Check the manual, you have Sketchup::ComponentDefinition and Sketchup::ComponentInstance. In your case you're looking for a Sketchup::ComponentInstance.
- Global Moderator
- Name: thomthom
- License type: Pro
by Pilou » Tue Jul 07, 2009 12:07 pm
Yep!!! THX! Miracle that is working! Sure I should read the Api document before  But I had risked the trick So my second script was a new speedy success and a big lesson  groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup::ComponentInstance)}
groups.each{|ComponentInstance|zeds.push([ComponentInstance.bounds.min.z, index]) Copy my code follow in the Web console from Jim Foltz (if you have components use the file linked ) - Code: Select all
groups.each{|group|zeds.push([group.bounds.min.z, index]) index+=1 } zeds.sort! zeds.each{|z|sorted_groups.push(groups[z[1]]) } ### sorted_groups is now groups sorted by z
Some help for fun variations
Pilou
- Top SketchUcator
by Pilou » Wed Jul 15, 2009 2:55 pm
Come back in these very dangerous territories As I understand that retrieve the center XYZ of the bounding box group by - Code: Select all
center = boundbox.center
but how give these 3 values(?) to these 3 variables ? xc= ? yc= ? zc= ? must be trivial but yet some foggy for me  PS I read the API from the end to the start, and inverse but this stay mysterious found anything except that
Pilou
- Top SketchUcator
by thomthom » Wed Jul 15, 2009 3:20 pm
boundbox.center returns an object of type Point3d. You can check what an object is by checking the .class value of an object. That gives you an indication to where to look. - Code: Select all
xc= boundbox.center.x yc= boundbox.center.y zc= boundbox.center.z
- Global Moderator
- Name: thomthom
- License type: Pro
by Pilou » Wed Jul 15, 2009 4:02 pm
Many thx! It's always the more easy ans usefull who is not written as example
Pilou
- Top SketchUcator
by Pilou » Wed Jul 15, 2009 5:05 pm
??? = error : in ‘initialize’: undefined local variable or method ‘boundbox’ - Code: Select all
model = Sketchup.active_model entities = model.entities selection = model.selection #groups = [] xp=100 # Pivot Point yp=100 zp=100
xc=0 #Center Point of the grouped object yc=0 zc=0
xe=0 #End Point of the grouped object ye=0 ye=0
selection.each do |e| # update! # Skip all entities that aren't groups next unless e.is_a? Sketchup::Group # Now we process the groups
center = boundbox.center xc= boundbox.center.x # ??? error yc= boundbox.center.y zc= boundbox.center.z xe=xc ye=yc ze=zc if xc<xp xe =xc - 100 end if xc>xp xe =xc +100 end
if yc<yp ye =yc - 100 end if yc>yp ye =yc +100 end
if zc<zp ze =zc - 100 end if zc>zp ze =zc +100 end
point = Geom::Point3d.new xe,ye,ze t = Geom::Transformation.new point # Apply the transformation e.transform!(t) end
Pilou
- Top SketchUcator
by thomthom » Wed Jul 15, 2009 5:30 pm
That's because of center = boundbox.center <- you haven't referenced boundbox yet. - Code: Select all
change to - Code: Select all
center = e.bounds.center xc= center.x yc= center.y zc= center.z
- Global Moderator
- Name: thomthom
- License type: Pro
by Pilou » Wed Jul 15, 2009 6:29 pm
Thx! More easy with that  Works like a charm I can now test some natures of explodes
Pilou
- Top SketchUcator
by Pilou » Wed Jul 15, 2009 7:06 pm
Funny thing
Pilou
- Top SketchUcator
by Pilou » Thu Jul 16, 2009 10:15 am
Some tests  Put the code inside the WebConsole by Jim Foltz Press "Eval" button and have fun Veyron model is from 3Dwarehouse! - Code: Select all
xp=100 # Pivot Point (as you want) yp=100 zp=100
q=50 # Measure of translation (as you want)
selection.each do |e| # update! # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups next unless e.is_a? Sketchup::ComponentInstance # Now we process the component or group center = e.bounds.center #Center Point of the grouped object xc= center.x yc= center.y zc= center.z xe=xc #End Point of the grouped object ye=yc ze=zc
if xc<xp xe =xc - q end
if xc>xp xe =xc + q end
if yc<yp ye =yc - q end
if yc>yp ye =yc + q end
if zc<zp ze =zc - q end
if zc>zp ze =zc + q end
Pilou
- Top SketchUcator
by thomthom » Thu Jul 16, 2009 10:22 am
Looking good Pilou! Instant assembly drawings!  This should come in handy.
- Global Moderator
- Name: thomthom
- License type: Pro
by Pilou » Thu Jul 16, 2009 10:27 am
Instant assembly
Alas for the inverse, that must be more tricky! Better is use the Undo
Pilou
- Top SketchUcator
by thomthom » Thu Jul 16, 2009 10:43 am
hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
though, that will fail if the user moves anything... Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please.
- Global Moderator
- Name: thomthom
- License type: Pro
by Pilou » Thu Jul 16, 2009 10:52 am
In theory that must be more easy Just select that you want and apply a "negative" translation : a deflation  Maybe my next  And the above is not yet perfect! The Pivot Point seems not have the wished result wanted be continued... Ps When Groups or Components are nested how to process automatically? A plug for make each components individual is maybe existing? Edit one exist for group by TIG Explode2groupsmiss now somethings transform Transform2goups or Explode2Components
Pilou
- Top SketchUcator
by Chris Fullmer » Thu Jul 16, 2009 10:14 pm
Store the original transformation in a dictionary attached to the group/component. Then to unexplode, just re-apply that transformation onto the group. It will go right back where it belongs.
I wrote that crazy scrambler script a while ago that does this and it worked very well.
- SketchUp Team
- Name: Chris Fullmer
- License type: Pro
- SketchUp use: landscape architecture
by Pilou » Thu Jul 16, 2009 10:25 pm
@Chris Any chance to see it somewhere?  PS A plug for make each components individual is maybe existing? Edit one exist for group by TIG Explode2groupsmiss now somethings for components Transform2goups or Explode2Components
Pilou
- Top SketchUcator
by Chris Fullmer » Thu Jul 16, 2009 10:38 pm
take the componentInstance, add it to a group, then explode the component instance.
And I posted my scrambler script here. I'll see if I can find the thread.
- SketchUp Team
- License type: Pro
by Pilou » Fri Jul 17, 2009 8:59 am
@Chris thx for the Info Fredo6 has inside the FredoScale something who transform any selection of groups or Components in "Unique" groups or componants! (each become individual) (last icon)
Pilou
- Top SketchUcator
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
- Robot
Return to Developers' Forum
