SketchUcation Plugin Store
[Plugin] extrudeEdgesByEdges.rb
Re: [Plugin]extrudeEdgesByEdges.rb
Postby CadFather » Tue Jun 23, 2009 11:33 am
gotcha!.. :roll: :lol:
..the script does lead you into 'lofty' considerations..
Quarr-IT - SketchUp Training from the Master.. . ;) .
User avatar
CadFather
Name: Max Coppoletta
Postby majid » Tue Jun 23, 2009 7:05 pm
thanx dear TIG .. it is great. maybe the next step is adding options so that it could do something like Follow me ,+ FollowMe&Keep, but whit a noncouplanar profile (like your scrip is doing)... again :it is great TIG :thumb:
تیگ عزیز،ممنون از سخاوت تو
User avatar
majid
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: architecture
Level of SketchUp: Intermediate
Postby mitcorb » Tue Jun 23, 2009 8:06 pm
TIG:
Did you notice the plugin will displace the resulting group a distance away from the originating groups? I don't know if this is a random distance or a proportional distance, or if it is dependent on the geometry of the originating elements. This is just an observation, and not necessarily a problem.
mitcorb
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby TIG » Tue Jun 23, 2009 8:08 pm
majid
Thanks for the ideas...
Peace, hello: I am happy that the website is active ?
My Farsi is not so good...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Postby TIG » Tue Jun 23, 2009 8:09 pm
mitcorb wrote:TIG:
mitcorb
The result sometimes displaces... It's to do with the translations of the two groups, I haven't yet worked out how to ensure it always snaps over the original - the displacement is the bounds of the new group v. the originals...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Ben Ritter » Tue Jun 23, 2009 9:11 pm
TIG,
Very grateful for your talent, and for sharing.
Thank you.
Ben Ritter
Postby plot-paris » Wed Jun 24, 2009 8:22 am
wow, really a nice plugin! thanks a lot, TIG! *jumps out of his seat* :berserk:
(and thanks Gaieus, for pointing me here...)
that is quite a useful tool.
next step: birial operation? (two different path-curves and/or several different base-curves...) ;)
User avatar
plot-paris
SketchUp version: 8
License type: Pro
Postby mitcorb » Wed Jun 24, 2009 2:19 pm
As Plot-paris said: "next step: birail operation? (two different path-curves and/or several different base-curves...) ;) and then morph along rails to preset sectional outlines, and who knows what else?
I am currently enjoying some experimentation with this plugin-- craggy curtains, canyon walls, insect "skins"....
Thank you TIG
mitcorb
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby olishea » Wed Jun 24, 2009 7:43 pm
does it work well for mac?
oli
User avatar
olishea
Premium Member
Premium Member
Postby Dylan » Wed Jun 24, 2009 9:44 pm
Works perfectly on the Mac Oli 8-)
Dylan
Postby putnik » Thu Jun 25, 2009 4:05 am
Thank you TIG!
putnik
Name: Kesha Chakhvorostov
Postby olishea » Thu Jun 25, 2009 9:45 am
amazing plugin, works really smooth too. gonna have some fun with this! :lol:
oli
User avatar
olishea
Premium Member
Premium Member
Re: [Plugin]extrudeEdgesByEdges.rb v1.1
Postby TIG » Thu Jun 25, 2009 11:45 am
Version 1.1 20090625
Speed improvements - face making time ~halved,
typename >> kind_of?, triangulation glitch trapped
and orientation improved.
It's here viewtopic.php?p=166780#p166780 ...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jun 25, 2009 12:34 pm
The funny of your plug ;)
(Click the image)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby MALAISE » Thu Jun 25, 2009 1:08 pm
Great TIG, thanks a lot for this SU enhancement.
MALAISE :berserk:
MALAISE
Postby JClements » Thu Jun 25, 2009 2:53 pm
Congratulations TIG!
A very useful and well executed script.
Questions/Suggestions:
1- I assume the order in which the two groups were assigned determines the alignment of the mesh; to the last defined of the two selected groups.
2- Not critical, but could there be a Smoothing Dialog that prompts: "a)Smooth or b)Smooth and Soften"?
3- A defaults dialog triggered by pressing the [Tab] key? You'd would then be able to assign defaults of a Yes or No for each prompt and which which dialogs would be shown (if shown, then user could temporarily change their default as the script is playing).
John
Illustrator
Beaverton, Oregon
User avatar
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Re: [Plugin]extrudeEdgesByEdges.rb v1.2
Postby TIG » Thu Jun 25, 2009 5:05 pm
Here's an update...
Version 1.2 20090625
Orientation speed optimised.
Glitch on groups erase fixed.
Get it here... viewtopic.php?p=166780#p166780 ...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby massimo » Thu Jun 25, 2009 6:27 pm
Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Muchas GRACIAS...!
Postby ideas_arte » Thu Jun 25, 2009 7:06 pm
:berserk: :berserk: Wow...! :berserk: :berserk:
Many thank you very much ...!
Excellent tool, thank you very much again and a hug from Central America ...! :D
ideas_arte
Postby TIG » Fri Jun 26, 2009 9:13 am
massimo wrote:Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
Massimo
Have you tried the latest version v1.2 ? I've just tried to reproduce your path/profile and I get all faces made - no gaps - Any edge that can get a face should get a face ? Your faces aren't reversed are they, so look 'gappped' ?
The only problem I have was because of the convoluted result some faces orient wrongly [inside out] - both in the script AND within SUp later - the only fix is to reverse the problem faces manually ...
I had to guess your model's details - I could test it better with the real thing - if after trying with the latest version it still gaps please PM me with the model attached, so I can see if I get the same problem...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Jun 26, 2009 10:42 am
I have same result but seems normal as this function is not adapted to this!
As the profil stay parallel :roll:
At each "rotation" there are creation of an external or internal horizontal face :)
For ovoid that make just an half circle ;)
And a mirror after ;)
But even with this there some gaps ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Fri Jun 26, 2009 10:57 am
Can you subsequently get the face made if you redraw an edge ? If so then EEbyE should have made that face...
I haven't managed to reproduce it, can one of you PM me a [small] model with the problem ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Jun 26, 2009 11:03 am
file of the mirror above ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Fri Jun 26, 2009 3:53 pm
I get no loose edges with either of your skp's... There is orientation weirdness as sometimes threes faces share as edge as it's convoluted in on itself when a circle... to be on the safe side I am adjusting the script to trap any edges without faces... Look out for update...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin]extrudeEdgesByEdges.rb v1.3
Postby TIG » Fri Jun 26, 2009 4:10 pm
Here's v1.3 ...
It's been trapped for rare unfaced edges - it either forces the edge to have a face, or erases the edge if it's not possible to add a face ...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Jun 26, 2009 4:39 pm
There is always no possible to close some faces (my gap file above) ;)
The curious is this is a "big face" :o
Maybe because angle is too flat?
Not so a big deal to close it by hand ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Fri Jun 26, 2009 4:42 pm
Have you tried this latest version ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Jun 26, 2009 4:43 pm
Of ourse yes ;)
The curious was there same size so maybe you have not posted the good version?
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Fri Jun 26, 2009 4:44 pm
Did you still get unfaced edges ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Jun 26, 2009 4:50 pm
yes the same than on my image above! (orange pale one)
After Auto self convoluted stay 2 "big faces" (second of the revolution, and second of the profil)
AND I have this one " 1.3 20090626 Edges not facing in convoluted shapes trapped."
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: cyberia23, danl, serraniadan and 8 guests
