SketchUcation Premium Membership
[Plugin] #SelectionHideShow.rb v1.1
Postby TIG » Wed Jun 03, 2009 10:25 am
#SelectionHideShow.rb adds a context-menu sub-menu with various Selection, Hide and UnHide tools, such as 'Invert Selection', 'Hide/UnHide Selection', 'UnHide All Active' etc...
Edit:
v1.1 Now tests with ".is_a?" to speed-up and avoids testing already unique groups[after AlexM's advice].
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] #SelectionHideShow.rb
Postby Pilou » Wed Jun 03, 2009 10:34 am
Very practical! :fro:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby Mr S » Wed Jun 03, 2009 11:49 am
Great!
I asked for this a while ago.
I suggested it was something that should be a standard feature in SketchUp
Now it is. Thanks for another great contribution.
Regards
Mr S
Mr S
Postby boofredlay » Wed Jun 03, 2009 1:28 pm
Thanks TIG. However I expected to see Reverse Faces in there too.
User avatar
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Postby erikB » Wed Jun 03, 2009 2:06 pm
Thanks TIG, and I second the request made by Boofredlay.
erikB
User avatar
erikB
Postby TIG » Wed Jun 03, 2009 4:00 pm
Reverse and Orient faces is already built-in on the context-menu - near the top [as are some other 'select tools']... adding them would only duplicate stuff...
User avatar
Global Moderator
License type: Pro
Postby AlexMozg » Thu Jun 04, 2009 7:01 am
:?: Why constantly to use the method of group_miner, when in him practically is not there a necessity?
:?: Why to apply properties to entity, when are new properties of entity equal to the applied properties?
These questions are linked at a speed of implementation of script on the large scenes.
:!: Example of considerable increase of speed of implementation of script:
Code: Select all
class Sketchup::Group
    def definition
        self.entities.parent
def SelectionTool::group_miner(ents)
    ents.each do |e|
        if e.is_a? Sketchup::Group
            e.make_unique if e.definition.instances.length > 1
            SelectionTool::group_miner(e.entities)
:!: At the use of method of typename speed of implementation of script goes down in once or twice!
It would be desirable to correct these shortages...
AlexMozg
Postby Chris Fullmer » Thu Jun 04, 2009 7:42 am
Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
I'd rather use the faster method too, I just never knew there was a faster one. I'm sure TIG isn't using a slow method on purpose either...
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby AlexMozg » Thu Jun 04, 2009 9:37 am
Chris Fullmer wrote:Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
Easily to check...
The more elements in the model - the better results script.
SpeedTest
is_a? - 0.36c
kind_of? - 0.39c
class - 0.422c
typename - 1.313c
Model Statistics:
edges = 48981
faces = 8009
groups = 729
components = 365
construction_lines = 1
construction_points = 4
images = 3
section_planes = 4
texts = 4
others = 2
AlexMozg
Postby thomthom » Thu Jun 04, 2009 9:45 am
That's some interesting numbers. I've always used kind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
Thanks for posting this test.
User avatar
Global Moderator
License type: Pro
Re: [Plugin] #SelectionHideShow.rb v1.1
Postby TIG » Thu Jun 04, 2009 11:08 am
Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". :oops:
I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... :geek:
I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! :cry:
Here's v1.1 viewtopic.php?p=161963#p161963
User avatar
Global Moderator
License type: Pro
Postby thomthom » Thu Jun 04, 2009 11:16 am
Maybe we could add this info to a new stickcy where we collect such useful tips and info?
User avatar
Global Moderator
License type: Pro
Postby AlexMozg » Fri Jun 05, 2009 10:34 pm
TIG wrote:...I didn't realise it was so much slower to use typename=="". :oops:
For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
_________________________
My model statistics:
Model 68.4 Mb:
Edges 485016
Faces 128906
Component Instances 6055
Groups 3078
Section Planes 4
P.S.
It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
:roll:
AlexMozg
Postby bianhai » Mon Jun 08, 2009 4:25 am
Very good :fro: !
bianhai
Banned
Postby thomthom » Sat Jun 20, 2009 2:20 pm
Easily to check...
SpeedTest
is_a? - 0.36c
kind_of? - 0.39c
class - 0.422c
typename - 1.313c
Model Statistics:
edges = 48981
faces = 8009
groups = 729
components = 365
images = 3
section_planes = 4
texts = 4
others = 2
Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
http://www.ruby-doc.org/core/classes/Ob ... ml#M000370
User avatar
Global Moderator
License type: Pro
Postby thomthom » Mon Jun 22, 2009 12:11 pm
I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
AT - SpeedTest:
is_a? - 0.89c
kind_of? - 0.782c
class - 0.875c
typename - 2.297c
Model Statistics:
edges = 159630
faces = 61300
groups = 0
components = 1000
construction_lines = 0
construction_points = 0
images = 0
section_planes = 0
texts = 0
others = 0
User avatar
Global Moderator
License type: Pro
Postby thomthom » Mon Jun 22, 2009 12:51 pm
Much larger test. (did have a few programs open while I did the tests.)
AT - SpeedTest:
is_a? - 16.297c
kind_of? - 16.141c
class - 18.703c
typename - 88.703c
Model Statistics:
edges = 8396595
faces = 1026520
groups = 52643
components = 526428
construction_lines = 2
images = 0
section_planes = 0
texts = 0
others = 0
User avatar
Global Moderator
License type: Pro
Postby 3dsmax9 » Thu Jul 28, 2011 5:19 pm
a tool bar will be very great with this script
3dsmax9
Postby irwanwr » Sat Dec 24, 2011 11:36 am
i think i need this plugin
thank you in advance, sir.
User avatar
irwanwr
SketchUp version: 8
SketchUp use: hobby
Level of SketchUp: Beginner
Postby Ivancho » Fri Mar 15, 2013 12:06 pm
NICE!! :ecstatic:
Ivancho
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Flippie123, menmsis, renderiza, zoodogink and 7 guests
