SketchUcation Premium Membership
New Skx Sub Forum
Moderator: Jim
New Skx Sub Forum
Postby Jim » Thu Jun 18, 2009 4:08 pm
This is the first post in a new Ruby Sub-Forum called "Skx Extension Library"
Skx is a project to create an extension library for SketchUp's Ruby API.
My original intention was simply to organize all of the code snippets floating around the Ruby forum and on my computer, to document them, and to make them available as a versioned package so other scripts could take advantage of them. That remains one of the primary goals.
To facilitate collaboration (another primary goal), I set up the skx project on Google Code. Google Code was a mostly arbitrary decision selected because that is what some other people were using (citygen, SketchyPhysics, surdebug and others).
This forum is for documenting the design process and related discussions.
Jim
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Re: New Skx Sub Forum
Postby •BTM » Fri Jun 19, 2009 1:23 am
I might be able to help, but i've got a few questions like; can the snippets use variables other than just local variables (@close_point, etc.) ? If so, I've got a snippet called 'closest_point', that is used to find the closest point from an array of points, to the Point3d object ( a is a point3d object, b is an array of points. a.closest_point b). The issue is that it uses variables, and I don't know if they can or not. :?
Code: Select all
#  Created by •BTM on 16/06/09.
class Geom::Point3d
   def closest_point a
   point = self
      a.each do |e|
         if point != e
         dist = self.distance e
         @close_dist = dist if not @close_dist
            if dist <= @close_dist
            @close_dist = dist
            @close_point = e
   return @close_point
Reason: use [code] tags for blocks of code
•BTM
Postby thomthom » Fri Jun 19, 2009 7:35 am
Code: Select all
class Geom::Point3d
   def closest_point a
      point = self
      close_dist = nil # just init the variable here first - this should work.
      close_point = nil
      a.each do |e|
         if point != e
         close_dist = dist if not close_dist
            if dist <= close_dist
            close_dist = dist
            close_point = e
   return close_point
If you initialise the variable before the loop you can use then inside the loop and after the loop.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby •BTM » Fri Jun 19, 2009 10:28 am
Ah, thanks :thumb:
•BTM
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Return to Skx Extension Library
Who is online
Users browsing this forum: No registered users and 0 guests
