SketchUcation Plugin Store
[Plugin] 1001bit Tools - Architectural tools for SketchUp
Re: Find!!! - Architectural tools for SketchUp
Postby thomthom » Sun Jun 14, 2009 12:21 pm
That last one looks like the fender of an old car. :)
User avatar
Global Moderator
Name: Thomas Thomassen
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby GOHCH » Sun Jun 14, 2009 2:04 pm
Thanks Pilou, for putting the notification here. I was having problem logging in with Firefox; finally got in with IE. :?
And you're right about the 'crazzy' tool :lol:
I haven't been able to figure out what can you use this 'scaling' function for; but seems like good fun anyway :)
Other improvements in version 1.1.6 includes:
1) sorted out a bug in the panel divider tool. Please see details in windows and doors topic.
2) sorted out a bug in the hip roof tool. You can now generate hip roof directly from extruded top surface.
3) Improvement on setting up: no longer need to define path; as long as the 1001bit folder is located within Sketchup's plugins folder; it'll be fine.
You can still choose to define custom location for your 1001bit folder. Just keep your original path file (eg. 1001bit_path_win_su7.rb) or create a new path file
1001bit_path.rb file with a text editor and have the following line in the file
$GH1001bit_path="/your custom path/1001bit"
place the file inside Sketchup's plugins folder. note the name of the file is not important, as long as it has a .rb extension and it get run when SU loads.
I have not included the language folder in the standard zip file so that it will not overwrite the translated language file that you currently have.
However, the images are included. For those who are using language packs with translated images, you'll have to reload the images from the language pack again, after setting up v1.1.6
For details on necessary changes in language pack translations, please refer
http://www.1001bit.com/discussions/viewtopic.php?f=17&t=48&p=210#p210
Thanks for everyone's support and have fun with 1001bit tools! :D :D :D
Goh C H
GOHCH
Name: Goh Chun Hee
Postby thomthom » Sun Jun 14, 2009 2:24 pm
GOHCH wrote:2) sorted out a bug in the hip roof tool. You can now generate hip roof directly from extruded top surface.
Ah, this is a welcomed change. :thumb:
GOHCH wrote:3) Improvement on setting up: no longer need to define path; as long as the 1001bit folder is located within Sketchup's plugins folder; it'll be fine.
Another good change. :thumb:
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Jun 14, 2009 2:40 pm
BTw, your FAQ seem to be broken. http://www.1001bit.com/faqs.html Only see the first three FAQ's.
User avatar
Global Moderator
License type: Pro
Postby thomthom » Sun Jun 14, 2009 2:42 pm
Ohh The Hip Roof even lets you select multiple faces now. Nice addition as well.
User avatar
Global Moderator
License type: Pro
Postby utiler » Sun Jun 14, 2009 11:54 pm
Hi GOH, the upgrade sounds great!!!!
For some reason, this update is not loading... i get this error...
Sorted now... :thumb: :thumb:
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Jun 15, 2009 7:12 am
utiler wrote:Hi GOH, the upgrade sounds great!!!!
I got the same error.
I had to completely remove 1001bit and reinstall it.
User avatar
Global Moderator
License type: Pro
Postby Burkhard » Mon Jun 15, 2009 10:41 am
If you have the language file in the 1001bit folder, make sure you have set the lines 39 into the main txt files like discribed in
http://www.1001bit.com/discussions/view ... 8&start=10
Should work then
User avatar
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Postby thomthom » Mon Jun 15, 2009 11:06 am
I've never installed any language files for 1001bit. Bog standard installation.
User avatar
Global Moderator
License type: Pro
Postby Burkhard » Mon Jun 15, 2009 11:16 am
Check 1oo1bit folder for the language folder. Take a look at 1oo1bitmenue.txt file if there are both lines included. (t and st 39 )
User avatar
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Jun 15, 2009 11:23 am
I can't check any more as I've completely reinstalled it.
But seeing that I've not done anything to the language files I'd say it's a bug in the upgrading process.
User avatar
Global Moderator
License type: Pro
Postby Pilou » Mon Jun 15, 2009 11:31 am
Sorry but where is the link to the new version 1.1.6? :oops:
All the links shown are for the translation or adding lines...but the new version?
Seems that will be the Duhduh of the day :mrgreen:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby thomthom » Mon Jun 15, 2009 11:34 am
It's a bit weird navigation on the site. It all seem to refer to trial versions, but it's all the same actually. http://www.1001bit.com/v1.1/download_re ... v1.1.shtml
User avatar
Global Moderator
License type: Pro
Postby Pilou » Mon Jun 15, 2009 12:07 pm
@Thomthom
So simple indeed :oops: THX :enlight:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby Pilou » Mon Jun 15, 2009 12:37 pm
Works really like a charm! :fro: (I have not error message) ;)
Infinite possibilities! :enlight:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby thomthom » Mon Jun 15, 2009 12:42 pm
Do shapes like that with a scale factor of 1.618 and can do some nice simulations of snail shells etc and other organic creations. :)
User avatar
Global Moderator
License type: Pro
Postby Pilou » Mon Jun 15, 2009 1:06 pm
And you can of course make some thickness with the Joint Push Pull of Fredo 6 ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby utiler » Mon Jun 15, 2009 11:52 pm
Awesome, Pilou!!! :sketchstatic:
And more for you, Goh!!!! :sketchstatic: :sketchstatic: :sketchstatic:
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby GOHCH » Tue Jun 16, 2009 1:17 am
Thanks guys :D
Pilou, i love that rendering, real cool! :thumb: :thumb: :thumb:
and thanks to the support and generosity of so many people; the language packs are ready too!
here's a list of them (i've bundled the language pack with 1001bit(v1.1.6) into a single zip file for easy setting up)
1001bit(v1.1.6) without language pack -->
http://www.1001bit.com/download/1001bit(1.1.6).zip
1001bit(v1.1.6) in French (thanks to Pilou :ecstatic: )-->
http://www.1001bit.com/language_pack/v1.1/fr/1001bit(v1.1.6)_fr_pilou.zip
1001bit(v1.1.6) in Chinese Simplified (thanks to Purplewind :ecstatic: ) -->
http://www.1001bit.com/language_pack/v1.1/cn/1001bit(v1.1.6)_cn_purplewind.zip
1001bit(v1.1.6) in Spanish (thanks to Oxer :ecstatic: )-->
http://www.1001bit.com/language_pack/v1.1/sp/1001bit(v1.1.6)_sp_oxer.zip
1001bit(v1.1.6) in German (thanks to Burkhard :ecstatic: )-->
http://www.1001bit.com/language_pack/v1.1/de/1001bit(v1.1.6)_de_burkhard.zip
There's a Chinese (Traditional) version coming soon...
Thanks everyone for your support!!! :D :D :D :D :D
GOHCH
Name: Goh Chun Hee
Postby purplewind » Tue Jun 16, 2009 3:14 am
Thanks again Goh, for this awesome toolset :berserk:
purplewind
Postby massimo » Tue Jun 16, 2009 2:12 pm
I've tried this toolset and after 10m i removed it. With 29$ you have a collection of plugins that you can get for free (and in many cases they work better) like align, Kt tools, trim and extend, fillet, roof, windowizer ecc. plus a duplicate of native SU commands like array, offset ecc. Maybe i missed something...
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby Pilou » Tue Jun 16, 2009 2:26 pm
you miss revolve, extrusion along a path,...etc and all pre-build parametrics elements ;)
+ images help inside ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby thomthom » Tue Jun 16, 2009 2:38 pm
Plus it's neatly packaged with a uniform UI and continuously maintained.
User avatar
Global Moderator
License type: Pro
Postby massimo » Tue Jun 16, 2009 2:52 pm
Ok, thanks. I'll give it another try.
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby GOHCH » Tue Jun 16, 2009 3:12 pm
hi everyone!
Thanks to Charles Tom of http://www.geoinfo.com.tw there's now a language pack for
1001bit tools in Chinese Traditional繁體中文 :sketchstatic: :sketchstatic: :sketchstatic:
http://www.1001bit.com/language_pack/v1.1/ct/1001bit(v1.1.6)_ct_geoinfo.zip
Thanks Charles for your support and sharing!:)
GOHCH
Name: Goh Chun Hee
Postby aadbuild » Tue Sep 15, 2009 6:44 am
1001 bit is definately a big time saver when modeling. I have done some great animations and client think they took me weeks where they only realy took hours. The rafters, battens and hips are fantastic
Andrew Dwight, NW Sydney Australia
aadbuild.com
Something different done in Sketchup take a look at shipping container transformation. animated in Sketchup
http://www.youtube.com/watch?v=9YxFuJYFgsY
aadbuild
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby GOHCH » Tue Sep 15, 2009 1:47 pm
Thanks aadbuild for your support!
Have been a bit tight on time working on a shadow analysis tool (in collaboration with Takeshi)
see http://www.1001shadows.com
Hope to get back to 1001bit tools by next month.
cheers!
Goh
GOHCH
Name: Goh Chun Hee
Postby CrackerJim » Tue Oct 27, 2009 8:27 pm
I've downloaded the 1001bit tools and also downloaded the help file from their forum. When I open it, it appears to open in a reader application. The table of contents appears on the left pane but regardless of what I click in the left pane, nothing but invalid address message appears in the reading pane.....
any suggestions?
Thanks for any help,
Jim
CrackerJim
Postby GOHCH » Fri Dec 25, 2009 4:40 am
:D :D :D Merry Christmas Everyone!!! :D :D :D
1001bit version 1.1.7 update is now ready for download!
http://www.1001bit.com/v1.1/download_registration_v1.1.shtml
3 new tools are added into this update:
Rectangular grille tools: convert edges into rectangular sections.
Circular grille tools: convert edges into circular sections.
both the grille tools only create grilles on a common plane defined by the first 3 points it finds from the selection.
any edges that are not on the plane will be projected onto the plane.
Extrude while maintaining tapering effect.
:D :D :D :D Wishing everyone a very Happy Christmas, and all the best in the coming year! :D :D :D :D
GOHCH
Name: Goh Chun Hee
Postby Gaieus » Fri Dec 25, 2009 10:17 am
Thanks Goh for the update! this whole toolset seems to be very useful not only for architects actually! :thumb:
I have also "updated" The Daily CatchUp.
_______
Also, if you don't mind, I have renamed the subject of the topic to
and moved it into our new Plugins forum. This seems to be more straightforward for this topic as it is a discussion between developer and users rather than about ruby methods (or what) between developers.
User avatar
Administrator
License type: Pro
SketchUp use: historical reconstruction
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: driven, Gipsking, glro, imranzabidin, jeanluc_16, Kossie, rastor and 5 guests
