[Plugin] #SelectionHideShow.rb v1.1
• Page 1 of 1
[Plugin] #SelectionHideShow.rb v1.1#SelectionHideShow.rb adds a context-menu sub-menu with various Selection, Hide and UnHide tools, such as 'Invert Selection', 'Hide/UnHide Selection', 'UnHide All Active' etc...
Edit: v1.1 Now tests with ".is_a?" to speed-up and avoids testing already unique groups[after AlexM's advice]. Please, register (free) to access all the attachments on the forums.
Re: [Plugin] #SelectionHideShow.rbVery practical!
Re: [Plugin] #SelectionHideShow.rbGreat!
I asked for this a while ago. I suggested it was something that should be a standard feature in SketchUp Now it is. Thanks for another great contribution. Regards Mr S =======
Re: [Plugin] #SelectionHideShow.rbThanks TIG. However I expected to see Reverse Faces in there too.
Re: [Plugin] #SelectionHideShow.rbThanks TIG, and I second the request made by Boofredlay.
erikB
Re: [Plugin] #SelectionHideShow.rbReverse and Orient faces is already built-in on the context-menu - near the top [as are some other 'select tools']... adding them would only duplicate stuff...
Re: [Plugin] #SelectionHideShow.rbTIG
These questions are linked at a speed of implementation of script on the large scenes.
It would be desirable to correct these shortages...
Re: [Plugin] #SelectionHideShow.rbAlex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
I'd rather use the faster method too, I just never knew there was a faster one. I'm sure TIG isn't using a slow method on purpose either... Chris
Easily to check... The more elements in the model - the better results script.
Re: [Plugin] #SelectionHideShow.rbThat's some interesting numbers. I've always used kind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
Thanks for posting this test. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] #SelectionHideShow.rb v1.1Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="".
I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! Here's v1.1 viewtopic.php?p=161963#p161963 Last edited by TIG on Thu Jun 04, 2009 11:58 am, edited 1 time in total.
Re: [Plugin] #SelectionHideShow.rb v1.1Maybe we could add this info to a new stickcy where we collect such useful tips and info?
For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte! _________________________ My model statistics:
P.S. It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
Re: [Plugin] #SelectionHideShow.rb v1.1Very good
Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence? http://www.ruby-doc.org/core/classes/Ob ... ml#M000370 Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] #SelectionHideShow.rb v1.1I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
AT - SpeedTest: is_a? - 0.89c kind_of? - 0.782c class - 0.875c typename - 2.297c Model Statistics: edges = 159630 faces = 61300 groups = 0 components = 1000 construction_lines = 0 construction_points = 0 images = 0 section_planes = 0 texts = 0 others = 0 Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] #SelectionHideShow.rb v1.1Much larger test. (did have a few programs open while I did the tests.)
AT - SpeedTest: is_a? - 16.297c kind_of? - 16.141c class - 18.703c typename - 88.703c Model Statistics: edges = 8396595 faces = 1026520 groups = 52643 components = 526428 construction_lines = 2 construction_points = 4 images = 0 section_planes = 0 texts = 0 others = 0 Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] #SelectionHideShow.rb v1.1a tool bar will be very great with this script
Re: [Plugin] #SelectionHideShow.rb v1.1i think i need this plugin
thank you in advance, sir.
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
• Page 1 of 1
