[Plugin] New Piping System Plugin
• Page 1 of 3 • 1, 2, 3
New Piping System PluginThis looks great!
I changed the subject of the post - I think more people may be intersted than the original subject suggests.
Re: New Piping System Pluginoh I love it already and my TARDIS Project loves you.
but is the activation server down?
Re: New Piping System Plugingreat plugin
Re: New Piping System PluginDear All,
What happens when you download the software? Do you get the usual plugins or is there an installer that places software elsewhere? I note that the 'free' offer is only until October 2009. How does that work? Does the installed software time out? I would hate to get used to using it and then find it carries a heavy price tag after October. Regards, Bob
Re: New Piping System PluginTheres an installer. It then activates through a little dialogue when you start up SU.
Im guessing there will be a charge for the plugin after october, i'd be interested to hear confirmation of this though (and how much it's likely to cost.)
Re: New Piping System PluginHi SHK, hi folks.
After playing with it for 10 minutes, I find this software interface quite nice and intuitive. However, I did not find these features or items (either they are missing or I did not found a way to access them): - Reducers are usually of given length according to the small diameter and large diameter. Actually, the software allows for any length. - Eccentric reducers are nor covered. this can be worked around since it is easy to move the outlet to align it to the inlet. - Tees branches can be any length. Normally, tees come with standardised branches length. - Laterals or Y are not offered. - Some other piping items are also not offered like flanges, blind flanges, caps, unions, miter bends, treaded fittings. socket weld fittings, grooved end fittings. Maybe be these will be offered as components at a later date. Added piping items are groups but they are not named. Adding a name to the groups that are being created by the software would be nice since they would appear in the outliner and would also give the possibilities of using the Report generation feature introduced in SU 7 to get a report that could act as a fairly good start to a bill of material. Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Re: New Piping System Pluginok ignore my question about the licencing server.. overactive firewall here...
Re: New Piping System PluginI can see some real potential with this plug-in. I have had a play with the pipe tool which is good but needs to go to the next level. I am thinking of a combination of this and the profile builder plug-in, now what an awesome combo that would be
Stan
Re: New Piping System Pluginthank you for all the positive feedback
We work hard on the release of 3skeng conceptual. It will have a lot more features and possibilities then 3skeng pipe free including some of the whishes above. We will consider your whishes and ideas and try to implement as much as possible in the comming release. Sebastian
Re: New Piping System PluginHi Sebastian, hi folks.
I tried to give you feeback at the address: feedback@3skeng.com that you give on your web site but it does'nt seem to work. So far I got 2 "mail delayed" messages. Keep up the good work you have what looks to be a very promising software. Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Re: New Piping System PluginVery interesting plugin,
but it seems I cannot download a Mac version? Let me know if I am doing something wrong or keep me posted as to when it will be available. aloha red
Re: New Piping System PluginFAbulous Pipeline maker
Re: New Piping System PluginHi Red, hi folks.
If you go to their web site, namely at the download page at: http://www.3skeng.com/download.htm you will see that the Mac version is coming soon. Just ideas. Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Re: New Piping System PluginI just install this one, but is not working here:
Error: #<FloatDomainError: Infinity> (eval):213:in `round' (eval):213:in `roundToSystemUnits' (eval):1546:in `getDiameter' (eval):2340:in `onMouseMove' Error: #<FloatDomainError: Infinity> (eval):213:in `round' (eval):213:in `roundToSystemUnits' (eval):1546:in `getDiameter' (eval):2340:in `onMouseMove' (eval):213 Any idea? Daniel S
Re: New Piping System PluginAwesome plugin! Very intuitive interface. I can't wait for the conceptual version. Keep up the good work!
![]() Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
Re: New Piping System PluginVery nice UI!!! I see Josef Leibinger authored the Ruby. Kudos to him as well.
Suggestions: 1- Allow input of a radius either through typing in a value followed by an "R" or input of math such as "1.235/2". 2- Option to simultaneously draw centerlines on a user defined layer. 3- Elbows and reducer. Reconstitute separate arc segments into true circle. 4- T's. If the diameter of both pipes are equal then the diameter endcap of the branching pipe shows through the pipe it is centered on due to "Z-fighting" in SU. An option to hide the edge of the this diameter or to put in it on a hidden layer would remedy this. 5- eccentric reducers. 6- Option to use pre-selected centerlines? I'm guessing this could be useful if using client supplied CAD drawing; not sure how it would be implement though 5- I agree with Jean Lemire about naming the groups. Last edited by JClements on Mon Jun 01, 2009 4:20 pm, edited 2 times in total.
John
Illustrator Beaverton, Oregon
Re: New Piping System Plugin....Many thanks to SHK (Sebastian Kummer?) and talent of Josef Leibinger!...Very useful!... PIPESOAPSKINBUBLE?
--pupil forever...------
Re: New Piping System PluginIn the video we can see a modification in "Real time" ,
a move of a grey pipe with automatic transformation That is possible because it's built with library components or it's possible with any pipes built with the plug? Please, register (free) to access all the attachments on the forums.
Re: New Piping System PluginThank you for your answers, suggestions and positive feedback. Yes, Josef Leibinger is part of our software team and he is dong a great Job.
We have very interesting functions (flex, editing...) on our roadmap. We are working hard to convert our prototypes into products "ready to publish".
Re: New Piping System PluginA short hint. If you have open the tutor and switch to the selection tool, the tutor appears everytime you try to orbit around with the mouse wheel.
Greetings to Josef... Burkhard
Re: New Piping System PluginThis plugin really simplifies pipes drawings. I agree J.LEMIRE about improvements which could be implemented.
Gut gemacht Leute, erste Klasse Arbeit. MALAISE La Connaissance n'a de valeur que partagée
Re: New Piping System PluginA couple more suggestions:
1- Choose to put group on a specific, predesignated layer, but keep extruded contents on Layer0. 2- Choice of the number segments for circles and arcs. I believe it currently defaults to 60 segments; this is impractical for any models with more than few pipes as it will surely creat files in the megabytes. Last edited by JClements on Mon Jun 01, 2009 4:18 pm, edited 3 times in total.
John
Re: New Piping System PluginToday we published the MAC version. We are very interested, how many of you are working with a MAC...
Best regards Sebastian
Re: New Piping System PluginHello,
I installed the Mac plugin and it is working well. Great system. I had a problem, though. When I first installed the plugin, I was happily making 2" round pipe as desired. After a bit, it changed to hexagonal profile pipe and I can't seem to get things back to round. There didn't seem to be any solution in the tutorial. How do you choose between the profile of the various pipes? R
Re: New Piping System PluginHi folks.
After installing the Mac plugin, SU 7 stop working. SU starts then exit immediately. I had to uninstall all and then reinstall all. I am using OS 10.4.11 (Tiger). Is this pluggin only for OS 10.5 (Leopard) ? I have to wait before trying a new install of this plugin. Just ideas. Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Re: New Piping System PluginI can't find the files this Plugin installed on my Mac. Either they are in some strange location or I don't know what the name of the files are. How do I uninstall these if I don't want it cluttering up my system?
I've looked in Library>Application Support>Google Sketchup 7>Sketchup>Plugins in both the Macintosh HD and User Directories without luck.
Re: New Piping System Plugincalled 3dskeng and has its own two button toolbar
Re: New Piping System PluginSebastian / Josef,
Great plug-in. Excellent user interface - very fast to use. A few suggestions / ideas / requests: 1. Ability to specify number of segments for circles (pipe profiles) (to help keep file sizes down). 2. Ability to have pipe sections, pipe junctions etc as COMPONENTS - or all geometry as COMPONENTS 3. Ability to NAME these Components (if user requires it). 4. Ability to automatically generate Centrelines for all geometry eg each pipe section - very useful for snapping / lining up / offsetting other geometry to. This centreline to go on its own layer eg "Centreline" 5. Ability to Specify "Pipes" of Square or Rectangular Cross Section. This plug-in could then be used to model other types of Ducts eg Ventilation Systems / Air-Conditioning Systems. 6. See the excellent Profile Builder Plug-in. If you have centrelines you will be able to generate total LENGTHS for each Pipe section. From the pipe profile (area) you can then calculate VOLUME of each Pipe Section. Some type of Reporting function that will generate Lengths, Volumes and Totals for each Pipe Section (Named Components). These Reporting out type functions / code already exist in several other Plug-ins eg by TIG, Jim Foltz and others. ........... Just a thought... Potentially both The Profile Builder and your Piping System Plug-in Compliment each other very well. Maybe you should Team Up with Dale Martens who created The Profile Builder plug-in so that you can have the best of both worlds ??? You could use Dale's Profile Builder so that you can use any profile / cross-section you want to - but they would be modelled in a very simple and intuitive way using your superb drawing engine / user interface ??? A marriage made in su heaven ??? !!! ........... Keep up the good work on this fantastic plug-in. Regards Howard L'
SketchUcation One-Liner AdvertsNeed Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
