by Matt666 » Tue Feb 17, 2009 6:08 pm
Hi all! This plugin can recall last tool used. Based on this request. You can use native Sketchup Shortcut function to add a new shortcut. I use F2!  All suggestions are welcomed!! [EDIT1] This plugin is not compatible with Mac. Sorry. See below if you want to know why. A SU bug for Mac users. [EDIT2] v1.2 -> 09/04/2009 : Observer was not always activated before using tool. Thank you Simon Le Bon!
Matt666
- Name: Matt
by jmmad » Tue Feb 17, 2009 6:12 pm
Thxs Matt works great with Key shortcuts
Get Upa !
jmmad
by RickW » Tue Feb 17, 2009 7:34 pm
Matt, Nice work. My suggestion would be to use class variables (@@Matt_Model_Toolid, @@Matt_Model_Toolid2) or instance variables (@Matt_Model_Toolid, @Matt_Model_Toolid2) rather than global variables. Note that class variables must be declared right after the class is declared: - Code: Select all
class Matt_Observer < Sketchup::ToolsObserver @@Matt_Model_Toolid = nil @@Matt_Model_Toolid2 = nil def onActiveToolChanged (tools_object, toolname, toolid) # ETC...
but instance variables can be delcared anywhere in the class methods.
RickW
- Name: Rick Wilson
by Matt666 » Tue Feb 17, 2009 10:42 pm
Hi Rick! Thank you for the comment, I've updated the code...
Matt666
- Name: Matt
by EarthMover » Thu Feb 19, 2009 2:27 am
Hey Matt - You are eternally my friend! Thanks for listening to my request. I'm sure it will be useful to many!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller Some of my 3D crap
EarthMover
- Top SketchUcator
- Name: Adam Hails
by Matt666 » Thu Feb 19, 2009 7:46 am
Matt666
- Name: Matt
by Pilou » Wed Feb 25, 2009 12:27 pm
Astucieux!
Pilou
- Top SketchUcator
- Operating system: Windows
- SketchUp version: 6
- License type: Free
- SketchUp use: hobby
- Level of SketchUp: Advanced
by Matt666 » Wed Feb 25, 2009 2:40 pm
Merci Pilou
Matt666
- Name: Matt
by Edson » Wed Feb 25, 2009 3:43 pm
matt,
here we go again. unless i do not know how to use your new script, it is not working on mac! sorry...
edson mahfuz, architecthttp://www.mahfuz.arq.brAnyone can get you more for more, but it takes genius to get you more for less.
Edson
- Global Moderator
- Name: Edson Mahfuz
- Operating system: Mac
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
by Matt666 » Wed Feb 25, 2009 4:55 pm
Hi Edson... I hope you do not know!! I'm cursed... So : Draw a  . Draw a  . Press space bar for  . Go to Plugins/Recall last tool. Rectangle tool is now recalled. If it does not work, can you open your ruby console, and try again, please? And, at last, can you call rectangle tool, and try to copy this code in the ruby console ? - Code: Select all
Sketchup.send_action(21022)
This code calls selection tool. Thank you Edson. And sorry for the inconvenience.
Matt666
- Name: Matt
by Edson » Wed Feb 25, 2009 5:27 pm
matt,
it did not work. i had done it that way before. below is the ruby console reading.
glad to help you. keep your requests coming.
Please, register (free) to access all the attachments on the forums. edson mahfuz, architecthttp://www.mahfuz.arq.brAnyone can get you more for more, but it takes genius to get you more for less.
Edson
- Global Moderator
- License type: Pro
by pecan » Wed Feb 25, 2009 10:18 pm
Matt666 wrote:Hi Edson... I hope you do not know!! I'm cursed... - Code: Select all
On differenct OS's, even the same OS with different menus, that magic number will have changed. What's wrong with Sketchup.send_action(selectSelectionTool:); When the menu structure is updated, then the call will still work even tho the menu id has changed.
pecan
by simon le bon » Wed Feb 25, 2009 11:32 pm
Bravo Matt !! at the very beginning of my learning SketchUp, I was surprised not to have this feature at disposal. And then I was accustomed to always recall my tools. And Here comes your ruby. It is as if suddenly we had won a great lightness. (F2 is great) it already belongs to my toolbox.  simon
simon le bon
- Name: Simon Bonnet
by Matt666 » Thu Feb 26, 2009 8:19 am
Merci Simon ! pecan wrote:On different OS's, even the same OS with different menus, that magic number will have changed.
Hi pecan! Are you sure of that? I use only two different numbers in my code. The rest is a recall of the last number used. But there's a biiig problem with Mac... On Mac, function "send_action" does not accept integers. Only strings! Edson wrote:It did not work. i had done it that way before. below is the ruby console reading.
Thank you Edson! Ouch. I will try to find a solution. Can you test this code below, please? - Code: Select all
Sketchup.send_action("21022")
Matt666
- Name: Matt
by Edson » Thu Feb 26, 2009 12:23 pm
it looks good!
Edson
- Global Moderator
- License type: Pro
by Matt666 » Thu Feb 26, 2009 12:39 pm
Ok. But if you have rectangle tool called, when you copy and validate the code, is the selection tool activated?
Matt666
- Name: Matt
by Edson » Thu Feb 26, 2009 12:58 pm
i drew a rectangle, then pressed the space bar, then used the script from the menu. the result is in the picture.
Edson
- Global Moderator
- License type: Pro
by Matt666 » Thu Feb 26, 2009 1:58 pm
Sorry Edson, and all mac users. But I can't do anything with this bug.  Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
Matt666
- Name: Matt
by pecan » Thu Feb 26, 2009 7:12 pm
Result from SU ruby console
(eval) result = Sketchup.send_action "selectSelectionTool:" true
I was in error suggesting it was a num.
pecan
by pecan » Thu Feb 26, 2009 7:37 pm
Using the tool name should work: - Code: Select all
def onActiveToolChanged (tools_object, toolname, toolid) print tools_object, toolname, toolid @@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2 #@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid) @@Matt_Model_Toolid2 = "select#{toolname}:"; puts "1: #{@@Matt_Model_Toolid} 2: #{@@Matt_Model_Toolid2}" end
pecan
by pecan » Thu Feb 26, 2009 7:45 pm
pecan wrote:Using the tool name should work: - Code: Select all
Well... almost. "selectCameraOrbitTool:" doesnt work. It's action name is simply OrbitTool. So maybe a hash of returned tool names and the send_action name. sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc. Or maybe a hash of just the exceptions. Its a shame SU has to be so inconsistent.
pecan
by pecan » Thu Feb 26, 2009 8:25 pm
Here's a list of the send_actions and the actual tool name returned by the observer. - Code: Select all
howRubyPanel: viewBack: viewBottom: viewFront: viewIso: viewLeft: viewRight: viewTop: viewPerspective: viewShowAxes: viewShowHidden: viewZoomExtents: viewZoomToSelection: viewUndo: selectOrbitTool: (CameraOrbitTool) ok selectPositionCameraTool: selectDollyTool: (CameraDollyTool selectTurnTool: selectWalkTool: (CameraWalkTool) selectZoomTool: (CameraZoomTool) selectFieldOfViewTool: (CameraFOVTool) <=== inconsistency selectZoomWindowTool: (CameraZoomWindowTool) pageAdd: pageDelete: pageUpdate: pageNext: pagePrevious: renderWireframe: renderHiddenLine: renderMonochrome: renderShaded: renderTextures: ok selectArcTool: selectAxisTool: (SketchCSTool) ok selectCircleTool: ok selectEraseTool: ok selectFreehandTool: selectLineTool: (SketchTool) ok selectMeasureTool: ok selectMoveTool: ok selectOffsetTool: ok selectPaintTool: selectPolygonTool: (PolyTool) ok selectProtractorTool: ok selectPushPullTool: ok selectRectangleTool: ok selectRotateTool: ok selectScaleTool: ok selectSectionPlaneTool: ok selectTextTool: ok selectDimensionTool: ok selectExtrudeTool: ok selectSelectionTool: editUndo: editRedo: editHide: editUnhide: fixNonPlanarFaces:
axes is returning SketchCSTool 3d text is returning 3DTextTool plugins return RubyTool orbit return CameraOrbitTool pan returns CameraDollyTool zoom returns CameraZoomTool field of view returns CameraFDVTool zoom window returns CameraFOVTool zoom extends return CameraZoomWindowTool walk return CamerWalkTool look returns CameraPanTool line returns selectSketchTool
Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select". Special cases are PolyTool, Line tool, and axis tool. On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
pecan
by pecan » Thu Feb 26, 2009 8:59 pm
The following seems to work, and you can add to the exceptions hash when you find 'em. Hope this helps some... - Code: Select all
# Supports Organizer.rb =begin Copyright 2009, Matt All Rights Reserved
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
License: Free
Author: Matthieu NOBLET Organization: Matt Name: Recall_lst_tool Version: 1.0 SU Version: 6 and 7 Date: 17/02/2009 Description: Recall last tool used Usage: If you want to have a shortcut, please try with native Sketchup shortcuts... History: 1.000 17/02/2009 First version
1.100 17/02/2009 Global variables replaced by Class variables =end
require 'sketchup.rb'
class Matt_Observer < Sketchup::ToolsObserver def initialize @ToolExceptionsHash = { # observerName send_actionName "FOVTool", "FieldOfViewTool", "SketchCSTool", "AxisTool", "SketchTool", "LineTool", "PolyTool", "PolygonTool" } end @@Matt_Model_Toolid = nil @@Matt_Model_Toolid2 = nil def onActiveToolChanged (tools_object, toolname, toolid) print tools_object, " ", toolname, " ", toolid, "\n" tname = toolname; @@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2 # remove "Camera" prefix reported by ToolObserver" @@Matt_Model_Toolid2 = (tname[0,6]="" if (tname[0,6] == "Camera")); tname = @ToolExceptionsHash.fetch(tname, tname); @@Matt_Model_Toolid2 = "select#{tname}:"; puts "1: #{@@Matt_Model_Toolid} 2: #{@@Matt_Model_Toolid2}" end def self.recall_last puts "sending action #{@@Matt_Model_Toolid}" if @@Matt_Model_Toolid return Sketchup.send_action(@@Matt_Model_Toolid) if @@Matt_Model_Toolid return Sketchup.send_action("selectSelectionTool:") end end
unless file_loaded?(__FILE__) file_loaded(__FILE__) Sketchup.active_model.tools.add_observer(Matt_Observer.new) $submenu ? (organizer = $submenu) : (organizer = UI.menu("Plugins")) organizer.add_item("Recall last tool"){ Matt_Observer.recall_last } end
pecan
by Matt666 » Fri Feb 27, 2009 6:00 pm
Hi pecan! Sorry, I didn"t test your plugin, but I think it doesn't work with plugins. So Non native tools... I will test it! Thank you for that Pecan!
Matt666
- Name: Matt
by Matt666 » Thu Apr 09, 2009 10:12 am
Hi Pecan! Your method does not work with ruby tools, as expected... A new version has been posted in the first post. It fixes a bug found by Simon Le Bon. Thank you Simon!
Matt666
- Name: Matt
by simon le bon » Thu Apr 09, 2009 1:26 pm
Hi Matt, Hip Hip! I've just installed your plug v 1.2 and it seems working very well (all tools are seemingly supported)! So cool!! It's too young to see if it remain operative on duration, but i believe this is now fixed. Many thanks for that tool dear Matt I take it!  simon.
simon le bon
by Edson » Thu Apr 09, 2009 1:40 pm
Matt666 wrote:Sorry Edson, and all mac users. But I can't do anything with this bug.  Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
would the last update make it usable in macs?
Edson
- Global Moderator
- License type: Pro
by Matt666 » Thu Apr 09, 2009 5:19 pm
I take it! would the last update make it usable in macs?
... Dear Edson... I'm so sorry!  You (and all Mac users!)have some problems with many of my scripts... Included this one... I can't be usable in mac. Mac has a bug with main function used in this script: Sketchup.send_action(ToolID). And I can't do anything. Sorry again Edson...
Matt666
- Name: Matt
by Edson » Thu Apr 09, 2009 6:24 pm
matt,
no problem. several other plugins you created work without problems. let's hope this bug gets solved in the future.
Edson
- Global Moderator
- License type: Pro
Return to Plugins
