[Plugin] FredoScale - v3.1a - 18 Dec 18
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)
Postby thomthom » Sun Mar 29, 2009 11:11 am
Jeff Hammond wrote:Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
This he truly deserves!
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Sun Mar 29, 2009 11:44 am
And then after use Fredo's bend, clean selection can be useful for lighten the object ;)
clean selection by architectboy or cleanup_model.rb by J.H. Aughey :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby sepo » Sun Mar 29, 2009 11:51 am
clean selection?
sepo
Postby pilou » Sun Mar 29, 2009 11:56 am
clean selection?
Yes clean selection by architectboy or cleanup_model.rb by J.H. Aughey :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby sepo » Sun Mar 29, 2009 12:07 pm
aha :) I see what you mean.
Awesome plugin Fredo. Thank you very much. :thumb: :thumb:
sepo
Postby pep75 » Sun Mar 29, 2009 12:21 pm
:D :D :D :D
GOOGLE SHOULD THANK PEOPLE LIKE YOU! This plugin is exactly what SU needed in the 7th version but they didn't see it. You're brilliant. THNX!!!
User avatar
pep75
Postby CadFather » Sun Mar 29, 2009 1:07 pm
Master SuperFredo has done it again! :shock: :enlight:
..it's a pleasure just to admire the genius!
(hope google is listening)
Thank You Fredo.
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby ilay7k » Sun Mar 29, 2009 1:45 pm
Thank you! :ecstatic:
ilay7k
Postby Marian » Sun Mar 29, 2009 2:02 pm
THANK YOU VERY VERY MUCH, thess tools were diarely needed in SU.
Cheers.
User avatar
Marian
Postby Gaieus » Sun Mar 29, 2009 2:08 pm
This is again one of the greatest plugins, Fredo! There are so many of "one of the greates plugins" by you now that the expression is getting inflated however. ;)
Thanks a bunch! :fecstatic:
User avatar
Postby Gjenio » Sun Mar 29, 2009 2:34 pm
Your scripts are just incredible!
Thank you Fredo
You are great
Gjenio
Postby torben.wadlinger » Sun Mar 29, 2009 2:51 pm
I say "Wooooooaaaaaaaahhh!"
Google, be ashamed!
Great job, man. Great job!
Torben
torben.wadlinger
Postby kwistenbiebel » Sun Mar 29, 2009 3:52 pm
A one man development team. Wonderful!
Google, shame on you +1
kwistenbiebel
Postby boofredlay » Sun Mar 29, 2009 3:52 pm
Fredo6 wrote:
You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
To activate the slicer and divider, you also have the contextual menus.
Got it, thank you very much for the response, and the plugin.
User avatar
boofredlay
Global Moderator
Postby wrecknball » Sun Mar 29, 2009 4:23 pm
Wow! Just had my first cup of coffee and thought I would check to see about the "Bend" plugin. It's like christmas morning. Thanks sooooo much Fredo!
I will give it a try and post some results. Thanks again.
wrecknball
Postby notareal » Sun Mar 29, 2009 4:27 pm
:sketchstatic: Thank you. This is like Christmas!
notareal
Thea Render Support
Thea Render Support
Postby broomstick » Sun Mar 29, 2009 4:39 pm
this
is
utterly
AWESOME!
You are doing an incredible job. Thank you so much!
User avatar
broomstick
Postby solo » Sun Mar 29, 2009 4:44 pm
Scripters like you are what gives the 'UP' in Sketchup. Thanks a ton for all you hard work and thoughtful rubies.
User avatar
Global Moderator
Postby ken » Sun Mar 29, 2009 5:10 pm
Thank you Fredo6
However, I seem to be the only one with this problem. The below jpg shows the error I recieve. I have removed the old version, still get the same error.
Help
Again thank you.
Ken
User avatar
ken
Premium Member
Premium Member
Postby Dave R » Sun Mar 29, 2009 5:22 pm
Ken, did you install LibFredo6 version 3.1? It is linked to in the first post of the thread.
User avatar
Global Moderator
Postby thomthom » Sun Mar 29, 2009 5:43 pm
Is it possible to specify the number of slices it does when bending?
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Sun Mar 29, 2009 5:44 pm
Dave R wrote:Ken, did you install LibFredo6 version 3.1? It is linked to in the first post of the thread.
I think he does. He said he deleted the old version. But I suspect here is that Vista keeps a copy of the old version somewhere. I think I've heard of issues like that. Though I've never experienced it myself, I wonder if it happens when UAC is on...
User avatar
PluginStore Author
PluginStore Author
Postby remus » Sun Mar 29, 2009 5:47 pm
thomthom wrote:Is it possible to specify the number of slices it does when bending?
Yep, press tab when youve got the bend tool selected and change the top number, 20's usually pretty good, although you can go up to 60 if you need to.
remus
Postby ken » Sun Mar 29, 2009 6:06 pm
Yes, I did install LibFredo6 version 3.1. However, I didn't remove all of the old program, I just renamed the directories until I was sure this version would work.
Now, however, I did remove all of the old directories, I now have this error.
Working my way to total victory.
Thanks for the replies
Ken
User avatar
ken
Premium Member
Premium Member
Postby farukahmet » Sun Mar 29, 2009 6:10 pm
This is just.. just... i mean... :shock: :shock: :shock:
farukahmet
Postby free agent » Sun Mar 29, 2009 6:25 pm
you are a genius, i use your rubies daily and would have dropped sketchup a while ago if it wasnt for such awsome scripts, thank you.
a small request, could cadfather do your icons again, i liked his work with "Tools on Surface" and "BZ_Toolbar"... no offence
Google tisk tisk
User avatar
free agent
Postby fredo6 » Sun Mar 29, 2009 6:32 pm
Ken
Ken,
Do not remove or rename anything. Just install the Library LibFredo6 3.1 and FreeScale 2.0, as indicated.
Then, if it works, you may want to remove the folders LIBFREDO6_Dir_30 and FREESCALE_Dir_10, but it does not really matter you do it right away, as they will never be loaded.
User avatar
PluginStore Author
PluginStore Author
Postby wolfy » Sun Mar 29, 2009 7:04 pm
Fredo, you are truly amazing!! :enlight: Thanks so much for all your hard work, dedication and generosity!!!
wolfy
Postby otb designworks » Sun Mar 29, 2009 7:14 pm
awesome awesome awesome!!!
Fredo, if it wasn't for you, I think I would have left SU in my dust ages ago.
Just simply fantastic and thank you!!
Cheers, Chuck
OTB Designworks is on Youtube
otb designworks
Postby ely862me » Sun Mar 29, 2009 7:18 pm
This is
Well done....i m still wondering what is sketchup going to become with such smart people like Fredo..
Thanks a lot!
Elisei
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
User avatar
ely862me
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], CaptainProg, lucabattagliniarchitetto, mynameismisterw, Redmerski and 10 guests
Visit our sponsors:
