General discussion related to SketchUp Pro and Make
by david_h » Fri Mar 13, 2009 3:39 pm
Try it for Polar Arrays . . .it's loads of fun! But. . .Im sure you knew that!
If I make it look easy. . .then it probably is.
david_h
- Top SketchUcator
- Name: David_H
by •BTM » Sat Mar 14, 2009 12:38 am
A new "D'uh" for me: holding shift while using the smoove tool: smooves from normals. wow....jpg
•BTM
- PluginStore Author
- Name: •BTM
by thomthom » Sat Mar 14, 2009 10:38 am
•BTM wrote:A new "D'uh" for me: holding shift while using the smoove tool: smooves from normals.
What??? Duh!!!
- Name: Thomas Thomassen
- Operating system: Windows
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Advanced
by Rodentpete » Sat Mar 14, 2009 1:41 pm
Damn!! This has to be the most useful 'Duh!' in the thread - is this documented anywhere?!
Rodentpete
by remus » Sat Mar 14, 2009 2:00 pm
The Manual wrote:You can sculpt in a direction other than vertical by holding down the Shift key while moving the mouse. However, this operation can result in a non-functional terrain or terrain that can no longer be manipulated in a known way. This operation can only be performed while in active selection (not after preselection).
remus
- Name: remus
by pilou » Sat Mar 14, 2009 3:39 pm
False Duhduh!  Oh!  A manual is existing?  PS You don't need especially a manual : Just Look at the line help Page Bottom! It's Write... Line help is an another false Duhduh! falseduh.jpg
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
by •BTM » Sun Mar 15, 2009 2:02 am
Mine didn't say that.
•BTM
- Name: •BTM
by pilou » Sun Mar 15, 2009 2:45 am
@BTM: As shown on the green image above
- Top SketchUcator
- Name: Pilou
by sepo » Sun Mar 15, 2009 1:40 pm
[/quote]Being able to put in "s5" in the VCB to control the number of sides before I create a circle or arc... Big Duh![/quote] It does not work for me. As soon I type s it triggers scale tool. Btw If you call arc or circle vcb gives you option to type in number of segments.
sepo
- Name: sepo
- SketchUp version: 2013
- License type: Pro
- SketchUp use: architecture
by solo » Sun Mar 15, 2009 1:48 pm
try 5s.
- Global Moderator
- Name: Pete Stoppel
- License type: Pro
- Level of SketchUp: Intermediate
by sepo » Sun Mar 15, 2009 2:18 pm
But what is the point as vcb gives you option for number of sides as soon as you select arc or circle.
sepo
- Name: sepo
- License type: Pro
by solo » Sun Mar 15, 2009 2:21 pm
I dunno, I use the model info options to alter my segments anyway.
- Global Moderator
- License type: Pro
by pilou » Wed Mar 18, 2009 6:36 pm
- Top SketchUcator
- Name: Pilou
by Gaieus » Wed Mar 18, 2009 6:49 pm
Duh... I've never noticed you can collapse that Entity info box (mine is always expanded). Well, still better than the other way around.
- Name: Csaba Pozsárkó
- License type: Pro
- SketchUp use: historical reconstruction
by pilou » Sat Mar 21, 2009 6:11 pm
My Duhduh of the day! No exactly for SU but As make a "snapshot" of a video is impossible You can Save "as an image" when you make pause inside the viewer! So I have need this today for this crazy teaser of Fredo6 and his new Bend Function!  bend.jpg (click image if scrallbars)
- Top SketchUcator
- Name: Pilou
by Ecuadorian » Sat Mar 21, 2009 8:55 pm
Pause inside the viewer? What viewer?
Ecuadorian
- Name: Miguel
- License type: Pro
by pilou » Sat Mar 21, 2009 11:46 pm
Pause is normally existing in any viewer  Windows, Mpc, Quick Time etc... But the crazy thing is I had never thought to use it before today with the "Print Screen" key Because when you use the "Print Screen" key during an animation you have nothing as image!
- Top SketchUcator
- Name: Pilou
by Ecuadorian » Sun Mar 22, 2009 1:21 am
Depends on the mode you're using. If you're using hardware acceleration in whatever media player you use, you won't be able to make captures by just pressing "print screen". I recommend using the VLC player, it features screen capture and opens most formats.
Ecuadorian
- Name: Miguel
- License type: Pro
by jeff hammond » Tue Mar 24, 2009 9:28 pm
i'm not sure this qualifies as a 'duh' moment because it's actually an application duh.. when i finally figured out this workaround though, it was a big relief..
it has to do with dividing arc/circles into a certain amount of segments.. say you need 16 segments in an arc.. sketchup may let you change the amount so you think you're good to go.. later in the model, you might need another arc with the same amount of segments but this time, sketchup won't let you change it to the same amount..
the workaround is this: change the amount to 1 higher than you need (17 instead of 16 for instance) THen change that arc to 16..
i have no idea why SU won't just let me divide into the proper amounts in the first place and i previously had some headache workarounds to deal with this..
- Global Moderator
- Name: Jeff Hammond
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
by pilou » Tue Mar 24, 2009 10:11 pm
cool to know that! ovoid some circular headaches
- Top SketchUcator
- Name: Pilou
by david_h » Fri Mar 27, 2009 8:44 pm
Gaieus wrote:How about creating only "dummy" or "proxy" components?
So what is the best method for Proxy-ing? To create a 2 layers of different components and toggle each one in a scene or is it to reload and displace the proxy via "RELOAD" when it comes time to render? Just Curious since I am dealing with that issue as we speak. David_H
david_h
- Top SketchUcator
- Name: David_H
by free agent » Fri Mar 27, 2009 9:18 pm
paulside wrote:Come on, Own up, how many of us have tried to orbit a jpg !
jeez ive tried to orbit word documents
free agent
- Name: Free Agent
by Gaieus » Sat Mar 28, 2009 2:19 pm
David_H wrote:...So what is the best method for Proxy-ing? To create a 2 layers of different components and toggle each one in a scene or is it to reload and displace the proxy via "RELOAD" when it comes time to render?
Well, I don't think there's a general and always "true" answer to that. It would definitely depend on the particular model, the purpose, the workflow, even additional software (like renderers that can use SU proxies and instancing) etc.
- License type: Pro
by david_h » Sat Mar 28, 2009 7:07 pm
That's what I was a-feared of. You know . .. of all the answers to life's questions. . . "well, that depends" has to be the least satisfying of them all. Thanx for the response anyway. so what is the most satisfying?
david_h
- Top SketchUcator
- Name: David_H
by Gaieus » Sat Mar 28, 2009 7:13 pm
Okay, I'll make a couple of short examples (but then I'll also split these posts off here and combine them with that). Is that okay? The best would be of course, if others could also add some examples from their field of profession and workflow.
- License type: Pro
by Tekkybot » Tue Mar 31, 2009 1:53 pm
ah, heres some of my best duh moments. learning how to use groups/componenets, understanding the outliner, learning to use xray when after using follow me to clean up a curved model, and my fav duh so far, (this one stumpped me for months!) drawing on top of shapes with the pencil tool when things are made into groups/components to make model building easier and more precise.
Tekkybot
by pilou » Wed Apr 08, 2009 4:47 pm
A vicious one!  By the complicity of John H. Aughey & Wiiki Solution ! Used first Erase Inner faces !
- Top SketchUcator
- Name: Pilou
by thomthom » Sat Apr 11, 2009 11:23 am
Because you have internal faces which uses those edges?
- License type: Pro
by pilou » Sat Apr 11, 2009 11:33 am
This arrives when you make PushPull + CTRL  But you must clean after so...Duhduh above! push.jpg
- Top SketchUcator
- Name: Pilou
by pilou » Wed Apr 15, 2009 2:26 am
Another one: after a Catmull Clark Subdivision  impossible.jpg An headache for orient faces all in the same color Solution one click!: Same than above! Plugin Remove Inner faces then Right Click / Plugin "Orient Face" on a White face
- Top SketchUcator
- Name: Pilou
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to SketchUp Pro & Make Discussions
