SketchUcation Premium Membership
New API doc - typos and questions
Postby thomthom » Thu Feb 26, 2009 8:11 pm
I'm looking at the new API docs and I noted an inconsistency in the documentation. I thought we might collect them here as they're discovered and hopefully we'll see them addressed.
The example for Set.include? http://code.google.com/apis/sketchup/do ... ml#include? uses a different method name:
Code: Select all
status = set.contains? object
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: New API doc - typos and questions
Postby thomthom » Thu Feb 26, 2009 8:21 pm
Vector3d.linear_combination
http://code.google.com/apis/sketchup/do ... ombination
In addition to the 4-argument form detailed here, you may also call this method with 6 parameters in the form of:
Arguments:
weight1 - A weight or percentage.
vector1 - The first vector.
weight2 - A weight or percentage.
vector2 - The end point of the line.
What's the two extra arguments?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Thu Feb 26, 2009 9:09 pm
Jim just pointed out this method and I noticed its missing:
Code: Select all
Face.get_glued_instances
Last edited by Chris Fullmer on Fri Feb 27, 2009 12:05 am, edited 1 time in total.
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby avariant » Thu Feb 26, 2009 11:22 pm
I'm pretty certain the material observer is completely wrong. The base class defines all but two methods incorrectly, and doesn't appear to use them all that correctly either.
avariant
SketchUp version: 8
License type: Free
SketchUp use: other
Level of SketchUp: Intermediate
Postby ScottLininger » Thu Feb 26, 2009 11:31 pm
Hello everyone,
Yes, we just launched some new docs for the Ruby API on the code site. These are the most accurate and up to date documentation we have ever had, and we hope that they are useful. (That being said, there is obviously still room for improvement.)
Your help in finding typos/missing details are very welcome! What isn't evident just from glancing at the site is that we have a new process internally for maintaining and updating the docs that will help us be more responsive to changes from here on out. (ThomThom, I've already pulled in your questions/corrections and will be pushing them out soon.)
By the way, HUGE thanks must be given to the people who worked on the wiki-enabled docs over the last couple of years. We integrated those community changes, and I'm currently doing a review to make sure that any changes from the last couple months are reflected in the new docs. Thank you! (The wiki docs are still up for now, and I will continue to monitor them for fixes.)
Keep the corrections coming!
- Scott Lininger
SketchUp Software Engineer
Have you visited the Ruby API Docs?
User avatar
ScottLininger
SketchUp Team
Postby ScottLininger » Fri Feb 27, 2009 12:31 am
Chris Fullmer wrote:Jim just pointed out this method and I noticed its missing:
Code: Select all
Hey Chris (or Jim),
I don't think that's a standard method... (am I wrong?) I went to go add it to the docs, but I can't find it. Maybe it's part of some script out there?
Let me know, :)
- Scott Lininger
User avatar
ScottLininger
SketchUp Team
Postby Chris Fullmer » Fri Feb 27, 2009 12:37 am
Scott, I have question. This is coming from me, and I have little understanding of this documentation stuff. But is the SU Ruby code documented in a similar way to rDoc or something? Is it set up so that you guys can change the documentation, then run some rDoc like command on it and it automatically updates the website? Does that make sense?
Also, I like the tag that shows what version of SU each method is compatible with :)
Last edited by Chris Fullmer on Fri Feb 27, 2009 12:58 am, edited 1 time in total.
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby remus » Fri Feb 27, 2009 12:43 am
[ruby newb]i thought the face.get_glued_instances method was added with the latest M1 release?[/ruby newb]
remus
Postby ScottLininger » Fri Feb 27, 2009 12:57 am
Chris Fullmer wrote:But is the SU Ruby code documented in a similar way to rDoc or something? Is it set up so that you guys can change the documentation, then run some rDoc like command on it and it automatically updates the website?
Yes.
We now generate the docs directly from source code comments, using something like rdoc. So we make a change to the source. It gets code reviewed and checked in. Then we push a button and it all goes onto the new site.
So... there are likely some "autogeneration" bugs that we will all discover over the coming weeks. Not to mention plain old human error. Which, by the way, is why the get_glued_instances method isn't up there. Remus is right, that was added with M1 and I am a bonehead. Fix coming! ;)
Thx,
- Scott Lininger
User avatar
ScottLininger
SketchUp Team
Postby ScottLininger » Fri Feb 27, 2009 1:11 am
avariant wrote:I'm pretty certain the material observer is completely wrong. The base class defines all but two methods incorrectly, and doesn't appear to use them all that correctly either.
Attached script demonstrates using the MaterialsObserver as documented. The base class may not have all of the methods correctly implemented, but SketchUp will call them.
As the docs say, the onMaterialRemoveAll does not fire in a particularly useful way.
Let me know if you find anything else! Thanks!
- Scott Lininger
User avatar
ScottLininger
SketchUp Team
Postby avariant » Fri Feb 27, 2009 2:03 am
I guess my blanket comments about the MaterialObserver were not entirely accurate ;) I was under the impression that unless some of the methods weren't explicitly implemented in the observer, SU would crash when it attempted to call the method since it's not implemented on the base. However, I seem to be wrong. :oops:
The documentation on onMaterialChange is a little inadequate. It says it is called whenever a material is altered, but it doesn't get called when you change size or color, just texture.
avariant
SketchUp version: 8
License type: Free
SketchUp use: other
Postby Jim » Fri Feb 27, 2009 3:00 am
Code: Select all
Hey Chris (or Jim),
Let me know, :)
Scott, I got the information from the Release Notes page.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Fri Feb 27, 2009 9:16 am
Noticed in another thread that there seem to be some deviation related to send_action. viewtopic.php?f=180&t=16751&start=15#p135201
"selectCameraOrbitTool:" doesnt work.
It's action name is simply OrbitTool.
Seems to be a couple more as well.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Todd Burch » Fri Feb 27, 2009 1:31 pm
ScottLininger wrote:Hello everyone,
Thanks Scott!
Todd Burch
Postby thomthom » Fri Feb 27, 2009 2:39 pm
Under the UI Classes section:
Tool, Toolbar and Webdialog all links to the Array class: http://code.google.com/apis/sketchup/do ... array.html
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby ScottLininger » Sat Feb 28, 2009 7:17 am
A bunch of fixes got pushed on Friday. Thanks again to folks who found typos, both from this thread and from the wiki documentation. Keep 'em coming!
I'm on vacation for the next week, so don't think I'm ignoring anyone if I don't reply for a few days. Thanks, guys!
- Scott Lininger
User avatar
ScottLininger
SketchUp Team
Postby thomthom » Sun Mar 01, 2009 10:39 am
Thanks Scott.
I'm still puzzled about the six arguments for Vector3d.linear_combination.
Code: Select all
vec = Geom::Vector3d.linear_combination(x, xaxis, y, yaxis, z, zaxis)
How does this really work?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Sun Mar 01, 2009 5:45 pm
Not to mention that the example at the bottom of the method does not actually include the method of linear combination. It only shows:
Code: Select all
 vector1 = Geom::Vector3d.new 1,0,0
 vector2 = Geom::Vector3d.new 0,1,0
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Sun Mar 01, 2009 10:02 pm
PolygonMesh.add_polygon
The example shows how to use the add_point method.
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Mar 01, 2009 10:09 pm
Wish we had red pens to scribble on the docs. :D
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jim » Sun Mar 01, 2009 10:36 pm
thomthom wrote:Wish we had red pens to scribble on the docs. :D
Great idea, really. I'm sure there are browser plugins that allow social sharing of sticky notes, or comments on web pages.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Sun Mar 01, 2009 10:42 pm
Oh, yea... at least for Firefox. I mean to remember something like that.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Sun Mar 01, 2009 10:53 pm
Could this be something? https://addons.mozilla.org/en-US/firefox/addon/2792
Anyone tried it? Or got better solutions?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Mon Mar 02, 2009 12:26 am
Point3d.project_to_plane:
http://code.google.com/apis/sketchup/do ... ct_to_line
Shows the wrong example code (uses from project to line). and I know I gave the link for project_to_line. Its so you can see both methods simultaneously and see the error better. Thanks!
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Mon Mar 02, 2009 2:35 am
So far I am really truly enjoying the new docs. They feel much better, thanks for the efforts to get them to where they are. I'm also excited that changes might be able to happen faster now too, that is great.
I'm noticing that sometimes in the methods list, when I click on a method, it takes me to the class index for that method. Other times it willtake me directly to the entry for that method within the class. I prefer the latter. But I don't know why sometimes it does one thing and sometimes it does another,
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Mar 03, 2009 4:40 pm
http://code.google.com/intl/nb/apis/ske ... l#inputbox
It doesn't mention how to allow drop-down options by using a third array with strings separating each option with a pipe | character.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Tue Mar 03, 2009 5:13 pm
You can do a dropdown box?
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Mar 03, 2009 6:08 pm
UI.inputbox ['Hello'], ['World'], ['Mars|Pluto|World|Monkeys'], 'Title'
"Global Material Changer" and "Component Spray" uses it. That's the only way I knew it was possible.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jim » Tue Mar 03, 2009 10:12 pm
Chris Fullmer wrote:You can do a dropdown box?
Sure, and I made this to ease the pain a little: http://sketchuptips.blogspot.com/2008/0 ... class.html
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Tue Mar 03, 2009 10:20 pm
Nice one Jim.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Next
Return to Developers' Forum
Who is online
Users browsing this forum: Bing [Bot], Carestellar and 3 guests
