New API doc - typos and questions
PolygonMesh.add_polygon
The example shows how to use the add_point method.
Wish we had red pens to scribble on the docs.
Great idea, really. I'm sure there are browser plugins that allow social sharing of sticky notes, or comments on web pages.
Oh, yea... at least for Firefox. I mean to remember something like that.
Could this be something? https://addons.mozilla.org/en-US/firefox/addon/2792
Anyone tried it? Or got better solutions? -
Point3d.project_to_plane:
http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#project_to_line
Shows the wrong example code (uses from project to line). and I know I gave the link for project_to_line. Its so you can see both methods simultaneously and see the error better. Thanks!
So far I am really truly enjoying the new docs. They feel much better, thanks for the efforts to get them to where they are. I'm also excited that changes might be able to happen faster now too, that is great.
I'm noticing that sometimes in the methods list, when I click on a method, it takes me to the class index for that method. Other times it willtake me directly to the entry for that method within the class. I prefer the latter. But I don't know why sometimes it does one thing and sometimes it does another,
http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#inputbox
It doesn't mention how to allow drop-down options by using a third array with strings separating each option with a pipe | character.
You can do a dropdown box?
UI.inputbox ['Hello'], ['World'], ['Mars|Pluto|World|Monkeys'], 'Title'
"Global Material Changer" and "Component Spray" uses it. That's the only way I knew it was possible.
Sure, and I made this to ease the pain a little: http://sketchuptips.blogspot.com/2008/03/inputbox-class.html
Nice one Jim.
http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#z=
It says:
Point3d.z= The y= method is used to set the z value of a 3D point.
That second line should say "The z= method..."
http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#area
Face.area
actually takes an optional argument. I'm not sure what the argument is. It accepts pure numbers which then seems to be a scale factor. But it also acceptsTransformation
objects. -
Same applies to
Edge.length
The example uses project_to_lineplane = [Geom::Point3d.new(0,0,0), Geom::Vector3d.new(0,0,1)] point = Geom::Point3d.new 10,10,10 projected_point = point.project_to_line line
Tool - onMouseMove example has a bad local variable.
http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onMouseMovedef onMouseMove(flags, x, y, view) puts "onMouseMove: flags = " + key.to_s puts " x = " + x.to_s puts " y = " + y.to_s puts " view = " + view.to_s end
The variable "key" should be replaced with "flag" I think. That makes the example work.
http://code.google.com/apis/sketchup/docs/ourdoc/face.html#get_UVHelper
The code example:
model = Sketchup.active_model entities = model.active_entities pts = [] pts[0] = [0, 0, 0] pts[1] = [9, 0, 0] pts[2] = [9, 9, 0] pts[3] = [0, 9, 0] # Add the face to the entities in the model face = entities.add_face pts tw = Sketchup::TextureWriter.new uvHelp = face.get_UVHelper true, true, tw
This will return the error:
Error: #<TypeError: (eval):95:in `get_UVHelper': wrong argument type (expected Sketchup::TextureWriter)>
(eval):95Instead of
, the methodtw = Sketchup.create_texture_writer
will work.
Which leads to another questions: why can'ttw = Sketchup::TextureWriter.new
be used as in the example? -
ModelObserver.onPlaceComponent
http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onPlaceComponentThe manual claims that a
Model
is passed on as the argument, but instead it's theComponentInstance
. I have not tested the rest of theModelObserver
events to see if they also match.onPlaceComponent FIXED
Model
events to see if they also match.Thomas, you rock.
I'll double check all of the modelobserver arguments. Thanks!
