[Plugin] Select Lines by Length (Updated March 9th, 2009)
Postby Chris Fullmer » Mon Feb 23, 2009 3:25 am
Descrtiption: This script selects all lines of a specified length.
Usage: You can start with a single line selected and this tool will select all other edges in the model of the same length. OR you can have nothing selected and it will prompt you to supply a length. The length is automatically in the default model units or you can specify ( 12", 2', 10cm, 110mm, etc).
v1.1 - Changed where it loads itself.
User avatar
SketchUp Team
SketchUp Team
Re: [Plugin] Select Lines by Length
Postby Panga » Mon Feb 23, 2009 1:05 pm
Nice script Chris, That'll hepl me a lot.
Thanks.
Panga
Premium Member
Premium Member
Postby azuby » Mon Feb 23, 2009 1:46 pm
I also coded something similar this night reusing the code form "Select all with same orientation" (SAWSO) It's should be simple to integrate the functionality to select more than one line, Chris.
azuby
error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory* | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
Bad English? PM me, correct me. :)
azuby
Postby Chris Fullmer » Mon Feb 23, 2009 6:39 pm
True, it wouldn't be that much more code to make it so it allowed for multiple starting lines being selected. Just a single line was the request, but if multiple lines is desired, I could expand it.
User avatar
SketchUp Team
SketchUp Team
Postby pilou » Wed Feb 25, 2009 6:36 pm
Tricky :enlight:
Maybe that be possible to choose something like this
13 <= length < 20 ?
Speedy Galerie
User avatar
Top SketchUcator
Postby Dee256 » Sat Feb 28, 2009 12:17 pm
Thanks, Chris! It's stuff save my worktime! Thanks Thanks Thanks!!! :ecstatic:
Dee256
Re: [Plugin] Select Lines by Length (Updated March 9th, 2009)
Postby sigue2000 » Tue Mar 10, 2009 10:31 am
That's a great script Chris!
Thank you.
It should save me a lot of clicks in the future.
sigue2000
Postby pilou » Wed Mar 11, 2009 9:39 pm
It's a pity that works not for a line "grouped" or a line "component"! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Tue Mar 24, 2009 9:42 am
If I want all lines of a selection? (not the faces ! )
Can you add something for that? :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Tue Mar 24, 2009 10:15 am
Pilou wrote:If I want all lines of a selection? (not the faces ! )
viewtopic.php?f=180&t=14975
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Tue Mar 24, 2009 11:09 am
Thx I had another one by Matt666
Selection manager
I will try yours also! :enlight:
Yours seems more cozy! :fro:
Even it's a toy! ;) :D
Adopted! 8-)
But if Chris can make something like ">length wished" that will be terrific! :mrgreen:
Like >0
or
>0 & < 12
Speedy Galerie
User avatar
Top SketchUcator
Postby Chris Fullmer » Tue Mar 24, 2009 4:11 pm
I might not get to it right away, but adding a selection length range would be easy enoug to do. Thanks for the suggestion.
User avatar
SketchUp Team
SketchUp Team
Postby pilou » Tue Mar 24, 2009 5:19 pm
Cool! :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby simon le bon » Tue Mar 31, 2009 12:11 pm
Heyhey! Chris,
Clever idea, wonderfull tool. Many thanks, just continue this way, cause we need such tools :thumb: :P :) :D simon
User avatar
simon le bon
Postby EarthMover » Sun May 10, 2009 5:56 pm
Chris,
Would it be possible to also have a script that would select faces all of the same surface area?
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby Chris Fullmer » Sun May 10, 2009 10:18 pm
Yeah, thats a good idea. I'll see if I can get that implemented. I have 2 others also in progress right now. Hopefully I'll get a chance to finish some of these up today. Thanks for the suggestion,
User avatar
SketchUp Team
SketchUp Team
Postby publied » Wed Jun 03, 2009 10:00 am
chris,
another very interesting plugin from you! nice job. thank you so much.
/paolo
publied
Postby bagatelo » Wed Mar 10, 2010 12:56 pm
Very good plugin. Is possible to make plugin work only in selection?
User avatar
bagatelo
Postby Chris Fullmer » Wed Mar 10, 2010 8:34 pm
I suppose I could. The idea would be to select geometry first, then run the plugin and then when you click, lines only get added if you have cliked on something that is selected? Is that what you mean?
User avatar
SketchUp Team
SketchUp Team
Postby bagatelo » Wed Mar 10, 2010 11:40 pm
Yes!!!
User avatar
bagatelo
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
cron
Who is online
Users browsing this forum: Google Bot, irdium, oliverdoma, Stan7195 and 9 guests
Visit our sponsors:
