SketchUcation Premium Membership
[Plugin] Zorro2 (beta)
Postby Whaat » Sun Jan 25, 2009 4:55 am
Time for an update of Zorro. I think this release is much more polished than the first one. Plus, you now finally have the ability to render section cut views.
New Features:
-made cuts work with parallel projection views
-added slice model at section plane (right click on a section plane for context menu)
-added nested cuts using CTRL modifier
-improved precision of cuts
Somes notes on this release:
- It is recommended to use 'Slice model at Section' on a backup of your SKP file. It is a destructive process.
- Cutting through nested components results in creation of many unique components
- Some code was used with permission from TIG's SectionCutFace script to create a cutting plane from a section plane. Thanks!
- Script should work for older versions of SU and also on Mac systems
I am calling this a beta version so please post any bugs or requests in this thread. Enjoy!
EDIT: Updated version now attached which should fix the problems that have been reported. Also added tutorial.
Whaat
Whaat
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Zorro2 (beta)
Postby Gaieus » Sun Jan 25, 2009 5:24 am
Seems that I was the first to download - willplay and give feedback as much as possible. Thanks Dale for this major upgrade; I'm especially interested in this section cut effect (I love TIG's script as well).
:thumb:
Also, this seems to be a special day again with these real presents you guys spoil us with! :sketchstatic:
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby kwistenbiebel » Sun Jan 25, 2009 5:47 am
Wowoooooow :berserk:
Thank you Whaat!
Looks very cool and I am sure to try it out. :thumb:
kwistenbiebel
Postby MALAISE » Sun Jan 25, 2009 9:20 am
Let's play with this version, feedback very soon !
MALAISE :thumb:
Just a try
The former version worked perfectly ( SU V6 and V7 ).
Using Zorro2 when trying to cut a simple box even a group, the white feather
is gluing to the cut line, and nothing happens.
back to Zorro.rb (1), all work perfectly.
I hope it's help :)
MALAISE
Postby remus » Sun Jan 25, 2009 9:31 am
Damm work getting in the way of playing around with your latest cool update!
remus
Postby CadFather » Sun Jan 25, 2009 10:41 am
superthank you Whaat - this is a great plugin - always one of my favourites
just putting my cape on now.. 8-)
Z
PS ( i guess it will go into subsmooth in due course?)
Quarr-IT - SketchUp Training from the Master.. . ;) .
User avatar
CadFather
Name: Max Coppoletta
Postby MALAISE » Sun Jan 25, 2009 11:08 am
Hi Whaat
Some difficulties using Zorro2. No cutting effects, the white (feather :lol: ) arrow is gluing to the cut line.
Let's see my previous post.
MALAISE :)
MALAISE
Postby Pilou » Sun Jan 25, 2009 12:05 pm
Zorro return! :fro:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby bianhai » Sun Jan 25, 2009 12:42 pm
This is a great plugin! :thumb:
Thank you Whaat!
Today is China's Spring Festival, to say hello!
bianhai
Banned
Postby Frederik » Sun Jan 25, 2009 1:16 pm
THANKS Whaat'sUp... :D
User avatar
Frederik
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby Whaat » Sun Jan 25, 2009 2:52 pm
MALAISE wrote:Hi Whaat
Some difficulties using Zorro2. No cutting effects, the white feather is gluing to the cut line.
MALAISE :)
Can you post the SKP file? Are you sure you are in group-edit mode when you are doing the cut?
Whaat
SketchUp version: 8
License type: Pro
Postby linea » Sun Jan 25, 2009 3:45 pm
:berserk:
One of my most used scripts just got better!
linea
Postby Pilou » Sun Jan 25, 2009 5:49 pm
Seems works not with the orthogonal view (parallel projection)! :o
Works fine with normal view and 2 points perspective ;)
Request : a little tut video! :)
Question: why not name the new Zorro file: zorro2.rb ?
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby watkins » Sun Jan 25, 2009 6:43 pm
Dear Dale,
I too would like to see a video tutorial, or a .pdf help file explaining the various options.
Kind regards,
Bob
watkins
Postby Whaat » Sun Jan 25, 2009 6:50 pm
I guess I created a small bug just before I released the plugin that I did not release was there. i will post a fixed version later today. Sorry! I will also try to create a tutorial later today if I have time. For those of you who do not want to wait, just change line 266 to read:
Code: Select all
Sketchup.active_model.start_operation("Zorro")
I belive this will fix the problem but I don't have time to fully test right now.
Whaat
SketchUp version: 8
License type: Pro
Postby MALAISE » Sun Jan 25, 2009 8:12 pm
Hi Whaat
some feedback, I've just notice your last post.
It seems that something may be corrupted
MALAISE :thumb:
MALAISE
Postby Whaat » Mon Jan 26, 2009 5:45 am
OK, I updated the plugin in the first thread and added a tutorial. Hope that all works now...
Whaat
SketchUp version: 8
License type: Pro
Postby kwistenbiebel » Mon Jan 26, 2009 5:49 am
I draw the cut line by clicking two points but it doesn't cut. (using the updated version)
kwistenbiebel
Postby Whaat » Mon Jan 26, 2009 6:05 am
kwistenbiebel wrote:I draw the cut line by clicking two points but it doesn't cut. (using the updated version)
Any errors in the Ruby Console?? Did you read the tutorial?
Whaat
SketchUp version: 8
License type: Pro
Postby MALAISE » Mon Jan 26, 2009 7:57 am
Hi Whaat
It works perfectly. Slide model at section is really a good improvement. :enlight:
MALAISE :thumb: :thumb:
MALAISE
Postby rv1974 » Mon Jan 26, 2009 9:05 am
immensely :thumb:
PS Dale could you add create section cuts from multiple sections all together at once?
rv1974
SketchUp version: 8
License type: Pro
Postby Pilou » Mon Jan 26, 2009 9:17 am
Absolutly brilliant and so easy to use! :fro:
Just for quibble "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")" ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby kwistenbiebel » Mon Jan 26, 2009 10:33 am
I deleted the old zorro.rb and now it works.
Thank you again for this plugin.
kwistenbiebel
Postby derryatlanta » Mon Jan 26, 2009 3:52 pm
Thanks so much, Whaat.
Superb job developing and packaging this ruby. I look forward to checking it out today.
Cheers,
Nigel
Stop your grinnin' and drop your linen
derryatlanta
Postby sepo » Tue Jan 27, 2009 12:25 am
Thanks for the really good and useful plugin. Is there any chance to have closed section when using with SU section tool.
sepo
SketchUp version: 8
License type: Pro
Postby materialdb » Tue Jan 27, 2009 10:20 am
THATS What I've been looking for! Thanks a lot!
free vismat materials: http://www.material-db.com
materialdb
Postby craigbic » Tue Jan 27, 2009 1:38 pm
Awesome plugin! The ability to slice along a section cut face is FANTASTIC! Been waiting for something like that for a while now. Thank you so much! :sketchstatic:
Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
craigbic
Postby Jim Smith » Tue Jan 27, 2009 3:37 pm
Thank you, again, Dale great tool!
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
User avatar
Jim Smith
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby cyan.archnet » Wed Jan 28, 2009 11:32 am
THANK YOU!, will definitely give this awesome plugin a try!
cyan.archnet
Postby AcesHigh » Wed Jan 28, 2009 6:31 pm
where can i get the house model displayed on the PDF tutorial? I really like that house and would like to study a bit of american architectural conventions.
AcesHigh
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: agmavil, bart82, cdauscher, Gábor, libeskiano, Lil Real, McGyver and 5 guests
