[Plugin] Zorro2 (beta)
superthank you Whaat - this is a great plugin - always one of my favourites
just putting my cape on now..
ZPS ( i guess it will go into subsmooth in due course?)
Let's play with this version, feedback very soon !
MALAISE
Just a try
The former version worked perfectly ( SU V6 and V7 ).
Using Zorro2 when trying to cut a simple box even a group, the white feather
is gluing to the cut line, and nothing happens.back to Zorro.rb (1), all work perfectly.
I hope it's help
Zorro return!
This is a great plugin!
Thank you Whaat!
Today is China's Spring Festival, to say hello! -
THANKS Whaat'sUp...
@malaise said:
Hi Whaat
Some difficulties using Zorro2. No cutting effects, the white feather is gluing to the cut line.
Let's see my previous post.MALAISE
Can you post the SKP file? Are you sure you are in group-edit mode when you are doing the cut?
One of my most used scripts just got better!
Seems works not with the orthogonal view (parallel projection)!
Works fine with normal view and 2 points perspectiveRequest : a little tut video!
Question: why not name the new Zorro file: zorro2.rb ? -
Dear Dale,
I too would like to see a video tutorial, or a .pdf help file explaining the various options.
Kind regards,
Bob -
I guess I created a small bug just before I released the plugin that I did not release was there. i will post a fixed version later today. Sorry! I will also try to create a tutorial later today if I have time. For those of you who do not want to wait, just change line 266 to read:
Sketchup.active_model.start_operation("Zorro")
I belive this will fix the problem but I don't have time to fully test right now.
Hi Whaat
some feedback, I've just notice your last post.
It seems that something may be corruptedMALAISE
OK, I updated the plugin in the first thread and added a tutorial. Hope that all works now...
I draw the cut line by clicking two points but it doesn't cut. (using the updated version)
Any errors in the Ruby Console?? Did you read the tutorial? -
Hi Whaat
It works perfectly. Slide model at section is really a good improvement.
MALAISE
immensely
PS Dale could you add create section cuts from multiplesections all together at once? -
Absolutly brilliant and so easy to use!
Just for quibble "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")" -
Any errors in the Ruby Console?? Did you read the tutorial?I deleted the old zorro.rb and now it works.
Thank you again for this plugin. -
Hi Whaat
Some difficulties using Zorro2. No cutting effects, the white (feather ) arrow is gluing to the cut line.
Thanks so much, Whaat.
Superb job developing and packaging this ruby. I look forward to checking it out today.Cheers,
Nigel
