by fredo6 » Sat Jan 24, 2009 9:53 pm
Coen Naninck wrote:Did anybody see my jaw? I lost it somewhere...
Fredo, the Taper function looks killer! If it does the job on Nested Components and Groups as well, then people don't have to explode the geometry anymore to perform a Free Form Deformation on it.
The only thing I didn't understand about the YouTube video was when you scaled that ship. What were you demonstrating there?
Coen, Thanks for your encouragements. Taper Scale should work on nested components and groups, but it has to make all components unique and explode all curves. So it's a little bit destructive. No mystery, Tapering is not a transformation that can preserve the unicity of a single definition for components (same rule as for Sketchy FFD). For my ship, the purpose was just to show that Free Scale can handle large models full of components and groups, because it is actually just based on regular Scaling. Free Scale is not destructive at all, in contrast with TaperScale. Otherwise nothing special. Fredo
- Top SketchUcator
by Daniel S » Sat Jan 24, 2009 10:06 pm
Fredo: This is the ruby console result when I enter the commands:
Traductor.string_to_length "20" nil "20".to_l 7.8740157480315 Traductor.string_to_float_formula "20" 20.0
I attach a screenshot too.
Daniel S
Daniel S
by fredo6 » Sat Jan 24, 2009 10:29 pm
Daniel,
I still don't see what it could be, and why you have it specifically in your environment.
Just in case, I made a slight change in LibFredo6. So you have to re-install it again and check if it improves. Can you try?
- Top SketchUcator
by Daniel S » Sat Jan 24, 2009 10:44 pm
I tried with the new version of LibFredo6 but have no luck... still can`t use the dimension dialog box. But i find something strange in my Plugins directory: there is a new folder called "DEFPARAM_Dir" and is empty. I delete this folder, but every time that I open a new SketchUp it creates the folder again. I never had this folder before.
Daniel S
Daniel S
by Whaat » Sat Jan 24, 2009 11:01 pm
Wow! Another brilliant plugin, Fredo6!
Whaat
- Name: Dale Martens
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by fredo6 » Sat Jan 24, 2009 11:09 pm
Daniel S wrote:I tried with the new version of LibFredo6 but have no luck... still can`t use the dimension dialog box. But i find something strange in my Plugins directory: there is a new folder called "DEFPARAM_Dir" and is empty. I delete this folder, but every time that I open a new SketchUp it creates the folder again. I never had this folder before.
Daniel S
Daniel, I think I know what it could be. I guess you have a set up where you should use the comma as the decimal separator. I made a change in LibFredo6. Maybe it will clear the issue. Thanks for your patience. PS: DEFPARAM_Dir is just the place where my scripts (today only FreeScale) stores the default parameter. It is a separate folder so that the parameters are not lost when upgrading.
- Top SketchUcator
by fredo6 » Sat Jan 24, 2009 11:12 pm
Whaat wrote:Wow! Another brilliant plugin, Fredo6!
Dale, You can be sure that I appreciate the compliment, coming from you. Fredo
- Top SketchUcator
by Daniel S » Sat Jan 24, 2009 11:29 pm
Now works!!!... but not well!! I don`t know how to explain it in english but i attach a video showing that it dosen´t scale well (i put 30 and the result is 76,200cm). But now works!! Thank you for looking into this, Daniel S. PS. It must be only my problem because I remeber in the past I had problems with TIG`s slicer... was working for everyone but not for me and then he fixes the problem and said that was a problem about the comma.
Daniel S
by fredo6 » Sat Jan 24, 2009 11:34 pm
Daniel S wrote:Now works!!!... but not well!! I don`t know how to explain it in english but i attach a video showing that it dosen´t scale well (i put 30 and the result is 76,200cm). But now works!! Thank you for looking into this, Daniel S.
Daniel, My fault in the update. Can you make a last try for today with the update I made in LibFredo6. Thanks again for your patience. Fredo
- Top SketchUcator
by Daniel S » Sat Jan 24, 2009 11:40 pm
Now is working right! Amazing Plugin!! Thank you Fredo!!!Daniel S
Daniel S
by topherthomas2 » Sun Jan 25, 2009 2:49 am
I'm having some issues with the taper scale working on my machine. FreeScale works fine, and TaperScale does not redraw the polygons after I use the TaperScale tool. I can see the polygon shape distort in wireframe preview mode. Any Ideas?
topherthomas2
- Name: Topher
by SABBA » Sun Jan 25, 2009 5:06 am
I use a mac too and don't have any luck with the taper tool. ...same problem as the others.
SABBA
by fredo6 » Sun Jan 25, 2009 8:19 am
SABBA wrote:I use a mac too and don't have any luck with the taper tool. ...same problem as the others.
Can you confirm that you have the problem even on a simple cube (drawn from a Rectangle and Push Pull)? If so, is it correct that: - the Box with the small pad is OK - when you drag the handle, the wireframe appears correct - But when you click or release to finalize, you get NO deformation Just in case, could you drop the attached file in te LIBFREDO6_Dir_30 folder, restart Sketchup, turn on the Ruby console and try again. Thanks Fredo
- Top SketchUcator
by OTB Designworks » Sun Jan 25, 2009 8:32 am
Thanks fredo!
After installing the updated script, taper scale works beautifully.
I feel like I owe you a bottle of scotch, or something.
Awesome script!
Cheers, Chuck MY BLOGBecome a fan of OTB Designworks on Facebook, we'd love to have you! 3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
OTB Designworks
- Name: chuck
by linea » Sun Jan 25, 2009 8:38 am
thanks, great script
linea
- Name: jon
by fredo6 » Sun Jan 25, 2009 9:05 am
kannonbal wrote:Thanks fredo!
Awesome script!
Very strange. The change I made is purely in the syntax. I wonder why there was a problem on Mac. But, what matters is that it works. Let's wait for confirmation from other Mac users before opening the bottle ! Fredo
- Top SketchUcator
by fredo6 » Sun Jan 25, 2009 9:24 am
To Mac Users
By the way, I am interested to know how the dialog boxes for Default Parameters behave on Mac. Does it even work? Same for the Translation web dialog box.
- Top SketchUcator
by urgen » Sun Jan 25, 2009 9:40 am
--pupil forever...------
urgen
by bigstick » Sun Jan 25, 2009 10:29 am
Wow - awesome work Fredo! If there is a list of essential Ruby scripts somewhere, this really needs to be on it!
bigstick
by CadFather » Sun Jan 25, 2009 10:50 am
Master Fredo for president!
Quarr-IT - SketchUp Training from the Master .. . .
CadFather
- Name: Max Coppoletta
by ilay7k » Sun Jan 25, 2009 11:37 am
thank you!
ilay7k
- Name: Ilya Shpilkin
by gilles » Sun Jan 25, 2009 2:30 pm
thanks Fredo
I'm a mac user (os 10.4.11) free scaling works well for the moment even when you specify new dimension(pop-up window), but when tapering SU quite immediatly.
To be continue.
gilles
- Top SketchUcator
- Operating system: Mac
- License type: Free
- SketchUp use: other
- Level of SketchUp: Intermediate
by arquitectomaracucho » Sun Jan 25, 2009 4:06 pm
Thanks fredo! This tool has changed my life, what is needed, it works great. IS a spectacle. This humble YOU ALL YOU MUST RESPECT.
arquitectomaracucho
- Name: ARQZUL
by OTB Designworks » Sun Jan 25, 2009 5:22 pm
maybe I am confused, but I never get a pop up window of any kind.
I can, however, customize the dimensions just as I would with the SU scale.
Is there a command to bring up the dialogue pop-up?
What a kick ass script!
OTB Designworks
- Name: chuck
by BUDLA » Sun Jan 25, 2009 5:51 pm
It not showing in windows menu and not working?
BUDLA
BUDLA
by fredo6 » Sun Jan 25, 2009 6:40 pm
Coen Naninck wrote:Fredo, I just now tried your script, but can't get it to work. I extracted both zip files, both having a file and a folder, to my plugins directory. At startup I get this error: - Code: Select all
Error Loading File ZLoader__FreeScale.rb C:/Program Files/Google/Google SketchUp 7/Plugins/LibFredo6.rb:30: syntax error def LibFredo6.startup ^
I must add that I am running SketchUp 7 on Ubuntu, which is a Linux distribution, with WINE (a Windows layer that allows for Windows apps to run on Linux). But as you can see it creates a C drive, so I don't think this is the problem.
Coen, For sure I did not test this platform! The error you get is very strange, because it signals a syntax error in a statement which is purely Ruby. And at the stage it reads LibFredo6, nothing of my scripts has been loaded yet. In order to know more, could you turn the Ruby console on, and then type - Code: Select all
load "LibFredo6"
Thanks Fredo PS: if you continue getting an error, could you comment out lines 24 and 25 of LibFredo6. Fred
- Top SketchUcator
by dacad » Sun Jan 25, 2009 8:03 pm
Fredo6 I'm slaping myself right know to make sure this is true...  Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! THANK YOU!!! Couple of years ago i asked for a ruby/feature just like this and was never aswer, and yeasterday i was just thinking how that could come in handy right now (for a project i'm working) and you just released it!! HA HA HA HA HA!! Let me try again: A million bucks would come in handy right now...hmm... Damn it Again thank you very very VERY much Fredo6 David
dacad
by fredo6 » Sun Jan 25, 2009 8:07 pm
David,
I am honoured by your enthusiasm. Do I also understand that the plugin works for you?
- Top SketchUcator
by dacad » Sun Jan 25, 2009 8:33 pm
Fredo6
I'm about to kiss you Fredo!! I just discovered that it works in a specifics lines selections from an organic mesh...This is getting better and better!
So yes the plugin works flawless in my PC with Windows Vista 32 Bits.
P.S.: You do realize that you acomplished something the sketchup team couldn't in God-knows-how-much-time-and-sketchup-versions and your ruby just turns the skethcup scale tool completly obsolete right?
Again: many thanks for this script
David
dacad
by tomasz » Sun Jan 25, 2009 8:36 pm
Fredo,
Big thanks for such amazing tool! I have watched the video and was almost sure you will release it as a commercial plugin. Do you have a Paypal account? I believe many would like to express their gratitude.
Thank you Tomasz
tomasz
- SU2TH & SU2KT Developer
- Name: Tomasz
- License type: Pro
Return to Developers' Forum
