SketchUcation Premium Membership
[Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
Postby fredo6 » Sat Jan 24, 2009 5:05 pm
[Edit - 29 Mar 09 - 11:00 CET] New version 2.0 is available at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180. It contains additional deformations, such as Shear, Stretch, Bend, Twist.
[Edit - 10 Feb 09 - 21:40 CET] updated version 1.0e with a big bug fixed concerning Scale to Target, and trapping of TAB on Mac for dimension dialog box). It includes the first translation in Italian kindly provided by Marco Cosedi.
Also, do not forget to load LibFredo6 3.0e (10 Feb 09), so that you are up to date.
[Edit - 03 Feb 09 - 00:20 CET] updated version 1.0d with a big bug fixed when releasing the update 1.0c (thanks to Daniel S. again for signaling).
Also, do not forget to load LibFredo6 3.0c (2 Feb 09), so that you are up to date.
[Edit - 02 Feb 09 - 22:30 CET] updated version 1.0c with bug fixed concerning the stability of scaling and tapering with negative scales (thanks to Daniel S. for signaling).
[Edit - 28 Jan 09 - 23:30 CET] Refresh with translation to Spanish provided by Pichuneke, and support of Construction Points.
Also, please make sure you download again LibFredo6 3.0a, same date and time, which contains a number of fixes.
See http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16020#p124684
FredoScale is a variant of the native Sketchup Scale tool, but with free orientation of the scaling box. I also derived Taper Scale, which uses a scaling box to perform tapering of the selection by scaling only one of its faces.
I made a short video (English / French) to show the main concepts.
http://fr.youtube.com/watch?v=sfXg4Q8J5pk
There are a few additional features.
  • can scale single edges (or aligned edges)
  • mode “Scale To Target” to drive scaling by matching 2 points
  • drive scaling by entering the dimensions of the scaling box
  • wireframe preview (easier to use inference, when dragging the scaling handles)
  • selection of several entities in implicit selection mode (via Ctrl key)
  • you can control the display of icons, and the location of the menu (by default, it installs in Tools > Fredo6 Collection.
One big caveat however is that it does not support Smart Scaling of the new Dynamic Components introduced in Sketchup 7
The goal was also for me to release the first consolidated version of a shared library, LibFredo6, which I should use for other plugins (it used to be called LibTraductor in earlier times).
The plugin is translated to English and French (but the doc is only in English). It is now possible for generous contributors to make the translation in other languages and share it with the Community.
REQUIREMENT: You must download and install LibFredo6 version 3.0. See this post for the zip file and the instructions. It should install a small file LibFredo6.rb and a subfolder LIBFREDO6_Dir_30.
see this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16020&p=124684#p124684
INSTALLATION of FredoScale:. Unzip (with Select All) the attached file FreeScale_10.zip. It should install a small file ZLoader__FreeScale.rb and a subfolder FREESCALE_Dir_10.
WARNING for Mac Users: FredoScale and LibFredo6 use Web Dialog Boxes, which have known problems on Mac platforms. As I don’t have a Mac myself, I cannot guarantee this works fine. This only concerns the dialog boxes for setting the default parameters and language translation however.
Note for icon designers: if you wish to design alternate icons and cursors, just follow the naming convention (FSC…), respecting the hot spot for cursors, and then pack them in a folder with the naming IMAGES_xxxx, which can then be dropped into the FREESCALE_Dir_10 directory. Finally, go the Default Parameters… dialog box and set it as an alternate icon folder.
Fredo6
Top SketchUcator
Re: [Plugin] FreeScale 1.0 (Free Scaling, Taper Scaling)
Postby Gaieus » Sat Jan 24, 2009 5:14 pm
:sketchstatic: (<- AFAIK this smiley was introduced as an honour of your efforts by Coen back when you released TOS)
Orientation of the scale tool: great!
A big time saver (need not change axes) but
Taper scale: fantastic!
:thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
Thanks again for your generous work - these all could well be serious commercial plugins!
(You can count on me for translations for sure) ;)
User avatar
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby remus » Sat Jan 24, 2009 5:20 pm
Cheers fredo, another indispensable script.
remus
Postby Gaieus » Sat Jan 24, 2009 5:23 pm
No, Fredo,I was wrong. Free scale is not "only" great - it is much more than that.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby kwistenbiebel » Sat Jan 24, 2009 5:23 pm
Fantastic fredo! :berserk:
Very useful. It will be one of those tools you cannot live without once you used it.
You guys (the wizard ruby masters) should take over the further development of sketchup as a whole.
Thank you very much. :thumb: :thumb:
kwistenbiebel
Postby Pilou » Sat Jan 24, 2009 5:26 pm
Super bestial ! Very tricky! :thumb: :fro:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby johnsenior1973 » Sat Jan 24, 2009 5:33 pm
Thank you for another great plugin.
johnsenior1973
Postby watkins » Sat Jan 24, 2009 5:36 pm
Dear Fredo6
I have just tried FreeScale. EXCELLENT!!!
Thank you for your generosity.
Kind regards,
Bob
watkins
Postby thomthom » Sat Jan 24, 2009 5:38 pm
Yes! I was thinking just this week that it'd be so nice ot be able to taper scale objects. This is another must have plugin. Thank you very much Fredo.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby notareal » Sat Jan 24, 2009 5:40 pm
Great! Thanks for your effort.
notareal
Thea Render
Postby johnsenior1973 » Sat Jan 24, 2009 5:51 pm
Solo is going to find his cartoon characters a great deal easier with this. This is clearly another great leap for Sketchup.
johnsenior1973
Postby Teezer » Sat Jan 24, 2009 5:51 pm
Wonderful! Great! Excellent! Thank you, thank you, thank you... :bounce: :D
Real life is just another website, albeit a rather boring one.
Teezer
Postby tbd » Sat Jan 24, 2009 5:57 pm
to be able to run on Mac I had to create DEFPARAM_Dir under plugins dir (due permissions restriction the mkdir command in Lib6Core_30 failed)
nice work Fredo :sketchstatic:
http://plugins.ro
User avatar
tbd
Postby solo » Sat Jan 24, 2009 5:57 pm
Bravo!!
Just what I need for my character modeling, thanks a ton.
My site
Quod gratis asseritur, gratis negatur.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby watkins » Sat Jan 24, 2009 6:19 pm
Dear Fredo6,
One little known option of the native SU Scale tool is the ability to input final dimensions via the VCB (example: 100mm,100mm,100mm). The scale box is then scaled to those dimensions. Is this something that could be include in your script?
Kind regards,
Bob
watkins
Postby OTB Designworks » Sat Jan 24, 2009 6:21 pm
Great script! Thank you thank you!.
However, I, as you know, am on a MAC and I am having serious issues with this script.
The standard scaling tool works beautifully and as expected. Being able to set the orientation is brilliant!.
The taper scale tool, however, isn't working at all.
It displays the bounding box and shows the results of all of the tool manipulations, but it never actually changes the object geometry. Picture attached. Hitting return or clicking outside the box erases the bounding box and the cube remains as is.
Let me know what I can do to assist diagnosis.
Thanks again.
Cheers, Chuck
MY BLOG
Become a fan of OTB Designworks on Facebook, we'd love to have you!
3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
OTB Designworks
Postby Matt666 » Sat Jan 24, 2009 6:29 pm
:shock: :shock: Awesome !!! Thank you Fredo !
Frenglish at its best !
My scripts
Matt666
Postby MALAISE » Sat Jan 24, 2009 6:35 pm
Hi Fredo
Incredible enhancement :thumb: :thumb: :enlight:
MERCI
MALAISE
MALAISE
Postby Daniel S » Sat Jan 24, 2009 7:31 pm
Awesome!!! :berserk: :berserk: :berserk:
Thank you Fredo!!!
I only have a problem when set the dimension in the dialog box by pressing TAB. It dosen´t accept what I put.. just make a beep :?
I attach a video example of this.
Daniel S
Daniel S
Postby fredo6 » Sat Jan 24, 2009 7:48 pm
Daniel S wrote:I only have a problem when set the dimension in the dialog box by pressing TAB. It dosen´t accept what I put.. just make a beep :?
Daniel S
Daniel,
Strange. What is the default decimal separator you normally use in your version of Sketchup.
Just in case, can you turn the Ruby console on to see if anything is displayed.
Can you also type in the Ruby console the following command:
Code: Select all
Traductor.string_to_length_formula "20"
and see what it does.
I don't know if any other users has found that problem?
I will analyze what it could be in parallel.
Top SketchUcator
Postby fredo6 » Sat Jan 24, 2009 7:51 pm
watkins wrote:Dear Fredo6,
Kind regards,
Bob
Bob,
Just press TAB when the scaling handle is highlighted (or use the contextual menu). You should have the Dimension box appearing. For teh time being, I preferred to reserve the VCB to scale values.
PS: Daniel S. has found some issues with this dialog box. Maybe you can report if found any.
Top SketchUcator
Postby fredo6 » Sat Jan 24, 2009 7:55 pm
kannonbal wrote:The taper scale tool, however, isn't working at all.
Thanks again.
It is clear that there is an error in the execution of the deformation, as shown on your image.
The best would be to turn on the Ruby console and see what it says. I don't know if it could be related to Mac.
Also can you tell me if your run SU 7 or 6.
Top SketchUcator
Postby roadkill » Sat Jan 24, 2009 8:01 pm
many thanks dude... that is special!
roadkill
Postby OTB Designworks » Sat Jan 24, 2009 8:02 pm
Hi Fredo!
Here is the Ruby Console result from attempting to taper scale.
I am using SU7, OS 10.5.6.
Cheers, Chuck
MY BLOG
OTB Designworks
Postby Daniel S » Sat Jan 24, 2009 8:06 pm
Fredo:
When i put in the ruby console
Code: Select all
It returns:
nil
When i have open the ruby console and try to use the dialog box don`t report anything.
I have the same problem with the taper.. it dosen´t accept what i put on the dialog box.
I attach a screenshoot of my units.
Daniel S
Daniel S
Postby TeKnoel » Sat Jan 24, 2009 8:31 pm
this looks great! thanks for your hard work
TeKnoel
Postby EarthMover » Sat Jan 24, 2009 9:04 pm
Holy Sh!t! Just what I was thinking of asking for the other day. I love the taper. Reminds me of the Falloff function in Modo. Thanks Fredo!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
User avatar
EarthMover
Top SketchUcator
Postby gaganraj » Sat Jan 24, 2009 9:29 pm
phenomenal tool. works perfectly on my windows machine. same issue as kannonbal on my mac.
i'm amazed at how intuitive and simple such a great tool can me made. I absolutely love the little green check mark!! such a great idea. This will make SDS proxies so much easier! thanks!
gaganraj
Postby fredo6 » Sat Jan 24, 2009 9:33 pm
To Daniel S (on problem of dimension dialog box)
I don't understand what is happening.
Can you then try the 3 commands below, one by one
Code: Select all
Traductor.string_to_length "20"
Code: Select all
"20".to_l
Code: Select all
Traductor.string_to_float_formula "20"
Apparently other users have not reported the problem (yet). So it may be something specific to your environment.
Top SketchUcator
Postby fredo6 » Sat Jan 24, 2009 9:37 pm
To Chuck (Kannonbal) on issues with Taper Scale
I made an update to LibFredo6 in relation with the issues you signaled.
Could you download and install again LibFredo6 and advise if you still have the problem
Top SketchUcator
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Next
Return to Developers' Forum
Who is online
Users browsing this forum: chrislbj, High_Viz, mptak and 5 guests
