Random Push Pull by Tig
Postby pilou » Sat Jan 17, 2009 12:37 pm
Seems nothing works? :?:
Is there a special installation :?: (i have the sketchup.rb)
I select some faces of some objects(not grouped) but nothing... :o
Unity must be in inch? (I am in cm)
Speedy Galerie
User avatar
Top SketchUcator
Re: Random Push Pull by Tig
Postby Chris Fullmer » Sat Jan 17, 2009 11:44 pm
Bummer, its not working for me either. It would be handy right now... :)
User avatar
SketchUp Team
SketchUp Team
Postby Jim » Sun Jan 18, 2009 4:27 pm
Change this line (38) from this
Code: Select all
   ss[i].pushpull ht.in ### into inches ***
to this.
Code: Select all
   ss[i].pushpull ht.inch ### into inches ***
Just a typo..
Jim
Global Moderator
Postby pilou » Sun Jan 18, 2009 7:08 pm
Cools that works with your modification! :enlight:
Have you a little trick for select only "surfaces"?
Speedy Galerie
User avatar
Top SketchUcator
Postby Jim » Sun Jan 18, 2009 7:23 pm
This will ignore selected edges.
edit - and work in the current model units, whatever they are.
edit - download removed. see TIG's updated plugin.
Jim
Global Moderator
Postby pilou » Sun Jan 18, 2009 7:34 pm
Bravo! :thumb:
Now that is absolutly rocking! :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby Chris Fullmer » Sun Jan 18, 2009 7:42 pm
Excellent. I'll have to play with this now. I've been learning ruby and greeble was the firs thing on my list. I'll check this script out now to understand how it works, then maybe I'll try to modify it to be more greebley :)
Anyhow, thanks for script TIG and thanks for the tweaks Jim,
User avatar
SketchUp Team
SketchUp Team
Postby derei » Thu Jul 07, 2011 11:22 am
It seems to be a problem with the plugin.
It doesn't respect the max/min values at all :(
See the images.
DESIGNER AND ARTIST DEREI.UK
User avatar
derei
Postby thomthom » Thu Jul 07, 2011 11:35 am
dereeei wrote:It seems to be a problem with the plugin.
See the images.
Did you use TIGs original script, or Jims modified version ( viewtopic.php?f=180&t=15824#p123151 ) ?
User avatar
PluginStore Author
PluginStore Author
Postby derei » Thu Jul 07, 2011 11:38 am
See the images.
I gues Jim's :? I downloaded it from here (see up)
Where I can find TIG's script?
User avatar
derei
Postby TIG » Thu Jul 07, 2011 12:02 pm
Here's a new v2.0 that tidies it up a bit... viewtopic.php?p=340452#p340452
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: No registered users and 6 guests
Visit our sponsors:
