SketchUcation Premium Membership
component question
Welcome! Ask and get answered - or just introduce yourself.
component question
Postby ianccc » Fri Nov 30, 2007 3:10 pm
I created this component (link below)for our Local festival - I am in charge of signage and last year the plastic signs disinigrated so I an going to dust off the welder and make one to last
http://sketchup.google.com/3dwarehouse/ ... 144e458307
Question can someone have a look and see if there are any real problems with my model - I relize there is some alighment + problems with the handle
any info appreciated
ianccc
Re: component question
Yikkes - it's worse than I thought - I just downloded it off 3D warehouse
I thought I re-saved the individual sign pickets with a different component name, what I am seeing is a jumble
part of my component is always highlighted - is there a easy to unselect - not sure why this is happening
~ian
ianccc
Postby Krisidious » Fri Nov 30, 2007 3:11 pm
downloaded fine for me...
to unselect either hit escape a few times or double click out in the open.
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
User avatar
Krisidious
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Krisidious » Fri Nov 30, 2007 3:12 pm
other than line up issues... like you said. all I would do is perhaps make a box for ballast at the bottom, or build it up more to weight it down.
also the handle is a bit much for me... why not just put a grip around the pole at the middle... it's just for moving it right?
otherwise... I'm sure this thing will last forever...
Kristoff Rand
Home Designer
User avatar
Krisidious
SketchUp version: 8
License type: Pro
Postby ianccc » Fri Nov 30, 2007 3:12 pm
thanks for the info - it worked I was able to
un-select the component
Yep - I will lose the handle and possible beef up the bottom plate with 1/2" steel
thanks again
~ian
ianccc
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: Bing [Bot], cotty, lavatoad, pomtiff and 8 guests
