I am watching my lines very carefully making sure they are aligned properly, but it doesn't matter;/ What am I doing wrong?
P: Hanna
Face
• Page 1 of 1
FaceHi
I am watching my lines very carefully making sure they are aligned properly, but it doesn't matter;/ What am I doing wrong? P: Hanna
Re: FaceHanna,
You may have a problem with OpenGL graphics compatibility for your graphics hardware. The square face may indeed be there, but your system isn't displaying it. What computer and operating system are you using? "Information is not knowledge." -- Albert Einstein
Re: FaceHi Hanna (and welcome as - so far - the "newest member"
Have a look at what the Users Guide tells about faces created on the ground plane: http://download.sketchup.com/OnlineDoc/ ... shPull.htm (second note after point 4) A face created on the ground plane should show its back (blue) face up however when you give a thickness to the geometry (say with the Push/Pull tool) it will turn all the faces to the lighter "front" face. If you don't have the front created, there might be a problem like Taff says. In any case you can set the face colours in your model in the "Styles" dropdown (activate it from the window menu) > In model (the little house tab) > Edit > Face settings (the second little image in the row). Gai...
Re: FaceI set the front color to grey and the back to light blue. I don't even get any color when I pull it out.
I am using windows Vista on a Gateway Notebook computer. P: Hanna
Re: FaceTry this diagnostic test, to see if you've got an OpenGL deficiency. Go to...
'Window > Preferences > OpenGL' ...and disable 'Use hardware acceleration' This will force SketchUp to do all the graphics calculations, rather than passing functions to your graphics card. If this diagnostic test resolves the odd behavior, then you need to obtain an updated driver for your graphics card. References: http://sketchup.google.com/support/bin/answer.py?answer=36252 http://sketchup.google.com/support/bin/answer.py?answer=66154 You can leave hardware acceleration disabled, as SketchUp will run okay without it, but it will run slower. The ideal resolution is downloading and installing an updated graphics driver. "Information is not knowledge." -- Albert Einstein
Re: FaceBINGO! That did it, thank you so much:) I will go chase down a driver...thanks a lot:)
P: Hanna
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
• Page 1 of 1
