[Plugin] Modification to PutOnLayer
Postby Dik Harrison » Sun Sep 07, 2008 3:17 pm
I tend to have way too many layers in my more complex models, and I really like Chris Grant's PutOnLayer as modified by Brian Wirth to put the geometry in Layer 0, but with so many layers, it is often difficult to locate the layer I'm looking for since the plugin lists them in ID order. I did a little tweak to the plugin to sort the layer list by name alphabetically. I hope someone else out there can make use of it.
PutOnLayer_bmw_wrh.rb
P.S.
I forgot to mention that you need to rename the file to PutOnLayer.rb when you put it into your plugins folder.
6
Have fun...
Dik
Dik Harrison
PluginStore Author
PluginStore Author
Re: Modification to PutOnLayer
Postby Burkhard » Sun Sep 07, 2008 3:31 pm
thanks a lot, will come in handy
:thumb:
User avatar
Burkhard
Premium Member
Premium Member
Postby juju » Sun Sep 07, 2008 3:41 pm
User avatar
juju
Premium Member
Premium Member
Postby Bob James » Wed Dec 10, 2008 8:43 am
Thank you, thank you, thank you. :berserk:
Would you believe that I was in the Ruby Forum about to ask if someone could do this very thing!!
Many of my models are very large and have up to 50 layers or more. It was really a chore to first make the layer current and then click on an object and then use Put on Layer. This makes it so much easier.
User avatar
Bob James
Premium Member
Premium Member
Re: [Plugin] Modification to PutOnLayer
Postby MALAISE » Wed Dec 10, 2008 7:33 pm
Really a good improvement. Mainly when using a lot of layers ( for teaching purpose )on drawings about sophisticated devices ( X ray Fluorescence spectrometers)
Thanks a lot :thumb: :thumb:
MALAISE :)
User avatar
MALAISE
Postby JClements » Mon Nov 02, 2009 9:25 pm
Dick,
I tried your version. It does a nice job of listing the layers in alphabetical order, BUT it seems to have broken the function of the original script which is to move ALL NESTED geometry to a target layer.
Do you have a way to fix this?
User avatar
JClements
Premium Member
Premium Member
Postby Bob James » Tue Nov 03, 2009 6:14 am
Putting things on Layer(0) is nice, but how about putting things on a layer of choice rather than just Layer(0).
As I said in my Dec 2008 post, I thought this plugin used to do that: am I wrong? [Windows 7]
User avatar
Bob James
Premium Member
Premium Member
Postby onzki » Fri Nov 18, 2011 5:18 pm
Thanks for the tweak, I'm about to request this one. I'm glad it's here already.:)
[/hr]Dell Precision T5600. SKU 2018 Pro. AutoCAD 2013. Landscape design firm. Hong Kong
onzki
Postby luo » Fri Apr 20, 2012 9:30 pm
JClements wrote:Dick,
i just added working layer list sorted by name.
try it, now it should work.
maybe someone could try to update layers list to display in coulumns?
without having to scroll up and down.
luo
Postby panixia » Sat Mar 09, 2013 2:55 pm
thank you a lot!!!!
User avatar
panixia
Postby dungkedi » Thu Apr 18, 2013 1:53 pm
wow thanks a lot! that's what I needed
dungkedi
Postby asterios_polyp » Tue Oct 22, 2013 3:18 am
Old post, but here is an update for those having difficulty. Use this script in conjunction with:
viewtopic.php?t=7638
The two combined are brilliant! This is especially true for those that use proper layering techniques, but receive models from Revit Exports.
asterios_polyp
Postby Helle » Sun Mar 16, 2014 10:27 am
SUPER ... Really LOVE it :-)
Helle
Postby 3dita » Mon Sep 22, 2014 11:49 am
Hi there! This is a great plugin, but could there be an option to create a new layer, after I have selected a group, and right clicked on it?
It could be useful to right click > Put on Layer > New..
Is it possible?
User avatar
3dita
Postby pbacot » Thu Nov 05, 2015 6:00 pm
omit
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby orbital » Wed Jul 31, 2019 11:48 pm
This is a great plugin - thanks!
But I don't want it to move all nested geometry (groups) to the target layer.
e.g. I'll have a nest of, say, three groups - outer group on a wall layer, middle group on an exterior layer and the inner most group on an existing layer.
I'm not experienced in the SketchUp API... In the code I've commented out the two lines of code where the the recursion happens and the plugin now seems to not move all nested geometry to the target layer, which is what I want to happen.
Is this a correct assumption to make or have I corrupted the plugin despite it seeming to work?
orbital
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: varindersingh and 12 guests
Visit our sponsors:
