SketchUcation Plugin Store
[Plugin] Soften/Unsoften
Postby CadFather » Thu Oct 23, 2008 10:15 am
is it possible to define an action (by icon or shortcut key) which unsoftens a selection in one go without having to go to smooth/soften and move the slider all the way down?
and is the reverse (one click soften)?
SOLVED - PLUGIN CREATED BY MATT
PLEASE USE THIS LINK FOR THE MOST RECENT VERSION
[file contains script and folder with icons - drop both into the plugins directory]
Quarr-IT - SketchUp Training from the Master.. . ;) .
User avatar
CadFather
Name: Max Coppoletta
Re: [Idea]
Postby Pixero » Thu Oct 23, 2008 11:53 am
If I remember correct this free plugin has it: http://www.cadspan.com/tools
User avatar
Pixero
Premium Member
Premium Member
Name: Jan Sandström
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Idea]
Postby Matt666 » Thu Oct 23, 2008 12:06 pm
A script was created to do what you want, here !
Frenglish at its best !
My scripts
Matt666
Re: [Idea]
Postby CadFather » Thu Oct 23, 2008 12:22 pm
THANKS GUYS!!! :berserk:
Pixero for a new interesting plugin
Matt for a genius 'back to the future plugin' - works just great even for groups and all!
(and it's much easier for quick smooth/unsmooth)
will see if i can create a toolbar to the commands..
User avatar
CadFather
Re: [Plugin] Soften/Unsoften
Postby CadFather » Thu Oct 23, 2008 2:25 pm
small update for whoever likes this idea:
tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
(i removed menus in plugins)
now it is a quick step!
Thanks Matt! :thumb:
User avatar
CadFather
Postby Matt666 » Thu Oct 23, 2008 3:09 pm
This plugin will help someone, finally... :D
As always, great icons CadFather !
My scripts
Matt666
Postby CadFather » Thu Oct 23, 2008 3:50 pm
Thanks Matt - and i even learned how to create toolbar items (by copying Jim's scripts).. :D
User avatar
CadFather
Postby ___olo » Fri Oct 24, 2008 6:36 am
CadFather, can you post this Ruby again. Because, I did down it , but it may has a mistake.
Xin chào nhau giữa con đường
Mùa xuân phía trước, miên trường phía sau
User avatar
___olo
Postby CadFather » Fri Oct 24, 2008 8:14 am
done - look up for new download
User avatar
CadFather
Postby Matt666 » Fri Oct 24, 2008 1:00 pm
Hi CadFather !
I updated the code, with another tool. It softens edges whose angle normal faces is below 20 degrees.
So now you've got three tools :
    Mildly Soft edges
    Completely Soft edges
    Unsoft edges
You forgot a bit of code at the end...
Code: Select all
if (not file_loaded?("Soften.rb"))
Now the tool will be loaded just one time !
and the code is also changed following the RickW notices (I hope ;) )
Good luck for the next icon :D
EDIT : Version 1.1
My scripts
Matt666
Postby CadFather » Fri Oct 24, 2008 1:43 pm
:shock: :o :? :evil: :roll: :fro:
User avatar
CadFather
Postby chango70 » Fri Oct 24, 2008 2:36 pm
Wow this answered my prayers!
chango70
Postby watkins » Fri Oct 24, 2008 3:57 pm
Dear Matthieu,
I have downloaded and installed the plugin. When I open SU I find a toolbar but no Icons. Is this an oversight?
Kind regards,
Bob
watkins
Postby CadFather » Fri Oct 24, 2008 3:59 pm
Hi Matt, i have a problem with the new version: nothing happens :?
still works with the old one
i have updated the script with the 3 icons (changed the name for the new command icon)
User avatar
CadFather
Postby CadFather » Fri Oct 24, 2008 4:01 pm
Bob, you need both the plug in and the folder called smooze (with the icons)
User avatar
CadFather
Postby watkins » Fri Oct 24, 2008 4:16 pm
Dear CadFather,
Many thanks for that. As an aside, are you Italian? I ask because I spent a very happy year at the University of Trento.
Kind regards,
Bob
watkins
Postby watkins » Fri Oct 24, 2008 4:29 pm
Dear Matthieu and Cadfather,
I am a little confused about what to download. I have the icons showing, but nothing works. The last thing I downloaded and tried is the very last .zip file posted by Cadfather.
Regards,
Bob
watkins
Postby CadFather » Fri Oct 24, 2008 4:45 pm
will post a working final version from Matt very soon - need to finish a couple of things first.
Bob, yes one of those... ;)
User avatar
CadFather
Postby watkins » Fri Oct 24, 2008 5:48 pm
watkins
Postby publied » Fri Apr 13, 2012 4:06 pm
oh my hero, my savior! this plugin is very useful for me! thanks!
publied
Postby tedvitale » Tue Mar 05, 2013 6:11 pm
Does anybody know of a plugin that allows me to soften multiple grouped objects? I have a lot of 3DS models that i import that need to be smoothed and cleaned up, but I have to open each group and soften them individually, which is quite painstaking. Any Suggestions?
tedvitale
SketchUp version: 8
License type: Pro
Postby massimo » Tue Mar 05, 2013 8:43 pm
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: No registered users and 14 guests
