[Plugin] BezierSpline - v2.1a - 01 Nov 18
Postby fredo6 » Sun Oct 19, 2008 5:07 pm
# Permission to use this software for any purpose and without fee is hereby granted
# Distribution of this software for any purpose is subject to:
# - the expressed, written consent of the author
# - the inclusion of the present copyright notice in all copies.
Please UPGRADE to this latest version 2.1 if you run SU 2017 (for certification) and above.
BezierSpline draws a variety of Polylines, Bezier and Spline curves, all in 3D. The present release gathers all extensions, including those published recently (Courbette, Catmull, F-Spline, DogBone, T_Bone, Polyline for Animation, etc…).
  • All curves are based on a sequence of control points, which is entered by the user in interactive mode.
  • A Precision parameter allows to adjust the number of segments when the curve is generated.
  • For some curves, there may be extra parameters, accessible via the TAB key.
  • All curves can be later edited. You can move, delete, add control points
  • As of version 1.4, you can also transform a curve of one type into a curve of another type, both sharing the same control points.
Here is a comparison between the different Splines, based on the same Control points:
Note: The doc is slightly outdated, but gives an overview of the essential features. All PDF files are also available from the menu "Draw > BezierSpline curves > Documentation..."
Quickcard BezierSpline - English - v1.2.pdf
Quickcard BezierSpline - French - v1.2.pdf
Quickcard BezierSpline - Portuguese - v1.2.pdf
Tutorial BezierSpline - English - v1.2.pdf
  • Language: English, French, Portuguese, Hungarian, German, Spanish (thanks to all kind translators).
  • Menus: by default, it is installed in Draw > BezierSpline curves…
  • Icon toolbar: Most of the tools are present on the toolbar (unfortunately, not adjustable unless you remove the icon files in BZ_Dir_14/IMAGES_CadFather)
There are now multiple ways to install scripts
- SCF Plugin Store (SU8 and SU13) - recommended method
- Unzip (all SU versions and for installations in an alternate Plugins directory)
- Extension Manager with RBZ files (SU8 and SU13)
If you run SU8, SU13, SU14, SU2015, or SU2016 the strongly recommended installation method is to Autoinstall with the SCF Plugin Store tool.
Otherwise, you can download the BezierSpline.rbz file from the Plugin Store page for BezierSpline.
Whatever way you install, you must end up with the following footprint:
Note for SU6 and SU7 users, download the rbz file from the plugin store page, and change its extension from .rbz to .zip
Then:
1) Open the zip archive
2) Select All (Ctrl A)
3) Extract into the Sketchup Plugin Directory
4) Answer YES to OVERWRITE all existing files if any
5) Make sure you get the correct footprint (one rb file and one folder)
The standard SU Plugins root directories are:
Windows SU8: C:\Program Files\Google\Google SketchUp 8\Plugins
Windows SU13: C:\Program Files\SketchUp\SketchUp 2013/Plugins
Windows SU14: C:\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
Windows SU15: C:\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
Mac SU8: Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins
Mac SU13: ~/Library/Application Support/SketchUp 2013/SketchUp/Plugins
Mac SU14: ~/Library/Application Support/SketchUp 2014/SketchUp/Plugins
Mac SU15: ~/Library/Application Support/SketchUp 2015/SketchUp/Plugins
CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
Curves are created by entering the control points. By default, all curves, except Classic Bezier requires to enter control points in sequence. Classic Bezier requires entering the first and last points, and then the other middle points.
You can later Edit a selected curve via the contextual menu “BZ - Edit <name of curve>….”
You can also Convert or Transform a curve via the contextual menu “BZ – Convert….” and “BZ – Transform (control points)….”
  • You can enter the precision in the VCB as a number followed by ‘s’
  • For loops, you can specify the number of segments as a number followed by ‘c’
  • Type F8 to close the curve by a segment
  • Type F9 to close the curve by a nice curve (based on Bezier)
  • Type TAB to access a dialog box for extra parameters when applicable
  • Type F5 to toggle the visibility of vertex (displayed as small blue points)
  • It is always a good idea to check the contextual menu to see which options are available
BezierSpline 2.1a – 01 Nov 18:
Fix for size of toolbar icons
BezierSpline 2.0a – 01 Aug 18:
Fix for non-ascii Windows username and repackaging
BezierSpline 1.9b – 25 Feb 18:
Increased the number of poinst and control points
Here is the start post for this release
BezierSpline 1.9c – 31 Jul 18:
BezierSpline 1.9a – 12 Feb 17:
Release certified for SU2017
BezierSpline 1.8a – 13 Nov 15:
Maintenance release
BezierSpline 1.7c – 23 Mar 15:
Remove traces at startup of Sketchup - second trial
BezierSpline 1.7b – 22 Mar 15:
BezierSpline 1.7a – 19 Oct 14:
Fixes when the username contains non-ascii characters (SU14).
BezierSpline 1.6d – 04 Mar 14:
Fixes another bug in Dog Bone curves (radius was not respected), as signaled by Robert Wan
BezierSpline 1.6c – 03 Mar 14:
Fixes a bug in Dog Bone curves (radius was not respected), as signaled by Robert Wan
BezierSpline 1.6b – 12 Nov 13:
Technical release for future Sketchup compatibility.
It also seems to fix the crash encountered on some Mac with SU13
BezierSpline 1.6a – 11 Nov 13:
BezierSpline 1.4f – 23 Jan 11:
  • Improve performance for contextual menu when selection is big (thanks to ThomThom and Jim for signaling)
BezierSpline 1.4e – 10 Nov 10:
  • Integrated the Spanish translation by Oxer
BezierSpline 1.4 – 07 Nov 10: bug fixing
  • Fix an issue concerning contextual menu performance for huge models
BezierSpline 1.4 – 02 Sep 10: Important update
  • Fix a bug for state of the toolbar on Mac
  • Added a menu to check for updates on Sketchucation (it links to this post)
  • Integrated updated icons by CadFather
BezierSpline 1.4 – 16 Aug 10: Important update
  • Several bugs fixed
  • Transformation of curves based on sharing control points
BezierSpline 1.3 – 31 Jan 10: Stable version
84
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] BezierSpline v1.2 - Comprehensive Refresh
Postby tomasz » Sun Oct 19, 2008 5:27 pm
Thanks a lot Fredo! :thumb:
Tomasz
tomasz
SU2TH & SU2KT Developer
Postby AndriyG81 » Sun Oct 19, 2008 5:31 pm
thank you very much, amazin update
AndriyG81
Postby watkins » Sun Oct 19, 2008 5:59 pm
Dear Frodo,
Many thanks for all your hard work. I have downloaded your files for a fresh install, but note that LibTraductor.rb is not there in the unzipped folder. This is not a problem for those who already have your plugin as they can use the existing file, but it might be a problem for new users unless LibTraductor.rb is a native SU file (is it?).
Does one leave the desired icons inside their folder or move them up one to the BZ_Dir folder?
Kind regards,
Bob
watkins
Postby fredo6 » Sun Oct 19, 2008 6:07 pm
You are right, thanks. I completely forgot LibTraductor.rb (which not Sketchup native, but mine). Actually, for those using my other plugins, it is present anyway, but for newcomers, it wouldbe missing.
I updated the archive in the main message of this post.
For the cions, I don't understand what you mean. Can you clarify.
User avatar
PluginStore Author
PluginStore Author
Postby sepo » Sun Oct 19, 2008 6:21 pm
Thanks Fredo...your efforts to help comunity is really great.
sepo
Postby watkins » Sun Oct 19, 2008 6:33 pm
Dear Frodo,
Inside the BZ_Dir folder you have two folders: IMAGES_CADFather and IMAGES_ Standard.
Does one leave the icons inside these folders or does one move the icons of choice into the BZ-Dir folder?
Kind regards,
Bob
watkins
Postby fredo6 » Sun Oct 19, 2008 7:33 pm
Bob,
The old icons are in IMAGES_Standard, but by default you get CadFather's ones. Unfrotunately, this Plugin is still behind my others, and I don't provide an easy option to switch between icon collections.
If you have your owns, drop them into the IMAGES_CadFather folder.
The convention is _24 and _16 for large and small icons.
User avatar
PluginStore Author
PluginStore Author
Postby watkins » Sun Oct 19, 2008 7:40 pm
Dear Fredo,
All working fine. Thanks for everything.
Regards,
Bob
watkins
Postby Whaat » Sun Oct 19, 2008 9:47 pm
This is quality work Fredo. Thanks very much!
Whaat
PluginStore Author
PluginStore Author
Postby CadFather » Mon Oct 20, 2008 12:40 am
hats off for Fredo! :fro:
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby putnik » Mon Oct 20, 2008 2:09 am
Fredo6, much appreciated! Thanks for taking the time to put all the bits and pieces together.
putnik
Postby mateo soletic » Mon Oct 20, 2008 8:05 am
Thank You. :thumb:
mateo soletic
Postby CadFather » Mon Oct 20, 2008 8:29 am
...is there a way to divide a curve by an equal number of segments or am i talking a different plug in?
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby plot-paris » Mon Oct 20, 2008 9:08 am
thanks a lot fredo. it is great to find everything in one place. now I can be sure to have the latest version :thumb:
CadFather wrote:...is there a way to divide a curve by an equal number of segments or am i talking a different plug in?
interesting question indeed (although I believe we should just read your manual :) )
User avatar
plot-paris
Postby viga1978 » Mon Oct 20, 2008 9:15 am
Thank you
viga1978
Postby marne » Mon Oct 20, 2008 9:22 am
Thanks Fredo, very useful! :thumb:
marne
Postby urs0815 » Mon Oct 20, 2008 10:10 am
great tool!
great update!
thank you!!!
urs0815
Postby CadFather » Mon Oct 20, 2008 10:35 am
plot-paris wrote:interesting question indeed (although I believe we should just read your manual :) )
you're right there PlotParis, i do read 'too fast' sometimes.. :mrgreen: so i went and reread it but what i am looking for is not the precision parameter (think that's what you mean) - rather a way of dividing the spline.. perhaps like we do for a simple line (right click, divide) or by input box.
when i change the precision points and then explode the curve - the split segments do not match the change.
the idea is to use the bezier curve for flightpath - the option of changing the division would give a handle on smoother frame transitions etc..
am i on a path?
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby plot-paris » Mon Oct 20, 2008 10:54 am
CadFather, I have to admit, I didn't mean anything. just had the situation several times, that I was looking for some function with fredo's plugins for hours - but everything was explained in detail in his superb manuals :)
ah, I see, you want to use it for flightpath. I think to have an even distribution of segments is not necessary, for flightpath automatically adjusts each scene transition time to match a constant speed (at least flightpath2 does it).
I tend to reset these modified times to default (with the TimeTransitionEditor script of the Presentation bundle (14$ at smustard) so that I can influence the animation speed with differing segment distribution along the curve...
but nonetheless I would appreciate a tool that creates an even distribution of segments throughout the whole curve. would come in quite handy sometimes. if you extrude the shape to have a curved wall for example. if all the segments are the same length it is far easier to use the same window component on this wall...
User avatar
plot-paris
Postby johnsenior1973 » Mon Oct 20, 2008 11:16 am
Thanks for this great plugin.
For me, one of the huge benefits is that it is now possible to draw much better with Sketchup. The normal Freehand draw tool in Sketchup is, quite frankly, pretty much useless. Now there's no need to use the Freehand tool, the Cubic Bezier Curve works so much better.
johnsenior1973
Postby CadFather » Mon Oct 20, 2008 4:04 pm
yes... at the moment i am doing exactly the same with PresBundle - but suppose you have a path with curves, knowing the constant segment of each camera can be useful.. (i'd love the same ease as 'divide')
when you reach the curve, splitting in two gives half transition time without having to try it out first
another use is the copy along path, since it behaves a bit different when copying by spacing and by nodes.. surely more would follow.. interesting.. hope Fredo's loves the idea too.. for now this is all Fredo Grace! :enlight:
..and thanks for the manual! ;)
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Oct 20, 2008 4:48 pm
The answer should be YES.
If you have a curve, generated by BezierSpline or from native Sktechup, you can convert it to a Polyline with equal segments by 2 methods which are delivered as part of BezierSpline (via the contextual menu "Convert to":
1) Polyline Divider: you specify the interval, and the extension computes the number of segments
2) Polyline Segmentor: you specify the number of segments, and the extensions computes the length of segments
Note that all segments will be equal, except possibly the last one (but you can adjust the last vertex anyway).
Here is an example: On the left is a regular B-Spline. On the right, the curve converted by PolyLine Divider. You can modify the interval by typing TAB and setting the value in the dialog box appearing.
Hope this helps
User avatar
PluginStore Author
PluginStore Author
Postby CadFather » Mon Oct 20, 2008 4:58 pm
Many Thanks Fredo ..that will do just fine for now. :thumb: :D
(think i'm going to make a request for curve divider)
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby plot-paris » Mon Oct 20, 2008 5:08 pm
fantastic, fredo! it is really great. every time I am looking for some function of your bezier curve tool, it already exists.
(and surely we would have found out ourselves, if we read your manual carefully :D
what do we learn from that? READ FREDO'S MANUALS!!!)
User avatar
plot-paris
Postby CadFather » Mon Oct 20, 2008 5:49 pm
..and he actualy writes them really well! :lol:
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby cyan.archnet » Wed Oct 22, 2008 3:03 am
THANKS A WHOLE LOT for the update!
cyan.archnet
Re: [Plugin] BezierSpline v1.21 - Comprehensive Refresh
Postby otb designworks » Wed Oct 22, 2008 12:49 pm
Thanks! Your plugins are awesome and quite appreciated, not to mention as useful as anything in SU.
Cheers, Chuck
OTB Designworks is on Youtube
otb designworks
Postby flyashy » Thu Oct 23, 2008 10:04 am
Again, Thank You!
Ashy
flyashy
Postby chrischancc » Thu Nov 06, 2008 2:19 pm
so a gorgeous plugin!!
chrischancc
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
cron
Who is online
Users browsing this forum: aguja98, Bing [Bot], Google Bot, winglory and 10 guests
Visit our sponsors:
