The Rescue (NPR)
• Page 1 of 1
The Rescue (NPR)Hi, this is rendering practice that was made only with default SketchUp Rendering Options found in Style menu by exporting a series of scenes which then were imported in Photoshop to mix them together. After some effects another program called FotoSketcher was used to make it look more NPR. I only rendered this scene and not modeled the castle. This was modeled by LordGood and you can find it on Trimble 3D Warehouse here... http://sketchup.google.com/3dwarehouse/ ... revstart=0 Hope you like it and if you have any feedback please share it with me...thanks! ____________________________________________________________________ SketchUp Scenes Settings: Color Scene Fog = off Shadow Settings: >> Use Shadow = false >> Light = 0 >> Dark = 100 >> Use sun for shading = true Styles: >> Edges = False >> Face Settings = Display shaded using textures. (Shaded with textures) >> Background Settings = [Background = White , Sky = false , Ground = False] Shadows Scene Fog = off Shadow Settings: >> Use Shadow = true >> Light = 100 >> Dark = 0 >> Use sun for shading = true Styles: >> Edges = False >> Face Settings = Display shaded using all same. (Monochrome) >> Background Settings = [Background = White , Sky = false , Ground = False] Aplha Channel Scene Fog = off Shadow Settings: >> Use Shadow = false >> Light = 0 >> Dark = 100 >> Use sun for shading = true Styles: >> Edges = False >> Face Settings = Display shaded using all same. (Monochrome) >> Background Settings = [Background = White , Sky = false , Ground = False] Note: Also make Front color = White and Back color = White ZDepth Scene Fog = on >> Use background color = true (Make it Black) Shadow Settings: >> Use Shadow = false >> Light = 0 >> Dark = 100 >> Use sun for shading = true Styles: >> Edges = False >> Face Settings = Display shaded using all same. (Monochrome) >> Background Settings = [Background = White , Sky = false , Ground = False] Note: Also make Front color = White and Back color = White Last edited by renderiza on Fri Jun 21, 2013 5:44 pm, edited 1 time in total.
Re: The Rescue (NPR)Where are the images of rendering ?
![]() And Fotosketcher is a crazzy free good program! (made by a Frenchy guy ![]()
Re: The Rescue (NPR)Fotosketcher is crazy good Pilou, so is Dynamic Auto Painter, check it out.
http://www.mediachance.com/dap/index.html Re: The Rescue (NPR)seems cool too, a little more pricey
The free trial does not expire, I've been playing with it for over a year now. Re: The Rescue (NPR)
I edited the main post to include the four images exported from SketchUp with a summery of the settings used.
I didn't know about "Dynamic Auto Painter" seems great!...I'll give it a try. ![]() Thanks, Renderiza
• Page 1 of 1
