SketchUcation Premium Membership
Sample Model for Rendering
Postby Al Hart » Thu Jul 12, 2012 5:56 pm
We are posting some models to the 3D Warehouse to use as sample models for rendering.
Take a look at this one: Interior Conference Room Sample Model
Add some rendering parameters, render it with your favorite renderer and post the results here, or send them to me at al.hart@renderplus.com.
It is OK to add materials, backgrounds, and other rendering settings - but do not add or change geometry - unless there is something stupid wrong with the original model.
When you post it here or send it, let me know if it is OK to post your image on SketchUpRendering.com. I will place some good examples from various rendering packages on that site. Include any other useful information - name of rendering package, special effects used, etc. Let me know what credit I should put on your image: (Rendered by...)
Al Hart
IRender nXt from Render Plus
User avatar
Al Hart
Render Plus Systems
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Advanced
Re: Sample Model for Rendering
Postby Al Hart » Fri Jul 13, 2012 1:18 am
I ran this through IRender nXt.
Reflections were added to the ceiling, Index of Refraction to the glass table top and lights behind the light grids.
100 passes - about 2 hours rendering time.
Al Hart
User avatar
Al Hart
Render Plus Systems
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Bryan K » Fri Jul 13, 2012 10:39 pm
This looks interesting. I'll post something this weekend.
Some quesitons:
My rendering program may not recognize the existing lights. Can I add them if needed as long as they are exactly where the originals are placed? If so, what are the general settings? Omni? Directional? Brightness? Is the exterior lighting a "sun" or more lighting?
Thanks.
User avatar
SketchUp version: 8
License type: Free/Make
SketchUp use: product design
Level of SketchUp: Intermediate
Postby Al Hart » Sat Jul 14, 2012 2:17 pm
Thanks for giving this a try. You can add lights, replace the lights, etc. depending on how your rendering program works.
I didn't create this model - but I believe the lights are either a face set to emit light, or a "ceiling light" placed behind the grids of the ceiling. It is probably marked as directional pointing down, but if it is behind the grid, then onmi-directional would work as well. You should choose the brightness what works to get the proper balance of sun, sky and lights, or go for a night time scene, etc.
In the rendering I created I the sky was on but not the sun. However, you are not trying to produce the same rendering, but rather to show a rendering you could get from the same model - for instance a rendering which would be good to show a client for whom you were designing this room. For instance you could make more, or different materials reflective, and have different reflection settings. The purpose of this thread and/or the SketchUpRendeirng.com site, where we will post these images, is to show SketchUp users the value of using add-on rendering packages to improve the quality and value of SketchUp models and images for internal or client presentations.
Al Hart
User avatar
Al Hart
Render Plus Systems
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby teknikarsitek » Sun Jul 15, 2012 6:14 pm
here is my test .. using vray for sketchup ..
hope u like it
teknikarsitek
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Ollo81 » Sun Jul 15, 2012 8:52 pm
Here is my first attempt to render this scene with Thea. So far I'm not too happy with the door area and its lighting. CC are welcome.
Ollo81
Postby JCA131 » Sun Jul 15, 2012 10:04 pm
I hope I'm not outside of the rules by creating all new materials instead of just editing the materials from the original model.
Twilight Render and Photoshop
JCA131
Postby jason_maranto » Mon Jul 16, 2012 1:56 pm
Here's a whack at it with Maxwell -- I tried to make the least amount of changes possible, but I did opt to use a free sample HDR for the background from http://www.hdri-locations.com/ for a more subdued tone. I used the Maxwell "Simulens" effects at the end for a bit of bloom and whatnot.
I'll probably take another whack at it with more custom materials and add some lights.
Best,
Jason.
User avatar
jason_maranto
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby oganocali » Mon Jul 16, 2012 6:42 pm
Render at noon, no background. vray + gimp(for contrast+brightness adjustment). I only added a few reflective layers and studio lights.
User avatar
oganocali
Postby Carloh » Mon Jul 16, 2012 7:07 pm
here my quick attempt using lumion free version. some of the materials are from the maxwell material library.
User avatar
Carloh
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby Al Hart » Mon Jul 16, 2012 11:50 pm
Carloh wrote:here my quick attempt using lumion free version. some of the materials are from the maxwell material library.
Is it OK to upload this to the SketchUpRendering site, and mention you as the contributor?
If you re-render it later, we can update the image on that site as well.
Al Hart
User avatar
Al Hart
Render Plus Systems
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Carloh » Tue Jul 17, 2012 8:57 am
Sure, that would be really nice! Just make sure you don't take any commercial advantage of this image as the lumion free version is for non-commercial use only. :)
User avatar
Carloh
SketchUp version: 8
License type: Pro
Postby jo-ke » Tue Jul 17, 2012 10:21 am
twilightrender setting 02 low
used the materials in model, added some bump, lights and background
removed backfaces in chairs
little correction in PS
User avatar
jo-ke
Premium Member
Premium Member
SketchUp version: 7
SketchUp use: interior design
Postby MrMikeEsq » Tue Jul 17, 2012 10:54 am
Carloh, what was the render time?! ;) :lol:
MrMikeEsq
Postby Carloh » Tue Jul 17, 2012 11:15 am
MrMikeEsq wrote:Carloh, what was the render time?! ;) :lol:
something between 10 and 15 seconds :D
User avatar
Carloh
SketchUp version: 8
License type: Pro
Postby jo-ke » Tue Jul 17, 2012 12:02 pm
and another one
twilight render preset 9
27 passes for 1,5 hours
User avatar
jo-ke
Premium Member
Premium Member
SketchUp version: 7
Postby jason_maranto » Tue Jul 17, 2012 1:21 pm
Here's another shot with Maxwell using some of my Arroway and RAL materials -- I also added more lights and re-arranged the existing ones slightly. I'm not sold on the floor I used, I may do another version at some point.
Also I really think this model needs more details, like baseboard/trim and electrical sockets to be a bit more interesting/realistic.
Best,
Jason.
User avatar
jason_maranto
SketchUp version: 8
License type: Pro
Postby jo-ke » Tue Jul 17, 2012 3:04 pm
another one, just for fun. Added my wife and myself
twilightrender preset 9 2,5h, 43 passes
User avatar
jo-ke
Premium Member
Premium Member
SketchUp version: 7
Postby macmac12 » Tue Jul 17, 2012 8:10 pm
here's my render, using vray for sketchup.hope you like it.
Uploaded with ImageShack.us
macmac12
Postby mwm5053 » Tue Jul 17, 2012 10:37 pm
The wife and girl friend. :berserk:
I stayed at home to do the rendering. Kerkythea Photomap high+ AA 0.03. I'll let it bake tonight and see any better quality at least with the lights.
mwm5053
Premium Member
Premium Member
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby Al Hart » Wed Jul 18, 2012 3:10 pm
macmac12 wrote:here's my render, using vray for sketchup.hope you like it.
Nice background, reflective chair legs and other materials
Al Hart
User avatar
Al Hart
Render Plus Systems
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby macmac12 » Wed Jul 18, 2012 4:43 pm
thank you sir.
macmac12
Postby Elibjr » Fri Jul 20, 2012 9:06 am
Here is my attempt. This was a 2 and a half hour render with 19 passes using the packet render in version 4 of IRender nXt. I used 4 lighting bounces 2 refraction and 2 reflective bounces. I wanted to create a slightly smokey space so I used the tone editor to bring up the contrast and lower the brightness and Saturation. Then I used the Nxt-image editor to add sharpen, change the lighting channels to emphasize the artificial lights I added a small about of dark grey haze and blur to the opposite end of the room for effect. I then added a bump map to the wood. I changed the light fixtures to match the color scheme; and changed the material on the chairs to a 'metal' I also made the glass on the table a little more translucent and misty. I hope you like it. :sketchstatic:
Elijah (Elibjr)
User avatar
Elibjr
Premium Member
Premium Member
SketchUp version: 8
Postby Al Hart » Fri Jul 20, 2012 2:59 pm
Elibjr wrote:Here is my attempt. ... I hope you like it. :sketchstatic:
Elijah (Elibjr)
Thanks Elijah - I have posted this and most of the other images on SketchUpRendering.com
Everyone - If you get a chance, take a shot at the swimming pool scene:
Al Hart
User avatar
Al Hart
Render Plus Systems
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby ccs1987 » Sat Jul 21, 2012 1:59 pm
i saw some Kuala lumpur HDRI there. haha i am from Kuala Lumpur
Sketchup 8 pro
Vray
Intel Xeon W3520 2.67Ghz
12Gb Ram
Nvdia Quadro FX 1800
ccs1987
Postby Nat1 » Tue Jul 24, 2012 10:47 am
Here is the scene rendered using SU Podium, I used the interior high preset and it took 3hrs and 45 minutes but this was a large image size of 6400x3030 I have cropped it and down sized the image so I can attach here, it would have been much faster to render at a smaller size. New textures have been added from the Podium Material Library/Browser. Levels have been adjusted in Photoshop.
Nat
iMac 27" 3.4GHz Quad Core Intel i7 16GB RAM SSD
AMD Radeon HD 6970M 2GB GDDR5
User avatar
Nat1
SketchUp version: 7
License type: Pro
Postby Carloh » Tue Jul 24, 2012 11:20 am
that's a nice one nat! :thumb:
User avatar
Carloh
SketchUp version: 8
License type: Pro
Postby micione » Wed Jul 25, 2012 7:46 pm
Two attempts with Reditioner. First, only added a few comments and artificial light. Second, changing materials, reflections, bump. Rendering time: 5 minutes.
User avatar
micione
SketchUp version: 8
License type: Pro
Postby john2 » Mon Sep 17, 2012 8:01 am
oganocali wrote:Render at noon, no background. vray + gimp(for contrast+brightness adjustment). I only added a few reflective layers and studio lights.
hey ogano! i like your thick glass, is it a vray two sided material? :thumb: :)
Google SketchUp Pro 8, Vray 1.49, Windows 7 – 32 bit
john2
Postby regnar » Sat Oct 13, 2012 2:05 am
Here is a render created in Shaderlight 2.3.1, rendering took 2.75 hours
at a quality setting of 8. Used HDR for the lighting & background.
Dan
regnar
SketchUp version: 8
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Next
Return to Gallery
Who is online
Users browsing this forum: No registered users and 3 guests
