by solo » Thu Feb 09, 2012 8:24 pm
Just a whim of an idea to kick start an easy challenge, model and render a glass block, sounds simple right?
And it is, but there are many ways to do this and lets see which works best and looks best. Feel free to try anything, go simple, or go crazy detailed, have a simple clear one or patterned, choose heavy glass, clear glass or even frosted glass, just have fun.
My site Quod gratis asseritur, gratis negatur.
solo
- Global Moderator
- Name: Pete Stoppel
- Operating system: Windows
- SketchUp version: 2013
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Advanced
by solo » Thu Feb 09, 2012 10:17 pm
First go, I did this with just mesh, no bump, used Artisan to create inside warped mesh.
Quick Thea render, crepe myrtle tree behind used to show glass warping effect.
Click on image for larger view
Please, register (free) to access all the attachments on the forums. My site Quod gratis asseritur, gratis negatur.
solo
- Global Moderator
- License type: Pro
by chedda » Fri Feb 10, 2012 7:26 am
Looks excellent Solo. Although they do repeat. You also need the mortar around the block.I guess my other thread is my submission for this challenge.
Kraken Wrangler
chedda
- Name: Simon
- Operating system: Mac
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
by oganocali » Fri Feb 10, 2012 2:03 pm
oganocali
- Name: Ogan
by solo » Fri Feb 10, 2012 2:30 pm
Ogan, Those are great but they are not glass blocks, but glass panes.
These are glass block sizes:
Inch sizes (actual dimensions, in inches) 5¾ × 5¾ × 3 7⁄8 7½ × 7½ × 3¼ or 4 7¾ × 7¾ × 3 7⁄8 9½ × 9½ × 3 1⁄8 11¾ × 11¾ × 3 7⁄8 or 4 inches
Metric sizes (nominal dimensions, in millimeters) 160 × 160 × 30 190 × 190 × 80 or 100 240 × 115 × 80 40 × 240 × 80
solo
- Global Moderator
- License type: Pro
by oganocali » Fri Feb 10, 2012 2:35 pm
Oppps  sorry. Here is 160x160x30 mm version. vray bumpmapped pure glass with texcloth. glassbumpmap.jpg
oganocali
- Name: Ogan
by Cyberdactyl » Fri Feb 10, 2012 4:23 pm
Hi everyone. As you explore refraction with your rendering software, I urge you to look at it deeper than merely the image you want from behind the glass.
Cyberdactyl
by Hieru » Fri Feb 10, 2012 5:04 pm
That's really interesting and gives me an idea for a scene/model/render.
Hieru
- Premium Member
- Name: Hieru
- License type: Free/Make
by chedda » Sat Feb 11, 2012 7:24 pm
Here you go Solo, i polished it up a little but i still see geometry in the corners, meh good enough.
Please, register (free) to access all the attachments on the forums. Kraken Wrangler
chedda
- Name: Simon
- License type: Pro
by Hieru » Sat Feb 11, 2012 8:00 pm
Looking really good You know you've been overdoing it in Sketchup when the first thing you do when looking at a render is try and orbit to get another view - doh!
Hieru
- Premium Member
- Name: Hieru
by chedda » Sat Feb 11, 2012 8:28 pm
Thanks Hieru , CG produces strange effects in operators, I get quite introverted I need the radio to stay sane. I had strange scenarios in the outside world after too much battlefield (PS3)
Kraken Wrangler
chedda
- Name: Simon
- License type: Pro
by jpalm32 » Sun Feb 12, 2012 3:09 pm
Pittsburg Glass has SU components & SW for this.
jpalm32
- Premium Member
- Name: John
by dale » Mon Feb 13, 2012 2:31 am
Took a stab at it, and it had some definite challenges. But it was fun. Glass block via Artisan. Rendered in Thea.
Please, register (free) to access all the attachments on the forums. Just monkeying around....like Monsanto
dale
- Top SketchUcator
- Name: Dale Stephens
- License type: Pro
by stefanq » Mon Feb 13, 2012 11:32 am
I did a render long time ago, but I didn't used a glass brick model. It's just a wall( probably out of scale) but it worked for me. Here is the rendering, and the textures I used:
stefanq
- Name: Stefan
by chedda » Mon Feb 13, 2012 11:37 am
Looking good Dale ! Stefanq also good considering it's only textures, is it just 2 faces or do you have internal faces ? Thanks for the textures.
Kraken Wrangler
chedda
- Name: Simon
- License type: Pro
by Hieru » Mon Feb 13, 2012 1:59 pm
I'm still working on mine - I got distracted modelling this - but there are some really ingenious texture only solutions over at the Thea forum.
Hieru
- Premium Member
- Name: Hieru
by dale » Mon Feb 13, 2012 3:58 pm
Thanks chedda. I also played with this diamond block, but abandoned it as I wanted to "suggest"the figure in the shower, and the diamonds just refracted the image too much. Even the one posted above is not quite subtle enough. Too me this is where it got interesting as using a straight thin glass was too clear, and using a clear glass material had mixed results. I ended up adding a thin film layer in Thea. Hope I get more time to play on this as it is an interesting challenge depending on what you want too see through the refractions. Here is the diamond block image, and the .skp if anybody can ever use it. Glass block diamond 1.png Glass Block Diamond.skp And here is the wave style.
dale
- Top SketchUcator
- License type: Pro
by dale » Mon Feb 13, 2012 4:02 pm
Hieru wrote:I'm still working on mine - I got distracted modelling this - but there are some really ingenious texture only solutions over at the Thea forum.
Seriously cool lamp! Hope you finish the model. I wonder how using textures v/s modeling mesh alters refracted images behind the block. hmmmm... Hope to get some time to play.
dale
- Top SketchUcator
- License type: Pro
by solo » Thu Feb 16, 2012 8:58 pm
Another one, this time I used a scene provided by TomDC, first is the original render (Thea BSD) with only one light source (open door) HDRI and second is when a wall is replaced with Glass bricks, incredible amount of light gets sucked through glass wall.
solo
- Global Moderator
- License type: Pro
by TomDC » Thu Feb 16, 2012 9:10 pm
The first one has issues (then, so do I  ), but the second one looks great. How long did these render for?
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
TomDC
by solo » Thu Feb 16, 2012 9:18 pm
The first one rendered for 12 minutes plus some change at 1200x600 default BSD settings The second was 33 minutes with a different preset (one of my optimised for thick glass interiors)
solo
- Global Moderator
- License type: Pro
by TomDC » Thu Feb 16, 2012 11:10 pm
I'm rendering this interior with TR1 as we speak. At 6000 pixels wide and supersampling set at 'High'. Wonder how long that one'll take.  Ah, if only unbiased rendering were fast -we'd never have to worry about thresholds and the like again.
TomDC
by solo » Thu Feb 16, 2012 11:17 pm
Yikes dude! That's an overkill, I'd suggest rendering at size needed and at normal super sampling, that will give a great result, or even high super sampling if you want perfection, but 6000 is crazy. Unbiased is fast, if you have enough cores or a render farm.
solo
- Global Moderator
- License type: Pro
by TomDC » Thu Feb 16, 2012 11:26 pm
solo wrote:Yikes dude! That's an overkill, I'd suggest rendering at size needed (...)
That is the size needed. It's a test to see how fast TR1 can deliver me images for printing. And er, you're speaking to someone who's rendered as wide as 20000.
TomDC
by solo » Thu Feb 16, 2012 11:31 pm
TomDC wrote:solo wrote:Yikes dude! That's an overkill, I'd suggest rendering at size needed (...)
Have you got one of those pesky 24 core 100 plus GB ram rigs? as 20000 wide it beyond anything i could imagine, planning to put a render on the side of a building?
solo
- Global Moderator
- License type: Pro
by TomDC » Thu Feb 16, 2012 11:36 pm
Nope, same old Mac Pro. A test I did a few years back.
TomDC
by Hieru » Thu Feb 16, 2012 11:40 pm
The other week I tried a 6000px by 3000px TR1 (high supersampling) render for a 360x180 panorama test. I gave up after 12 hours and realised that I needed to get my head around biased render settings. Luckily your interior with thick glass preset worked really well Solo. And back on topic - really nice scene. Would be perfect if you randomly rotated and reversed some of the blocks for variation. I can't wait to get back on track with my scene, but this week has been hell  .
Hieru
- Premium Member
- Name: Hieru
by notareal » Sat Feb 18, 2012 10:14 am
solo wrote:I'm rendering this interior with TR1 as we speak. At 6000 pixels wide and supersampling set at 'High'.
Supersamling high is good if you are going to render something to HD sizes or smaller. Not much use with high resolution renders used in posters or if you going to down scale them later. Perhaps some high precession printing can benefit from it.
notareal
- Thea Render
- Name: notareal
by Hieru » Tue Feb 21, 2012 9:45 pm
I still haven't had chance to do much work on this, but here's a quick teaser of one of the elements I want to use in conjunction with the glass blocks.
Hieru
- Premium Member
- Name: Hieru
by sepo » Wed Feb 22, 2012 10:18 pm
Very nice feel to the render...but what happened to caustics? Shouldn't be some on the floor, right?
sepo
- Name: sepo
- License type: Pro
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp. Premium Members get 20% discount!
- Robot
Return to Gallery
