Introducing Viz - parametric modeling for SketchUp
Postby fluid » Fri Feb 26, 2016 6:41 pm
We just released an early beta of Viz, our parametric modeling extension for SketchUp.
If you want to give it a try, you can download it here.
Please keep in mind it's an early beta, it might have bugs, and it supports only SketchUp 2013/2014/2015/2016 on Windows.
Any suggestion or feedback is welcomed.
7
fluid
Re: Introducing Viz - parametric modeling for SketchUp
Postby Pixero » Fri Feb 26, 2016 6:51 pm
:o :enlight: :thumb: :thumb: :thumb:
OMG!
I love you!
:D :D :D
One of my highest hopes for SU comes true.
Pixero
Postby Pixero » Fri Feb 26, 2016 7:01 pm
Ouch.
I get a instant bug splat when clicking on "Start Viz" in a empty scene.
I'm on SU 2016 Windows 8.1 64 bit.
Pixero
Postby JQL » Fri Feb 26, 2016 7:18 pm
I'll be damn!... I love you too... I'll try bugsplatting too...
JQL
Premium Member
Premium Member
Postby jiminy-billy-bob » Fri Feb 26, 2016 7:32 pm
:o :shock:
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby JQL » Fri Feb 26, 2016 7:38 pm
I had the same bugsplat as Pixero.
Win 10 SU 2016 Pro 64bit
EDIT: I still love you... but I hope you can fix it!
JQL
Premium Member
Premium Member
Postby pilou » Fri Feb 26, 2016 9:27 pm
Works fine for me :)
Better if you have 2 screens! ;)
Window 8.1 64 bits SU 2016 Make
Now a little new headache for make something with nodes mood! :mrgreen:
Speedy Galerie
Top SketchUcator
Postby fluid » Fri Feb 26, 2016 10:23 pm
Just uploaded a new version, fingers crossed...
fluid
Postby JQL » Sat Feb 27, 2016 12:06 am
Playing with it! You can uncross your fingers! Going to rewatch the videos so I can know what to do with this 1m cube
JQL
Premium Member
Premium Member
Postby pilou » Sat Feb 27, 2016 12:47 am
New version is always living! :)
But nodes are not an evident thing! :mrgreen:
Speedy Galerie
Top SketchUcator
Postby cesaro36 » Sat Feb 27, 2016 1:16 am
:o :o :o Awesome!
cesaro36
Premium Member
Premium Member
Postby JQL » Sat Feb 27, 2016 1:26 am
pilou wrote:New version is always living! :)
Yup, nodes names are hard to read and relate to functions.
I was searching for an array tool and I found a lot of array functions that get the max and min value of an array, but I had an hard time finding the array.
JQL
Premium Member
Premium Member
Postby pilou » Sat Feb 27, 2016 2:28 am
Nodes is a very powerful work function but no sure that is the more simple thing!
There is so much connections, possibilities, that is a real jungle! :)
That is in fact an hidden coding! ;)
Grasshopper is the Rolls Royce of that! The Bible :)
Speedy Galerie
Top SketchUcator
Postby Pixero » Sat Feb 27, 2016 9:27 am
The version 1.02 works but I'm having some problems getting the window to stay on top of SU.
Sometimes it refuses and ends up under the SU window which is a bit frustrating.
A larger/re sizable node window and some node categorization would be great but I guess it's coming?
More nodes wanted too. Different noises and cellular patterns for example.
Is there a way of using an image as input? For for example height based on gray scale values.
And curves. We need curves.
Any way of creating custom nodes apart from functions?
I like that the nodes have built in value sliders so you wont need to create every single input node by hand. :thumb:
Are there cases where a output node (Geometry sink) wont be used? If not maybe it's a good idea to have the output node always in the editor?
Looking good and very fun to work with. Great job so far. :D
Pixero
Postby Pixero » Sat Feb 27, 2016 9:38 am
Another thought, what if there were categories like "Math" or "Array" that incorporated all/several math functions and let you choose which function from a drop down menu on the node as a way of having less nodes to search through.
That way it would also be easy to quickly try different nodes like "add" or "multiply" to see the result.
Is it possible to have "triangulate" with options to the direction of the triangulation?
Also it would be great if it supported Thomthoms Quads for easy texturing.
Pixero
Postby Pixero » Sat Feb 27, 2016 10:25 am
I have a feeling a Beta forum would be a good idea as there probably will be lots of questions and suggestions. Better to have several topics than just one.
Pixero
Postby alexschreyer » Sat Feb 27, 2016 12:36 pm
Superb! Can't wait to try this out.
Author of "Architectural Design with SketchUp":
http://sketchupfordesign.com/
alexschreyer
PluginStore Author
PluginStore Author
Postby JQL » Sat Feb 27, 2016 12:36 pm
Pixero wrote:I have a feeling a Beta forum would be a good idea as there probably will be lots of questions and suggestions. Better to have several topics than just one.
That would be my main suggestion and I think Rich could set you up here.
Following on the slider's subject, I like them but they return huge values.
I have a 1m cube and translation slider slides easily up to 14000m so values ranging 1m 10m or 0.5m are impossible to tune with the slider.
I also agree on categorization, and I think it would be worth it to have some icons in the future as people doing graphic modelling, could probably relate nicelly with that.
I'm using Substance Designer on a regular basis and visuals of their nodes work nicelly there.
They have color separation by set of nodes.
In this case I can't tell yet what categories there are, but some are geometry creators, some are modifiers some are functions, so there should be something to start with.
Also, on the node workflow itself, something I feel it's lacking is a faster way to replace inputs. If I drag a vector into an input that is already used it does nothing and I would expect it to replace it.
Also changing a big amount of output lines from one node to another node would be great.
Here's a gif for clarifying what I'm talking about:
JQL
Premium Member
Premium Member
Postby fluid » Mon Feb 29, 2016 11:21 am
Thanks for all the feedback! Rolling up the sleeves for next version...
There is a lot of new nodes to be added, and node categorization too.
@Pixero:
- What do you mean for "Any way of creating custom nodes apart from functions?"
- Look at the Fx node for math for a list of math functions
- Image inputs will be added soon
- There are cases when you need multiple geometry sinks, and cases when you need none, for now probably it's a good idea to let the user choose
@JQL: we'll add sliders so you can set the range/numeric type, as well as a way of quickly replacing connections
fluid
Postby pilou » Mon Feb 29, 2016 1:30 pm
Will be a free product ?
Speedy Galerie
Top SketchUcator
Postby juju » Mon Feb 29, 2016 1:32 pm
so this , in essence, rhino/grasshopper for SU?
expected retail price?
juju
Premium Member
Premium Member
Postby Pixero » Mon Feb 29, 2016 1:42 pm
fluid wrote:- What do you mean for "Any way of creating custom nodes apart from functions?"
Case A:
A user conects some nodes and decides he wants to reuse them.
A sort of "grouping" of nodes for later use.
Case B: A user has some custom made node (like a cellular noise for example or something completele different).
It would be great if the community had the possiblility to expand with "plugin" nodes.
Pixero
Postby Pixero » Mon Feb 29, 2016 1:50 pm
Is copy possible yet?
Are you planning ways to get reports from the plugin?
I think it would be great if you could combine some nodes and have a drop down menu to chose from something like this.
Pixero
Postby fluid » Mon Feb 29, 2016 6:29 pm
It will be a paid extension, but we don't have a retail price yet.
@Pixero:
- It will be possible to group nodes into a single node for reuse, and to share nodes created in that way with other Viz users.
- Copy is not implemented yet, but it will be available soon
- There will be ways to get reports from the plugin, as well as save files with data
- If I understand correctly the Add example you provided, there is a similar functionality in Viz with the node "Fx"
fluid
Postby Pixero » Mon Feb 29, 2016 8:17 pm
fluid wrote:- If I understand correctly the Add example you provided, there is a similar functionality in Viz with the node "Fx"
What I meant was that you could have several math functions (for example) in the same node and a drop down menu to chose (for example multiply or add or divide).
A great way of having less nodes and a quick way if you want to test the different available math functions instead of having to create a new node and connect it every time you want to try a different function.
I'm sure other stuff could be grouped together into one node as well, like all vectors in one, all arrays in one and so on.
Less nodes to keep track of.
Faster workflow.
Pixero
Postby fluid » Mon Feb 29, 2016 8:42 pm
Something like this?
fluid
Postby Pixero » Mon Feb 29, 2016 10:10 pm
Yes but for more type of nodes. :thumb:
Pixero
Postby db11 » Tue Mar 01, 2016 12:29 am
This looks super-cool, but I can't try it out as it's Windows only :(
Any plans for an eventual Mac-compatible version?
db11
Postby fluid » Tue Mar 01, 2016 9:56 am
Thanks! We'll soon release a Mac version. At the beginning we want to keep it Windows-only to speed up iteration times
fluid
Postby DareDevil » Tue Mar 01, 2016 8:01 pm
Very cool idea !!!
I tested it and it's so nice... I'm frustrated, it's only a work in progress ;)
Some notices :
- can't make an array (other than random one) ; I thing is an essential node to test this kind of tool
- nodes have different behavior with array input : if I put an array on the Radius input of MakeCircle node, it make multiple circles ; if I put an array on the Translation input of Traslate node, it make single translation... I think if I put an array in one input, I must have an array output.
I will test further...
DareDevil
Next
Return to Extensions & Applications Discussions
Users browsing this forum: No registered users and 4 guests
