Batch Rendering with Maxwell
Anyone familiar with scrpiting in maxwell? especially batch rendering?basically, i have several MXI and their corresponding MXS files in a folder. i want to improve all their SL in stages, f.ex. from 2 to 5 and then the next day from 5 to 10. (when i am AFK, so batch is important). i tried the batch_render.ms script that was included, but it doesnt seem to resume the mxi files. instead it begins from 0 at each cycle.
the included script looks like this
// This script gets all the MXS files located in the folder "input" and its children // Opens them, changes their SL and resolution and launches each render // The output of all the images is stored in the folder "output" // The script also shows how to handle render events var inputFolder = "C:\Users\psw\Desktop\batch"; var outputFolder = "C:\Users\psw\Desktop\batch"; var engineVersion = Maxwell.getEngineVersion(); var mxsCount = FileManager.getNumberOfFilesInBranch( inputFolder, "*.mxs" ); var mxsList = FileManager.getFilesInBranch( inputFolder, "*.mxs" ); // Connect event RenderEvents["renderFinished()"].connect(renderHasFinished); var i = 0; var isRendering = 0; for( i = 0; i < mxsCount; i++ ) { renderScene(); while( 1 ) { if( isRendering == 0 ) { break; } } } ////////////////////////////////////////////////////////////////// function renderScene() { var mxsFile = mxsList[i]; var imagePath = outputFolder + "\" + FileManager.getFileName( mxsFile ) + ".png"; Maxwell.print( "rendering Mxs file: " + mxsFile ); Maxwell.openMxs( mxsFile ); Scene.setImagePath( imagePath ); Scene.setSamplingLevel( 3 ); isRendering = 1; Maxwell.startRender(); } ////////////////////////////////////////////////////////////////// function renderHasFinished() { isRendering = 0; Maxwell.print( "Render finished!!" ); } ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
i suck at coding, maybe there is just a command like "-resume"?
ok maybe i posted too premature, i got a solution after browsing the official maxwell forums, just use the script progressive_animation.ms and set the SL steps low
/close thread
Hi! I want to do the same, but render in a network. Dou you knkow how is the code?
