SketchUcation Plugin Store
LumenRT Microsoft C++ Visual Runtime Error - PLEASE HELP!!!
Postby patricktaft » Sat Apr 28, 2012 1:06 pm
Hi I am soon approaching a major deadline and I am having trouble with LumenRT2. Whenever I export my SKP model to LumenRT I am presented with an error: "Microsoft Visual C++ Runtime Library: This application has requested the runtime to terminate it in an unusual way.Please contact the application's support team for more information"
It does not happen with very basic models but this model is fairly complex. My machine is very competent (i7 2700k 3.5Ghz 16GB RAM GTX560ti) and breezes through the model in sketchup but when I export to Lumen RT when it reaches about 300 out of 4600 components the runtime error appears and sketchup is forced to quit. I have tried exporting this with my i7 macbook pro. It is also a high spec machine but nowhere near as competent as my PC and does struggle at times to deal with the model in SKP. But it is able to export to LumenRT successfully but when it is done, the mac struggles to run the live cube. I am able to then transfer the live cube to my PC, however, I am not able to then export as animation as it is not the machine it was originally created on.
The fact that I am able to export using my mac proves that it is not because Lumen RT cannot handle large complex models - but it is some sort of other software/driver issue with my windows setup. I am currently in communication with Lee Randall from e-on software however, I have not heard anything from him since a couple of days ago and my deadline is fast approaching. He suggested to run SKP as administrator which had no effect. I also uploaded my model to him using "sendittome.com" for him to have a go at but as I said I have heard nothing from him.
Any help would be greatly appreciated as I am really getting desperate now
Patrick
patricktaft
Re: LumenRT Microsoft C++ Visual Runtime Error - PLEASE HELP
Postby CadFather » Sat Apr 28, 2012 1:39 pm
i don't use LRT, so this is just a shot in the air. guessing you're running win 7 x64, have you got all the Visual C runtime updated?
VC 2010 x86: http://www.microsoft.com/en-us/download/details.aspx?id=5555
VC 2010 x64: http://www.microsoft.com/en-us/download/details.aspx?id=14632
VC 2008 x86: http://www.microsoft.com/en-us/download/details.aspx?id=29
VC 2008 x64: http://www.microsoft.com/en-us/download/details.aspx?id=15336
VC 2005 x86: http://www.microsoft.com/en-us/download/details.aspx?id=3387
VC 2005 x64: http://www.microsoft.com/en-us/download/details.aspx?id=21254
and have you purged the model of unused entities?
and are you using SU7 or 8?
Quarr-IT - SketchUp Training from the Master.. . ;) .
CadFather
Postby patricktaft » Sat Apr 28, 2012 2:29 pm
Hi thanks for your reply. I have tried several different installs of C++ versions including the one which is provided within the LRT package. Also, I have tried uninstalling all versions of C++ present on the machine and strangely it still triggers the same error even with not C++ even installed!
I am using SKP 8 Pro and yes have purged all unused. LRT gives you the option to export just the components/entities selected so I have tried selecting just the absolutely vital components and exporting them but still get the same error.
patricktaft
Postby CadFather » Sat Apr 28, 2012 2:38 pm
i presume have you tried all this logged on as administrator..
CadFather
Postby patricktaft » Sat Apr 28, 2012 2:48 pm
Yes I have tried running sketch up as administrator and my user account is administrator anyway. That is what the guy from e-on software initially suggested so I tried it delighted that I thought the problem was that simple but sadly that made no difference
patricktaft
Postby CadFather » Sat Apr 28, 2012 5:06 pm
without eon support, the only thing i can think of is a fresh win 7 install (.net + vb++ runtimes).. :roll:
very drastic and without promise, but because i have a clean install backed up with macrium free, it takes about 15 mins.
it has happened that things worked that way..
CadFather
Postby patricktaft » Sat Apr 28, 2012 8:43 pm
Thanks for the advice perhaps that will be the only solution. Before I do that however, I do have a friend who has a similarly spec'd PC. I may try and install LumenRT on his and load up my model and attempt to export and see if his does the same. If it does not then it looks like a fresh Win 7 is on the cards
patricktaft
Postby cmckillip » Tue May 01, 2012 7:45 pm
Patrick,
I have PMed you, downloaded your model and it hangs up on my machine also. There is something in the model that is hanging up LumenRT. The model is also very large, over 100 megs, sketchup gets buggy over 100 megs so you might remove something to reduce the space.
Chris
cmckillip
Postby MaloneXI » Wed Jun 27, 2012 7:07 pm
Hi ?
Any cure about this problem? I just bought lumen RT2 , and I got the same problem. I did all that could be done. I send the file to e-on guys , and they can open it.
I don't understand why...
And same for me , the model is more than 100 megs...
Don't understand the problem....
MaloneXI
Postby Pilou » Wed Jun 27, 2012 8:06 pm
That is very ennuyous for you :o
Speedy Galerie
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Advanced
Postby MaloneXI » Wed Jun 27, 2012 8:16 pm
Yeah uh ?
I don't know what to do ... totally lost lol
MaloneXI
Postby Nicholas Phelps » Tue Jul 10, 2012 6:42 pm
The problem is caused by the way Ruby handles memory in SketchUp (the problem is Windows only). Ruby runs in a 32 bit process, even if SketchUp itself is running in 64 bit, and if too much memory is allocated inside the Ruby script, Ruby crashes. It's totally unpredictable, and a known issue, apparently :-(
We are circumventing this problem in LumenRT 3 by creating a new (slower) export mode that does not allocate any memory inside of Ruby.
In the mean time, try reducing the size of your scene as much as you can.
Nicholas Phelps
e-on software
Postby MaloneXI » Wed Jul 11, 2012 10:03 am
Hi ,
first , thanx to have taken the time to answer :) I appreciate, really.
Next , I found the solution. I had a doubt seeing all the processes on my computer. And knowing my scene, that was not a poly number problem.
I remembered a thread were it was talking about the maximum size of the texture.
And that was the problem. I used 12000²px texture sized. Sketchup itself could'nt have threat such an info.
I resized the texture , and it worked.
So that was a texture size error. Working normally on big softawre like 3DS MAX , etc , I use to make big sized textures. So that was my fault.
Thanx a lot anyway for the anwser. And really good job for your software. Some lights artefacts problems persist, but globally it's a good job :)
MaloneXI
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Return to Extensions & Applications Discussions
