SketchUcation Plugin Store
render software advice
Postby davids90gt » Sun Feb 12, 2012 11:18 pm
I'm fairly new to this field and this is my first post on this forum. I'm looking for advice for rendering software. I work for a custom design/build landscape construction company and we are expanding into the 3d presentations. I've got a decent handle on sketchup (I'm working my way through "Google Sketchup for Site Design" by Danial Tal) but i'm looking for advice when it comes to rendering software. Obviously, I will be producing mostly exterior landscape designs with a lot of hardscaping and structures.
PS. This forum is an awesome source of info! I'll probably have a lot of other questions as i go along, but the rendering question is the most important right now.
Thanks,
Dave
davids90gt
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: landscape architecture
Re: render software advice
Postby TomDC » Mon Feb 13, 2012 1:01 am
Check out Vue and Thea.
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
TomDC
Postby Burkhard » Mon Feb 13, 2012 11:37 am
You will find a lot of informations and discussions here around.
Scroll down this thread.
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Level of SketchUp: Advanced
Postby Pilou » Mon Feb 13, 2012 1:00 pm
maybe this thread ? :)
What is your favorite render for SU ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby holmes1977 » Mon Feb 13, 2012 8:50 pm
I would go along with what Tom said. Thea and Vue are great choices. Avoid any render-er that works within Sketchup.
Because this will never be able to handle lots of high poly models. As you would use in landscaping.
Exaggeration makes a dull story better.
holmes1977
Postby davids90gt » Wed Feb 15, 2012 2:24 pm
Thanks guys for the response. I have been jumping into Kerkythea a little bit. Is there any reasons i shouldn't use Kerkythea? I also am looking at the demo version of Thea. I would love some feedback on the pros and cons of these programs.
I've worked with Dynascape software in the past and they are recommending shaderlight. From the looks of it, I can tell a huge difference between Shaderlight and Kerkythea. Can anyone explain the technical differences between the two and why Dynascape would be recommending it?
davids90gt
License type: Pro
Postby Schmeade » Wed Feb 15, 2012 4:48 pm
Hey Guys,
Shaderlights "Replace Me" tool allows you to load massively complicated components (such as the dynascape trees) into your model without killing SketchUp.
Replace Me works by having a low poly placeholder in your SketchUp scene and then when you hit render it is replaced with the high poly version.
Basically it means you get the benefits of both worlds, integrated rendering for a quick work flow and the ability to render very high poly models.
This video explains Replace Me better than I can.
http://www.youtube.com/watch?v=czKJfFVb85U
On 3D warehouse there is a bunch of Dynascape trees pre-made as Replace Me components that are ready to render in Shaderlight.
Hope that helps.
Schmeade
Postby solo » Wed Feb 15, 2012 4:51 pm
Schmeade wrote:Hey Guys,
Hope that helps.
In a nutshell, they have a collaboration, hence the endorsement.
My site
Quod gratis asseritur, gratis negatur.
solo
Global Moderator
License type: Pro
SketchUp use: other
Postby davids90gt » Wed Feb 15, 2012 5:16 pm
Yeah i watched a webinar on shaderlight, and they explained the "replace me" tool. Most of my projects will be landscape construction in someones backyard, so i probably won't have more than a few trees. I personally don't think that feature alone would be enough to buy Shaderlight.
Right now I'm more interested in what people have to say about Kerkythea vs. a paid program such as Thea.
davids90gt
License type: Pro
Postby Gaieus » Wed Feb 15, 2012 5:33 pm
Kerkythea and Thea - in many respects - are very similar. In fact, their developer is the same person. From a landscape designer's point of view, a big difference can be displacement which is not available in Kerkythea. If this is a smaller yard however, you can live without displaced grass and use grass instances that are supported in both. Also if just a couple of trees, they can also be added with no issues similar to SketchUp as they can handle high polygon meshes much better.
Administrator
License type: Pro
SketchUp use: historical reconstruction
Postby solo » Wed Feb 15, 2012 6:27 pm
a big difference can be displacement which is not available in Thea.
Huh!? you mean not available in KT right? as it is in Thea.
My site
solo
Global Moderator
License type: Pro
SketchUp use: other
Postby Gaieus » Wed Feb 15, 2012 6:49 pm
Yes, exactly, thank you Pete (I have corrected my mistake above).
Administrator
License type: Pro
Postby markitekt » Wed Feb 15, 2012 7:35 pm
I've had good luck with Twilight renderer for SketchUp which is also a stepchild of Kerkythea.
http://www.twilightrender.com/
markitekt
Postby Gaieus » Wed Feb 15, 2012 7:44 pm
Yes, Twilight, definitely. Especially for "starters". And you can export your model with all the settings already made to Kerkythea if you want more power (64 bit computing etc.)
Administrator
License type: Pro
Postby markitekt » Wed Feb 15, 2012 7:48 pm
I'm a bit of a newbie with the rendering stuff, but I was wondering what is "displacement"? Does it do a realistic job of materials like grass without having to instance it? What are good easy to use renderers that incorporate this?
Thanks,
Mark
markitekt
Postby davids90gt » Wed Feb 15, 2012 7:50 pm
Thanks for the input! I'm still a bit confused, why is kerkythea free, and what makes all other render programs worth what they sell for?
davids90gt
License type: Pro
Postby Gaieus » Wed Feb 15, 2012 8:05 pm
markitekt wrote:Does it do a realistic job of materials like grass without having to instance it?
More or less yes. It (somehow, don't ask me the technical details) does not only apply hadows and make a surface "bumpy" like a bump map but actually creates real geometry sticking out of the surface. Think of roof tiles, grass etc. (although displaced grass will never be as "real" as instanced but for mid distance, it is okay).
There are many renderers that can do that (like V-ray) but I only have experience with Thea in this respect. Here is a post over their forum where I used a single colour image (purely for testing reasons) as diffuse and a displacement map. Then there is the resulting roof below:
http://www.thearender.com/forum/viewtop ... 261#p34261
(Note that I suck at rendering).
Davids90gt wrote:I'm still a bit confused, why is kerkythea free, and what makes all other render programs worth what they sell for?
Well, Kerky is a bit exceptional, that's why it's free. :)
There are ones that's worth the price and there are obviously heavily overpriced renderers.
Administrator
License type: Pro
Postby markitekt » Wed Feb 15, 2012 8:06 pm
Guys like Solo and Gaieus are the experts on this stuff, but programs like Twilight at least make it easy for the novice like me to do very nice renderings quickly. There are many presets for setting up materials and lighting quickly which can be somewhat daunting if you don't have a lot of experience with it. Also it has the ability to do HDRI skies which is another feature that seems to be on the checklist. Cost is always a major factor since realistic rendering isn't a major priority for our daily architectural workflow. I am extremely impressed with some of the work I've seen on Solo's web site and I believe he uses several renderers including Thea, Twilight, and others. I'm interested in their opinions on what are good renderers based on what an individuals specific rendering needs are.
Mark
markitekt
Postby TomDC » Wed Feb 15, 2012 8:11 pm
Davids90gt wrote:I have been jumping into Kerkythea a little bit. Is there any reasons i shouldn't use Kerkythea?
I find its GI a little weak. But that shouldn't be a concern for you, as you do mostly exteriors. Let's see ... 64 bit, studio app, free render-ready tree models, instancing brush, free ready-to-use materials, helpful community, some good free tutorials, biased and unbiased rendering. Might be just the app for a beginner with your needs. Caveat: you won't get great results straight away. Don't be put off -learning to make a decent render takes a bit of practice, regardless of the app you're using.
In short: try Kerky for a year or so.
TomDC
Postby TomDC » Wed Feb 15, 2012 8:14 pm
Oh: don't choose a renderer over another because it does displacement. It's a nice feature and all, but it's terribly slow -in any app. And as Gai says, displaced grass doesn't look good.
TomDC
Postby Gaieus » Wed Feb 15, 2012 8:19 pm
markitekt wrote:Guys like Solo and Gaieus are the experts on this stuff, but programs like Twilight at least make it easy for the novice like me to do very nice renderings quickly...
ehm...
Gaieus wrote:(Note that I suck at rendering).
Anyway, it was also Twilight for me where I started to "feel" what I am doing.
Administrator
License type: Pro
Postby markitekt » Wed Feb 15, 2012 8:25 pm
ehm...
Don't underestimate your abilities my friend.
markitekt
Postby TomDC » Wed Feb 15, 2012 8:28 pm
Ah, Twilight. Related to KT. Any file exported by TW can be opened in KT. Twilight is easier to use than KT. Setting up materials is dead-easy.
So, what you may want to do, is set up mats and lighting in SU using Twilight, then export, and add render-ready trees from the KT site in KT.
TomDC
Postby Gaieus » Wed Feb 15, 2012 8:33 pm
markitekt wrote:Don't underestimate your abilities my friend.
Well, my renders always smell sweat. :D
TomDC wrote:So, what you may want to do, is set up mats and lighting in SU using Twilight, then export, and add render-ready trees from the KT site in KT.
Exactly, if you really need those high poly plants. I can often get away with billboards inside Twilight though. And as long as SU can handle them, Twilight has no more issues rendering component instances than Kerky. Also it can render stuff on hidden layers (what a Godsend!)
Administrator
License type: Pro
Postby dsarchs » Thu Feb 16, 2012 12:06 am
I'll jump in with my two cents.
I use Thea at work (architecture office) and Kerkythea at home (free). They both work very well/easily with sketchup and either would work just fine for you. If you don't mind paying a bit Thea is the better program (no surprise) but you might not need it.
There are plenty of differences between the two (active development not least) but the two main items I notice switching between the two are displacement and layers. Of these, layers is BY FAR the more important. Displacement is nice, and occasionally I do use it, but it depends on the type of result you're looking for.
Professionally, the images I'm trying to get are meant to show a compelling presentation of the proposed design to the city or a client. Reasonably believable materials and colors are important, as are good shadows (especially to show depth). Either program will do that just fine. Displacement makes for longer render times and more setup. Plus, if they're overdone they look as bad as if they weren't used at all. There are some real artists who use it in their renderings but are you showing closeups that honestly necessitate that detail (possibly) and do you want to spend the extra time required? For me it's rarely worth the time.
I tend to like "pretty good" renderings, that specifically establish the desired/required lighting and shadows, and then finish in post-pro (these are some great tutorials for that). It's faster and gives you good looking results, even if it's not PR.
About layers. When models start getting very large (usually when doing detailed exterior scenes) it's really nice to be able to turn off some variation of: the grass, the cars, the trees, the people, etc. It's such a basic feature but unless I've missed it you can't do that with Kerkythea.
Instead of displacing grass, I usually either use instances (very easy to do in either program) or post-pro as in the tutorial listed above.
Basically, get Thea if the expense makes sense for your business. Since you're just getting it, I imagine you've been doing fine without it in the past and this is just a new (very helpful) area. If that's the case, kerkythea is the way to go; if it works well then upgrade and the workflow if very similar.
Longer post than I intended. Sorry.
Knowledge is a polite word for dead but not buried imagination.
-e.e.cummings
dsarchs
Postby pbacot » Thu Feb 16, 2012 1:36 am
TomDC wrote:Ah, Twilight. Related to KT. Any file exported by TW can be opened in KT. Twilight is easier to use than KT. Setting up materials is dead-easy.
And can the same be said of Thea?
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby solo » Thu Feb 16, 2012 1:47 am
Yup, and even more. Then there is the progress in process which may soon give even more SU-Thea functionality in the near future.
My site
solo
Global Moderator
License type: Pro
SketchUp use: other
Postby Gaieus » Thu Feb 16, 2012 11:07 am
pbacot wrote:And can the same be said of Thea?
Well, Kerkythea xml files can be opened in Thea. So a Kerkythea xml file exported from Twilight after some material tweaks, can also be opened and although the material system is somewhat different, much of the settings get through and you need to tweak less in Thea.
This is of course not the "normal" way of doing it as the dedicated Thea exporter has a bunch of functionalities that the Twilight to Kerky exporter does not have (export model hierarchy for instance). But for a quick and dirty job, it works.
Administrator
License type: Pro
Postby notareal » Thu Feb 16, 2012 9:53 pm
Davids90gt wrote:Thanks for the input! I'm still a bit confused, why is kerkythea free, and what makes all other render programs worth what they sell for?
Kerkythea was born from enthusiasm and with active community it did grow in a point when entering into the commercial arena was only feasible option for further development. Even with a new born Thea Render, Kerkythea did stay free and is still been developed (but in slow cycles).
TomDC wrote:Oh: don't choose a renderer over another because it does displacement. It's a nice feature and all, but it's terribly slow -in any app. And as Gai says, displaced grass doesn't look good.
Indeed! For grass I'd use instancing or/and post pro. I rarely seen good enough grass made with displacement (specially when comparing the added render time). Gravel, pavement, stone walls, water... those are good targets for displacement.
Like said before, Thea can import kerkythea xml (be it created by Twilight or Kerkythea). Material systems are different, although some similarities can be find. Thea does a KT material conversion with some heuristics, so little fine-tuning may be in need in case of complex materials. Exporting materials/models from Thea to Kerkythea is not possible.
Before jumping to test Thea, it's good to watch overview tutorials.
notareal
Thea Render
Artisan Organic Toolset - a set of powerful organic modeling tools.
Return to Extensions & Applications Discussions
Users browsing this forum: Bing [Bot] and 6 guests
