FluidImporter free .obj importer Beta 1.0.5 Updated
• Page 3 of 4 • 1, 2, 3, 4
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedHi there,
I tried to download the fluidimporter, but the website gives back a 500 error. I couldn't find a mirror to download it. Is there someone who would send it to me or give me an available link ? Thanks
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedHi,
It should be fixed now. Nicola
Re: FluidImporter free .obj importer Beta 1.0.5 Updatedhmm... We're having a tab bit of trouble importing a terrain mesh we've made... We keep running out of memory...
The file size on the obj file is 374mb. Any solutions? If importer cant be solved for it... any other way to get it into sketchup (perhaps in pieces?) Not sure about the polygon count, but its a large number. Probably somewhere around 2m.
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedAll i can say is try poly cruncher or deep exploration beforehand.
That's a pretty large .obj which probably increases inside SU also. Best of luck with it
Re: FluidImporter free .obj importer Beta 1.0.5 Updatedpoly cruncher is a bit useless since the goal is to have a complex 3D terrain mesh, and deep exploration would not work... (wrong processor)
any way to chop up a 3D mesh into smaller segments?
Re: FluidImporter free .obj importer Beta 1.0.5 Updatedhmm... figured out the lack of cooperation... tried to import far too large meshes... worked better when going for a smaller mesh.
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedHello, i tried the FluidImporter, and saddly, even for a simple cub i got a google sketchup 8 crach
Does it because i'am using a 64bit window ? Any help possible ? thanks ^^
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedWhat app are you using to make the .obj file?
I find this plugin very robust in most cases.
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedI made thoses obj in the Cryengine 3.
I tried the Trial of the simlab soft Obj importer, and that work correctly except for the scale. and i only have problem with thoses ones.
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedYou get to choose the units for the OBJ file as you import it, so there is no 'scale issue', just PEBCAC!
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedTrying to figure out what the first 'C' is?
I hope it's not what I'm thinking!
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedProblem Exists Between Computer And Chair
Well yes, but the problem is that the simlab importer tool have a 30 import limit :/ and well, for just a personal and occasional use.. thats not so nice having to pay it. After the other free Obj Importer didnt work at all with thoses object. Your didnt import anything, and the fluidImporter crash all the time :'( ( at least with .obj coming from the CryEngine3, didnt try .obj coming from other soft. )
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedDo you have a small example OBJ we could look at.
Some exporters do make an unusual format... Did you try taking it into another Application and then export out again before the SKP? TIG
Re: FluidImporter free .obj importer Beta 1.0.5 Updatedfluidimporter doesn't work for me!
(works fine only in a in a previous installation of o.s.) i try su7, su8, su8pro trial...
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedHow doesn't it work? It's very frustrating for developers to be told something doesn't work, but then give no clues as to the issue[s]... Does it appear on the Import menu list of types? Does it open a dialog for options? Does it run? Does it do anything at all? Is the imported object not as expected? Does it take a long time to process? Does Sketchup crash/bugsplat? If you open the Ruby Console before running the importer are there any error messages? Can you successfully open this OBJ file in another app like Blender? Are the OBJ/MTL files together and any textures in the folder as specified in the MTL? You see there are many questions unanswered... TIG
Re: FluidImporter free .obj importer Beta 1.0.5 Updatedyou're right, sorry!
simply did not appear *. obj on the list of import formats ... I do not know what else to explain the problem. only now it is on the list mystery (translated by google)
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedJust tried to download fluidimporter. Web page comes back with an error Internal Server Error.
Re: FluidImporter free .obj importer Beta 1.0.5 Updatedpmolsen
Worked fine for me just now. I'd PM you the zip BUT it's 11Mb... TIG
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedWorked that time thanks. I tried it for over an hour last night with the same error. Maybe they were doing maintenance.
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedI have a problem as well
I open a new sketchup 8 window I click File>Import I change "All Supported Image Files" to ".obj files" I select an obj file I exported from sketchup previously I click import The window freezes then closes Bug splat appears
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedDo you get an options dialog auto-opening before the freeze happens ? If so what settings have you tried/used? Can you try it with a simple 'box' OBJ exported from a SKP. Importing that should work. When you installed the OBJ importer did you have 'admin rights'? Is its .exe in Sketchup's Importers folder ? Have you tried uninstalling it and reinstalling to see if that fixes it ?? If you have the Ruby Console open before the import starts are there any error messages ?? TIG
Re: FluidImporter free .obj importer Beta 1.0.5 Updatedjust trying to import this model:
http://www.flyingarchitecture.com/download/DOT-modo-obj.zip than bugsplat came out
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedThe obj file is strangely structured and the mtl lacks good color definitions. I edited the file to ensure all of the 'o[bjects]' become g[roups] with the mtl material immediately afterwards and the matching g[roup]/mat entries before the 'f' blocks was removed. Then it works - units=mm and flip-YZ... Please, register (free) to access all the attachments on the forums. TIG
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedThanks TIG,will try it as your Sugestion
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedEverything ive tried to import is causing bugsplats,
Bring on the Rain...
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedPost a simple OBJ/MTL file set [zipped] that you are having issues with and we can read/test it, to see if it's the file or your setup that needs fixing... TIG
I will have to get back to you on this later Tig, my Internet is down and I'm restricted to my iPhone Bring on the Rain...
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedHi sir! I tried using the fluidImporter but I'm having issues regarding the missing materials.. whenever I import an object in Sketchup the materials are always missing.. and sometimes it crashes.. please help on this.. thank you so much in advance!:)
Re: FluidImporter free .obj importer Beta 1.0.5 UpdatedHere are the images of the imported obj. file and the obj. image...
