SketchUcation Premium Membership
FluidImporter free .obj importer Beta 1.0.5 Updated
Re: FluidImporter free .obj importer Beta 1.0.5 Updated
Postby bizmen » Tue Apr 19, 2011 12:12 pm
Which folder do I have to extract the fluidimporter file? I cannot see it under the plugins menu after extracting on its default folder.
Btw. I'm using Google sketch up v8 (free version) ,and should I install the fluid ray demo version before fluidimporter for sketchup appears?
If yes, which installer should I download? I'm using windows vista ultimate 64 bit, 4gb ram
FluidRay for SketchUp Win32 Demo (Version 1.1.2)
FluidRay for SketchUp Win32 SSE2 Demo (Version 1.1.2)
FluidRay for SketchUp Win64 SSE2 Demo (Version 1.1.2)
FluidRay for SketchUp Win64 SSE41 Demo (Version 1.1.2)
Thanks!
bizmen
Postby TIG » Tue Apr 19, 2011 12:31 pm
It's not a Plugin, it's a compiled 'Importer'.
It adds an additional Importer type 'Wavefront/OBJ' under the File > Import file-browser...
The same as other compiled importers/exporters - it's the Ruby based tools that are in other menus like Plugins...
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby bizmen » Tue Apr 19, 2011 12:48 pm
TIG wrote:It's not a Plugin, it's a compiled 'Importer'.
Thanks TIG, you're the MAN!
bizmen
Postby whoa » Thu May 12, 2011 1:11 pm
Hello
I just installed your importer and I have no issue importing the .obj file, however I am not getting any textures?
Everything is just gray. I received the files from a furniture company, 4 seperate folders with several .obj files + .mtl and some jpgs that I guess are the textures. How do I add these into sketchup onto the objects?
Thank you
whoa
Postby TIG » Fri May 13, 2011 12:23 pm
whoa wrote:Hello
Thank you
You can read OBJ and MTL files in Notepad or equivalent.
The OBJ file defines the MTL file by name mtllib xxx.mtl.
The OBJ file usually expects the MTL file to be in the same folder as itself.
The MTL file defines materials.
They can be simple plain color like this (Kd values as %s =~[170,170,170]=~'mid-gray')
newmtl Color_003
Ka 0.000000 0.000000 0.000000
Kd 0.666667 0.666667 0.666667
Ks 0.000000 0.000000 0.000000
d 1.000000
or with a texture specified by an image-file it is like this
newmtl Wood_Floor
Kd 0.607843 0.411765 0.239216
d 1.000000
map_Kd MyModel/Wood_Floor.jpg
In this example the MTL file is expecting to find that material's texture's image-file called Wood_Floor.jpg in a subfolder that's in the MTL file's folder, that's named MyModel.
Note that many OBJ exporters use an image subfolder, but some do not - in that case the line might read
and then the textures' image files should be in the same folder as the MTL file itself...
If an OBJ importer can't find the image file it usually skips using it, and just uses the color specified for the material - in the case of 'Wood_Floor' this would be an RGB color based on the Kd values, as percentages of 255 =~[155,105,61]=~'mid-brown'...
Note that the 'd' value is the opacity: where 1.000000 is solid and 0.500000 is 50% transparent etc... So you can adjust these prior to import if desired...
Global Moderator
License type: Pro
Postby emanshiu » Fri Jun 03, 2011 6:07 am
Thank you for writing this tool. But everyttime i try to load in an OBJ, the sketchup just crashes. It crashes on a very simple text file. I'm a bit confused at what I can do. Am I doing something wrong? These files are all exported from Maya. Thanks!
emanshiu
Postby TIG » Fri Jun 03, 2011 5:06 pm
emanshiu wrote:Thank you for writing this tool. But everyttime i try to load in an OBJ, the sketchup just crashes. It crashes on a very simple text file. I'm a bit confused at what I can do. Am I doing something wrong? These files are all exported from Maya. Thanks!
What are the error messages in the Ruby Console etc ?
Have you tried it with my [TIG] older/slower OBJimporter.rb ?
Any error messages there ?
CAN you zip the OBJ & MTL files... and image files [in a folder if specified in the MTL etc] and post them so we can test it...
Global Moderator
License type: Pro
Postby emanshiu » Sat Jun 04, 2011 12:14 am
There are no error messages as it just crashes.
I'm sorry i was not aware theres an older one. I just tried to find it but can't where is it?
Also is there any way to import an obj and have it place at 0,0,0?
thanks so much for the help!
emanshiu
Postby TIG » Sat Jun 04, 2011 7:53 am
Search the Plugins-Index [here] for my OBJimporter.rb ...
That does place the geometry directly at it's original location.
The alternative, newer compiled version allows you to manually locate the geometry BUT it's easy enough to make that [0,0,0] ...
Global Moderator
License type: Pro
Postby emanshiu » Sat Jun 04, 2011 8:13 am
TIG wrote:Search the Plugins-Index [here] for my OBJimporter.rb ...
any idea on the crashing? it's really just a cube from maya.....
emanshiu
Postby TIG » Sat Jun 04, 2011 8:53 am
Unless you zip up the OBJ/MTL/Image-files and post them how can I know?
Have you tried the older importer.rb file ?
I haven't been directly involved in making the newer one BUT there might be clues in the way each one works...
Please post the files if we are to progress this issue anywhere...
Global Moderator
License type: Pro
Postby fluid » Mon Jun 06, 2011 12:11 pm
Yep, if you post the file that is causing the crash, I'll be happy to test it on FluidImporter as well.
fluid
Postby Efrado » Mon Jun 27, 2011 6:33 pm
HI ,TIG &NICOLA
WHAT ATEAM YOU ARE DOING :thumb: :thumb:
JUST A HUMBLE MAC USER WAITING TO TRY YOUR EFFORT IN THIS PLATFORM,PLEASE :cry:
Efrado
Postby niks » Tue Sep 20, 2011 1:42 pm
hi Fluid and Tig... thank you very much for this importer. tried it for a test and achieve great result :D
niks
Postby blockade08 » Mon Oct 03, 2011 2:59 am
TIG wrote:
whoa wrote:Hello
Thank you
newmtl Color_003
d 1.000000
newmtl Wood_Floor
d 1.000000
Thank you so much TIG you just saved me from hours of trying to fix up the textures as normally happens when i try a new importer/exporter :D Thanks a bunch :)
BTW for anyone who also has this problem, my .OBJ said mtllib C:\......\*wheremyModelIs*\test.mtl
I changed it to mtllib test.mtl - took off the directory data and it worked like a charm :)
blockade08
Postby chocochoc » Wed Nov 23, 2011 3:53 pm
Hi there,
I tried to download the fluidimporter, but the website gives back a 500 error.
I couldn't find a mirror to download it. Is there someone who would send it to me or give me an available link ?
chocochoc
Postby fluid » Mon Nov 28, 2011 4:37 pm
It should be fixed now.
Nicola
fluid
Postby somun » Thu Dec 15, 2011 6:45 pm
hmm... We're having a tab bit of trouble importing a terrain mesh we've made... We keep running out of memory...
The file size on the obj file is 374mb.
Any solutions?
If importer cant be solved for it... any other way to get it into sketchup (perhaps in pieces?)
Not sure about the polygon count, but its a large number. Probably somewhere around 2m.
somun
Postby Rich O Brien » Thu Dec 15, 2011 7:10 pm
All i can say is try poly cruncher or deep exploration beforehand.
That's a pretty large .obj which probably increases inside SU also. Best of luck with it :thumb:
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby somun » Thu Dec 15, 2011 7:48 pm
poly cruncher is a bit useless since the goal is to have a complex 3D terrain mesh, and deep exploration would not work... (wrong processor)
any way to chop up a 3D mesh into smaller segments?
somun
Postby somun » Tue Dec 20, 2011 11:46 am
hmm... figured out the lack of cooperation... tried to import far too large meshes... worked better when going for a smaller mesh.
somun
Postby wootwoots » Thu Jan 26, 2012 5:31 pm
Hello, i tried the FluidImporter, and saddly, even for a simple cub i got a google sketchup 8 crach :( whatever i'am choosing as import option.
Does it because i'am using a 64bit window ?
Any help possible ?
thanks ^^
wootwoots
Postby Rich O Brien » Thu Jan 26, 2012 5:46 pm
What app are you using to make the .obj file?
I find this plugin very robust in most cases.
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby wootwoots » Thu Jan 26, 2012 7:40 pm
I made thoses obj in the Cryengine 3.
I tried the Trial of the simlab soft Obj importer, and that work correctly except for the scale. and i only have problem with thoses ones.
wootwoots
Postby TIG » Thu Jan 26, 2012 8:46 pm
You get to choose the units for the OBJ file as you import it, so there is no 'scale issue', just PEBCAC! ;)
Global Moderator
License type: Pro
Postby Rich O Brien » Thu Jan 26, 2012 8:50 pm
Trying to figure out what the first 'C' is?
I hope it's not what I'm thinking!
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Jan 26, 2012 9:10 pm
Problem Exists Between Computer And Chair
Global Moderator
License type: Pro
Postby wootwoots » Fri Jan 27, 2012 5:30 pm
TIG wrote:You get to choose the units for the OBJ file as you import it, so there is no 'scale issue', just PEBCAC! ;)
Well yes, but the problem is that the simlab importer tool have a 30 import limit :/ and well, for just a personal and occasional use.. thats not so nice having to pay it.
After the other free Obj Importer didnt work at all with thoses object. Your didnt import anything, and the fluidImporter crash all the time :'( ( at least with .obj coming from the CryEngine3, didnt try .obj coming from other soft. )
wootwoots
Postby TIG » Fri Jan 27, 2012 5:35 pm
Do you have a small example OBJ we could look at.
Some exporters do make an unusual format... :?
Did you try taking it into another Application and then export out again before the SKP?
Global Moderator
License type: Pro
Postby snorky » Tue Apr 24, 2012 10:54 am
fluidimporter doesn't work for me!
(works fine only in a in a previous installation of o.s.)
i try su7, su8, su8pro trial... :cry:
snorky
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Extensions & Applications Discussions
Users browsing this forum: danielisimo and 3 guests
