SketchUcation Plugin Store
[NEW]Sketchup 2 Vue
Re: [NEW]Sketchup 2 Vue
Postby dburdick » Thu Nov 18, 2010 8:17 am
nomo81 wrote:the left one was exported with the sketchup 2 vue plug, material issue,
the right one was exported with 3dmax way., no material issue.
regards
nacho
Hi Nacho. Can you send me the SU file of your test here and I will try and see what the problem is. Send the model to:
dburdick@e-onsoftware.com
dburdick
e-on software
Postby d12dozr » Thu Nov 18, 2010 6:40 pm
What atmosphere type, if any, do you guys find works best for architectural rendering?
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: product design
Level of SketchUp: Advanced
Postby d12dozr » Mon Nov 22, 2010 5:11 pm
I asked this on the Cornucopia forum but no response yet over there...
I'm having some trouble, hopefully just beginner's ignorance...
1. My Sketchup scenes are not translating to Vue cameras. I made sure to unlock the camera height and uncheck "Sun face camera" in Vue like the Sketchup2Vue manual says. I am opening the model in Vue using the Python loader script.
2. the imported model comes in partially below the ground in Vue, even though it is above ground in Sketchup.
I'm using Vue 8 Complete and SU 8 free for the Vue export.
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby dburdick » Tue Nov 23, 2010 8:59 am
d12dozr wrote:I asked this on the Cornucopia forum but no response yet over there...
We discovered the problem on this one. In Vue, go to Options-->General Preferences and then uncheck "Preserve size of natural elements at creation"
This is a legacy option that auto-adjusts scaling to Vue Units on imports. It should be off by default, but apparently on Vue 8 it's on - so just uncheck this.
dburdick
e-on software
Postby d12dozr » Tue Nov 23, 2010 3:26 pm
dburdick wrote:We discovered the problem on this one. In Vue, go to Options-->General Preferences and then uncheck "Preserve size of natural elements at creation"
:thumb: That does it!
Thanks, Dave.
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby miikka1978 » Tue Nov 23, 2010 7:28 pm
Has anybody experienced similar problem when using Sketchup models in Vue? I have exported my Sketchup model into Vue with the new plugin. But, when I move the model in Vue it is not complete component. There is separate SingleSidedFacesGroup that I have not created in Sketchup.
miikka1978
Postby dburdick » Tue Nov 23, 2010 7:41 pm
miikka1978 wrote:Has anybody experienced similar problem when using Sketchup models in Vue? I have exported my Sketchup model into Vue with the new plugin. But, when I move the model in Vue it is not complete component. There is separate SingleSidedFacesGroup that I have not created in Sketchup.
You have to move the model as a whole. The single sided faces group consists of all of the faces which have materials on both sides. If you just grab the whole model and move it, all of the sub-components will move with it -- including the single-sided faces group.
dburdick
e-on software
Postby miikka1978 » Wed Nov 24, 2010 6:24 am
Thanks for explaining dburdick. Anyway, it seems that there are many other faces with material on both sides in my crane model. But, export doesn't create "loose geometry" in these cases. Based on this, I believe that the problem arises when there is material on both sides of face and these materials are different.
Is there is any way/plugin to examine Sketchup models and geometries in order to find out if there are faces with different materials on the sides of the same face?
miikka1978
Postby d12dozr » Wed Nov 24, 2010 6:44 am
Here is one by TIG: viewtopic.php?p=264134#p264134
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby dburdick » Wed Nov 24, 2010 5:57 pm
miikka1978 wrote:Thanks for explaining dburdick. Anyway, it seems that there are many other faces with material on both sides in my crane model. But, export doesn't create "loose geometry" in these cases. Based on this, I believe that the problem arises when there is material on both sides of face and these materials are different.
The SUVueExporter creates either:
1. double-sided faces - where the materials are the same on both sides or if one of the sides uses the default material
2. single-sided faces - where the face uses a different material on each side and neither of the sides is the default material
The reason for isolating the single-sided faces is that these faces are created as a single-sided mesh in Vue (e.g. where each polygon is treated as having a unique material on each side).
dburdick
e-on software
Postby Bob James » Sat Nov 27, 2010 3:12 am
I am unable to load a SketchUp model of a house into Vue 9. I'm attempting to use the SU2Vue ruby script in Sketchup 8 Pro.
Upon completion of export from Sketchup, I get a .vob file and a folder with an .xml file, a .py file and many .jpg and .png files.
I have set the Camera Height to unlocked and Point Sun at Camera disabled.
I've also unchecked "Preserve size of natural elements at creation"
If I use the Automation -> Run Python Script all I get is a large ball as the model.
If I try to use File -> Load Object I get an error statement saying that it can't find the .tga file xxxxxx.tga. If I say no to it's query to look for it, Vue crashes.
A truly distressing introduction to Vue :cry: :roll:
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Krisidious » Sat Nov 27, 2010 5:04 am
Bob James wrote:I am unable to load a SketchUp model of a house into Vue 9. I'm attempting to use the SU2Vue ruby script in Sketchup 8 Pro.
I have been using the Import option... not load or even Python...
try that and report back... are you using 9? because I am using 8.5... this may be a 9 bug.
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
Krisidious
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby d12dozr » Sat Nov 27, 2010 5:39 am
Bob,
I use the Automation -> Run Python Script and it works for me, like Kris, I'm also using Vue 8.
TGA is an image file, like JPG. Maybe you could try finding and deleting/replacing that material in the Sketchup file before exporting, see if that helps.
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Bob James » Sat Nov 27, 2010 6:34 am
None of the materials exported are .tga: they are all .png or .jpg.
When I try to import the .vob file I get the errors looking for 191_tx01_402.tga, etc. (there are eight of them - I have no idea what material/texture they are linked to).
So I've tried:
1. Automation -> Run Python Script [All that appears is a large sphere]
2. File -> Load Object [asks for .tga, cancel->Vue crash]
3. Import .vob [asks for .tga, cancel->Vue crash]
Edit: I also have Vue 8 Complete and I get the same result with it. As a matter of fact, I get the error messages when I use Automation -> Run!!!
I'm at a loss
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Krisidious » Sat Nov 27, 2010 6:40 am
save a copy of your model and remove all materials, then try importing it into Vue. report back
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby Bob James » Sat Nov 27, 2010 6:47 am
Krisidious wrote:save a copy of your model and remove all materials, then try importing it into Vue. report back
How do I do that: it's a big model with over 80 different materials :shock:
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Bob James » Sat Nov 27, 2010 7:02 am
I made a simple model: cube with cylinder on top - no color/material/texture.
When I import it by any of the three methods all I get is a sphere!
But at least I don't get the .tga error messages.
Not very encouraging :(
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Bob James » Sat Nov 27, 2010 7:13 am
Krisidious wrote:do you have the new version or the update to the plugin?
What is the latest version of the plugin? I got mine along with Vue 8 Complete back in October.
I opened the ruby, but there is no date in it. I see a lot of \win32\ in it: I'm using 64-bit Win 7 Professional. Is that a problem?
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby d12dozr » Sat Nov 27, 2010 7:24 am
Bob James wrote:I opened the ruby, but there is no date in it. I see a lot of \win32\ in it: I'm using 64-bit Win 7 Professional. Is that a problem?
64 bit should not be a problem, I'm using 64 bit.
FWIW, I made a simple model of a cube, textured it with a .tga image, and it imported into Vue just fine.
Bob, I can't think of anything else...have you tried emailing Dave Burdick? He posted his email address near the top of the previous page.
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Krisidious » Sat Nov 27, 2010 7:31 am
there is a "remove all materials" plugin it leaves all groups and components but removes all materials recursively.
try it on the model and let us know if it comes in.
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby Bob James » Sun Nov 28, 2010 12:51 am
Krisidious wrote:their is a "remove all materials" plugin it leaves all groups and components but removes all materials recursively.
Thanks, I'll try that but if it won't even import a cube with no material......
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Bob James » Sun Nov 28, 2010 1:41 am
Krisidious wrote:there is a "remove all materials" plugin it leaves all groups and components but removes all materials recursively.
Used TT's great plugin "Materials Tools" and removed all materials and made sure all faces were front faces: All I get is a large ball in Vue9. :puke:
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Krisidious » Sun Nov 28, 2010 6:22 am
this has got to be some issue with Vue 9 can you go and install 8.5?
Kristoff Rand
Home Designer
Krisidious
SketchUp version: 8
License type: Pro
Postby miikka1978 » Sun Nov 28, 2010 7:48 am
I am also having some problems when trying to use Automated VuePython Scene Loader. If I import Sketchup model manually, everything works ok. But, when using Python script I get only Sphere and no other geometry is listed in Object list. I am using Sketchup 8 and Vue 8.40-04.
miikka1978
Postby d12dozr » Sun Nov 28, 2010 8:01 am
miikka, are you unlocking the camera height and unchecking "Sun face camera" in Vue like the Sketchup2Vue manual says?
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby miikka1978 » Sun Nov 28, 2010 10:07 am
d12dozr wrote:miikka, are you unlocking the camera height and unchecking "Sun face camera" in Vue like the Sketchup2Vue manual says?
Yes, I have done those changes according to the manual.
miikka1978
Postby d12dozr » Sun Nov 28, 2010 12:25 pm
Well hopefully Dave has the answer...you could try emailing him if you haven't yet...
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Bob James » Sun Nov 28, 2010 10:40 pm
Krisidious wrote:this has got to be some issue with Vue 9 can you go and install 8.5?
I have Vue 8 Complete and Automation -> Run Python Script works just fine as long as the exported model has no textures.
This is an improvement over Vue 9, but to have to "emasculate" all of my models and then re-texture them in Vue is not a viable workflow :thumbd:
Besides that, this does not help with Vue 9 :thumbd: :thumbd:
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thecravatman » Sun Nov 28, 2010 10:43 pm
Dave et al, Can you shed some light on my predicament. I have SU to Vue exporter, SU 8 and Vue 9 Complete. I load vob file from SU and it shows up in the layer pane and I can see the materials but I can see the scene. I select it and right click to select 'frame selected object' but can see anything. I re-scaled the model in case this was a mm to m problem but to no avail. I unchecked 'preserve size of elements at creation' check box again to no avail. I have tried via the python script.
This is so annoying as I can see that it has been imported, its just I can see or manipulate it. Any tricks? Thoughts or work around I have run out of ideas. I really need something like zoom extents or a positioning tool so that it fits in the scene where I want it.
Please tell me that I am missing something obvious.
Thanks T
thecravatman
Postby dburdick » Wed Dec 01, 2010 12:00 pm
Hi Bob,
Sorry to see the problems you're having. Can you send me an e-mail to
dburdick@e-onsoftware.com with the model in a zip file so that I can take a look at it and see what the problem might be? It sounds like there might be corrupt texture file or something. There is a new update for the SU to Vue Plugin coming out later this week that might fix this problem.
dburdick
e-on software
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
PreviousNext
Return to Extensions & Applications Discussions
Users browsing this forum: No registered users and 6 guests
