Bonzai3D - double take
• Page 4 of 5 • 1, 2, 3, 4, 5
Re: Bonzai3D - double takeit would be nice to know. if you have a minute maybe you could try and see? or send me a file so i could try it.
Please, register (free) to access all the attachments on the forums. “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: Bonzai3D - double takeI'm not sure if I have any dwg counter data files at home. Might have to try it out at the office tomorrow...
Re: Bonzai3D - double takeWe are pleased to announce that the bonzai3d 2.1 update has now been released. To update a registered version of bonzai3d (v. 2.0), simply select Check for Updates from the bonzai3d Help Menu and follow the prompts.
We have also released the 2.1 Trial version of bonzai3d, which can be downloaded from the usual Trial Download page, or by filling out this form: http://bonzai3d.com/products/bonzai3d/b ... Trial.html The complete description of what is new in bonzai3d 2.1 can be found in this PDF, which is also downloaded automatically to your bonzai3d folder when you run the automatic update. http://www.bonzai3d.com/forum/discus41/ ... -42714.pdf What’s new in bonzai3d v2.1: Dimension unit display: Dimension styles have been enhanced with a new option : Include Units. NURBS by Lofting tool: New options have been added to the N-Loft tool. Match View tool: A new option, Angle Only has been added to increase the flexibility of the view matching process. Snap to ghosted objects: A new Snap To Ghosted option has been added to the Object Snaps Options palette. SketchUp 7.0 import: The sketchup importer can now import files created with SkecthUp 7. On Windows, this new SKP importer will require an additional library from Microsoft. Please download this specific version of Microsoft’s vcredist_x86.exe from near the bottom of This Page: http://www.microsoft.com/downloads/deta ... laylang=en Bug corrections: There are over 50 bug corrections in this version. Here are a few highlights: • Stability of operations on smooth object has been improved. • Area pick of parts is now much faster. • Large JPEG images are now correctly displayed. • Triangulate export option is now available for Facetted and Parametric exports.. • Closing and Saving a project is now enabled when Isolate Object is active (projects are saved without the objects isolated). • 3Dconnexion devices now respect changes to axes set in the System Preferences on Macintosh. • Space bar on Windows no longer creates two spaces when editing names in attributes dialog for layers, views, lights, scenes, reference & clipping planes. • The Angle field of the input palette that is displayed with the line drawing tool now accepts typed input correctly. • Background images no longer display upside down in certain cases. • Text objects are now exported to DWG at their proper size. • Export to DWG no longer triangulates all faces. • DWG export now correctly exports view spin parameter. • Changing the view now activates the Save and Save As... items in the File menu. • Switching to another tool after right clicking in an active result buffer no longer causes a hang. • The Piranesi export now works correctly. • The degree symbol now displays correctly. • Deleting control points on splines now works properly. • and many more..... Let us know what you think!
Re: Bonzai3D - double takeHey - that looks like a nice update. Sorts out some of my issues, I can tell by just a glance.
Re: Bonzai3D - double takehow does one determine if one need that MS patch?
Re: Bonzai3D - double takeThomas,
Real contours never end, and as such, we require the contours to at least end outside of the boundary of the site. (It could be possible to make an inaccurate terrain by guessing what the contours should be, but quality geometry and accuracy are very important to us, so we require proper contours to get the best results.) Finding end points that are inside the site boundary can be pretty easy if you turn on the Show First Point option from the Interactive Tab of the Wireframe Display Options. Any endpoint that is inside the site boundary (and not part of a closed line) then needs to be joined to another line, or moved outside the site boundary. This is pretty easy (even with complex contours) once you know the trick, but if you have any questions or problems with a specific file, feel free to ZIP and email it to support@bonzai3d.com so we can take a look at it and give you some help. Regarding the Microsoft vcredist, if you have the latest version of SketchUp, then you should already have it (but you should install it again if SKP fails in general). ps. Yes, Thomas, a couple of these bugs were thanks to your reports. (Thanks again!
I can see if I can dig out. I make terrains from DWG data, they they always have lots of caps here and there. It would take ages to stitch it up manually. You might see the scale better if I send a sample.
Sure, accuracy is good. But for the type of jobs I work with, I never have such ideal data. This is where I miss a tool that can interpolate most of it. Usually it's good enough. The most common type of gaps are microscopic gaps you can hardly see, and some are chunks where lines are removed. For instance, a map where you usually got contour every 1 meter, in steep areas, the surveyor data is often showing only each 5 meters suddenly. To me the terrain tools look to work best when you create the contours yourself manually. But not so well when used to visualize actual data. Thomas Thomassen — SketchUp Monkey & Coding addict
If the breaks are microscopic, you can just use the Join tool to automatically join open lines within whatever tolerance you like. (Just set the Tolerance greater than the microscopic gap -- but smaller than the distance between segments that you don't want to join...)
umm, if you have a hill or a ditch they do. I might have to try the software out especially on my AutoCAD contours. In AutoCAD (well, actually Civil 3D) the contours are all perfect; i.e. no breaks. When I import them into SU, they are fragmented and have holes. Some rubies help somewhat, but my experience is that I'd rather have all my teeth removed with pliers and without Novocaine. Rick
Re: Bonzai3D - double takeis anyone else having a nightmare with 2.1? i upgraded (use term loosely) and the first thing i tried; terrain in light of recent discussion; froze my whole system, i couldn't even bring up the task manager or start menu... then i got these popping up
maybe i should wait for ver 3? Please, register (free) to access all the attachments on the forums. “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: Bonzai3D - double takeRick,
In the case of a hill or a pond, the contours will be closed, so their last point is the same as the first point. Contours always connect back to themselves somewhere... Xrok, The Insufficient memory message probably appears because you are trying to generate a Meshed Terrain using a very small mesh size relative to the size of the terrain site boundary. Measure the longest length of the site, divide this by ~20, and use this distance as a starting point for your mesh spacing for the terrain model. Once you generate this properly, you can then determine the desired mesh spacing (perhaps 1/50th or 1/100th of your site length). Regarding the Run command, this is Microsoft's Security Policy manager, and it is coming up because of your security policy settings on your computer. True, bonzai3d will try to connect to the internet to access tutorial video files, or download files from Google's Warehouse, so perhaps you have set up some security measures to bring up this run command in that event? (No one else has reported this, and we are not seeing this on any of our computers, so we are not sure what settings that you may have employed that are causing this to appear -- but this is because of your settings and not because of the update -- other than the fact that bonzai3d 2.1 is a "different program" than version 2.0.)
Re: Bonzai3D - double takeThis may be of interest?
bonzai3d Webinar **RenderZone Rendering** Join this webinar to hear Matthew Holewinski from AutoDesSys demonstrate the power of photorealistic rendering with RenderZone, for bonzai3d and form•Z. RenderZone is the rendering engine of choice when you need full raytrace rendering, giving you the power to visualize your ideas in very abstract or photorealistic ways. RenderZone adds a full arsenal of tools to assist you with anything from simple scene development to your most demanding rendering needs.This informative webinar will give you insight into why RenderZone is such a valuable compliment to your visualization needs. Wednesday, June 2, 2010 at 12:00pm-1:00pm EST (GMT - 4hrs) <https://www1.gotomeeting.com/register/958028537> **bonzai3d Introduction Webinar** Join this webinar to hear Matthew Holewinski from AutoDesSys demonstrate and explain how bonzai3d is used to accelerate the 3D design process with its intuitive interface, flexible modeling tools, and extensive visualization capabilities. Discover how the robust models created with bonzai3d can be used further down the production pipeline with worry free geometry. This informative webinar will give you insight into why bonzai3d is fast becoming the 3D modeler of choice in all design disciplines. Thursday June 17, 2010 at 12:00pm-1:00pm EST (GMT - 4hrs) <https://www1.gotomeeting.com/register/512139233> Space is limited. Reserve your Webinar seat now! After registering you will receive a confirmation email containing information about joining the Webinar. System Requirements: PC-based attendees: Required: Windows® 7, Vista, XP, 2003 Server or 2000 Macintosh®-based attendees: Required: Mac OS® X 10.4.11 (Tiger®) or newer Copyright ? 2010 AutoDesSys, Inc. 2011 Riverside Drive, Columbus, OH 43221 Phone: (614) 488-8838 Fax:(614)488-0848 support@formz.com
Re: Bonzai3D - double takejust received an email:
Bonzai 3D v2.2 is out http://www.formz.com/products/bonzai3d/ ... d_2.2.html also, a free webinar this thursday (sept30,10) https://www1.gotomeeting.com/register/732623209 dotdotdot
Re: Bonzai3D - double takedoesn't say anything about working better, just trying to do things SU does already?????????
maybe they could prioritize function over feature. Personally, i'll check back in a couple versions. “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: Bonzai3D - double takeThey're not quite in your Weight-class yet Rocky!
you might be right about a couple of more versions... supposedly, they're going hard at the flagship so i'm sure it will trickle down the pipeline.. (thinking some of the things needing worked on in bonzai are also needed in form-z.. if i were them, i'd do form-z first too) [/speculation]
dotdotdot
Re: Bonzai3D - double takeI just noticed that my menus in B3D is File - Edit - Window - View - Display - Palettes - Help
Has it always been like this? Or changed in v2.2? It seem like an odd placement of the Window menu.... Thomas Thomassen — SketchUp Monkey & Coding addict
sorry...after this thread that statement seems oxymoronic.
Re: Bonzai3D - double takeThis has been a very different approach to reviewing software.....seeing it through with a virgin so to speak....
It would be useful to put SU (and a few others) to the test in the same way...I would like to see how the thread would develope.
i should've documented a recent effort of mine.. i have a project starting tomorrow and while i did the initial design in SU, i forced myself to do the actual design entirely in another app.. (something with nurbs surfaces as there isn't a straight cut in this thing im building) i downloaded bonzai 2.2 as it's seemingly an app that i'd like to know as well as i do sketchup.. honestly, i gave up on it after about 3 hrs.. it crashed on me twice but the final death blow was this weird thing it kept doing.. basically, the model would get lost in space and i couldn't recover it no matter what i tried (zoom extents etc..) it was just gone and saving/reopening didn't help either.. i need the app to preform while on the jobsite and this finicky behavior was a major turnoff.. there's also a major (well, major to me) bug in there that won't allow certain curves to happen.. i emailed them about it when v2 first came out and they agreed it's a mistake and they'll fix it but it's still not working. i'm sure a autodessys rep would say it's user error etc. or 'send us the file so we can look at it' etc. but i dunno, first impressions are lasting ones.. i ended up doing it in rhino (which i've dabbled with in the past but never committed to it) and seriously, that app is great.. i think some of my attraction towards bonzai is that it's basically pitched as sketchup and rhino (or whatever) in a single package.. after last weeks' work though, i'm over that idea and am actually excited about furthering my rhino skills.. dotdotdot
Re: Bonzai3D - double takesometimes "virgins" find more flaws cause their not used to working around them like users who are experienced with the offending software. I never claimed it was a tutorial and i sure as hell know how 3d software should function and so far this ain't IT!
I may be a Bonzai virgin, but a 3D virgin i'm not. (experienced in MAX, Solidworks, Modo, Sketchup...) “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: Bonzai3D - double takeThis has been a looooong interesting read... There wasn't any mention though of how this software handles large amount of geometry. But i haven't seen much development on this in the past year or so... Maybe waiting for a better sketchup is the way forward?
Re: Bonzai3D - double takeBut i haven't seen much development on this in the past year or so... Maybe waiting for a better sketchup is the way forward?[/quote]
I noticed that also. Keep going back to see what's happening and don't see anything progressing.
download the trial.. import an x-frog tree or something then try wiggling it around? shouldn't be too hard to figure out if it can handle geometry..
nah, don't do that.. sketchup is sketchup and will always be.. there are already other apps that can handle situations where sketchup breaks down.. instead of waiting for sketchup to (do whatever it is you wish it would do), learn the other app that can already do it.. [and maybe bonsai is that app? it wasn't for me but maybe for you] dotdotdot
Re: Bonzai3D - double takeMukul.ar et al,
Thanks for your interest in bonzai3d. We just posted a response to a similar question you had here: viewtopic.php?f=10&t=38102&p=370239#p370239 (We don't want to post the answer twice and appear to be spamming the forum, so please find your answer there...)
Re: Bonzai3D - double take@ bonzai3d support
there's this one small thing that always bugs me about you guys' (gals'?) responses both at scf and at your own forums.. [and i realize, this could very well be my own problem so not something you must take seriously or whatever.. regardless, i truly mean this as being a positive statement to you.. not trying to battle or anything like that] it's that you guys (gals?) use the generic name of 'bonzai3d support' or 'support@formz' or 'user name - tech' when you're posting on the internet.. i mean, are you one person? a bunch of people using the same user names? an automated response? dunno, it just feels way too impersonal to me.. especially when you're representing a corporation.. you know? anonymous internet posting went out of style circa 2006 or so.. gotta get up to date on that dotdotdot
Re: Bonzai3D - double takeJeff,
There is a whole team of people that provide support and answers for our users (or potential users). Wouldn't it be confusing to get a series of official company replies -- one from Dan, another from John, or Dave, all on the same topic? I would think that it would be a bigger concern to get a polite and correct reply as quickly as possible. No?
Re: Bonzai3D - double takexrok, did you check the Insert checkbox?
Ooops.... I replied to a very old post.... viewtopic.php?f=80&t=27022#p233455 Never mind me... Please, register (free) to access all the attachments on the forums. Thomas Thomassen — SketchUp Monkey & Coding addict
just as an example, the google employees (as well as some other software devs) that post here use their own names but they have a title under their names which designate the company they are with.. i believe Gaieus would do the same for you all if you're so inclined. but take my statement for what it's worth.. i'm just one person giving an opinion on the internet.. wether or not others see it the same way, i don't know.. but just using your previous post as an example, i bet typing that message with (Jeff,) as the beginning seemed at least a little different than addressing it to (LurkerBoi2000,) -- to which you click on my profile and it being empty as well.. dotdotdot
Re: Bonzai3D - double takeRocky,
I'd like to give a word of thanks for your doing this thread. I appreciate having an experienced modeler share is experience with a new software. When I have time to spare I like to look at new software as well, and hate running into these kind of dead-ends (poor inferencing seems to be the biggest culprit here) Andy
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
