PhotoSculpt
PhotoSculpt
Postby solo » Wed Feb 03, 2010 6:15 pm
Hey guys, check this out:
http://www.photosculpt.net/
Looks like we have another winner.
PhotoSculpt Textures is a new software due to release in 2010 that creates high definition 3D textures or 3D models from 2 photos of the same subject taken from 2 different viewpoints.
Top Features :
Very high quality of depth detail
Very high resolution results
Very fast : 3d model are displayed on screen within seconds while still processing
3d model export (obj, stl)
texture map export (color, depth, normal, ambient occlusion, specular)
Tileable texture option
http://www.solos-art.com
I'm better with polys than words
solo
Global Moderator
Re: Photo sculpt
Postby solo » Wed Feb 03, 2010 6:19 pm
Even better, if you only want a great texture and not the model, then no probs, it will extract all the maps needed for HD textures which can be used for rendering, bonus is it will even do the seamless tiling for you.
solo
Global Moderator
Re: Photo sculpt
Postby pilou » Wed Feb 03, 2010 6:21 pm
A prog by a French guy ;)
These are not on the site ;)
Yes you can import objects PhotoSculpt in zbrush. It's even done: via the import obj file 3d textured.
In fact for nothing to hide I even designed the app for you specifically to your attention (zbruh users) because there is that you almost that manipulate objects 5 million quads without wincing.
It seemed like a tool PhotoSculpt would meet your expectations
- Yes the 3D models are highly detailed.
- Yes it is easy to use. I described the operation:
First I place the left and right images in the interface and click the button 'sculpt'.
The 3D object first appears on screen in lowpoly in 1 s. Then very quickly the density increases gradually as the program works. Everything is interactive in real time. You can zoom, rotate around the object, change of subdivision, etc. crop.
In 40 seconds, the object is 0.5 million triangles.
In 2 minutes he made 5 million
in 4 minutes it is the maximum that my camera can provide around 24 million. What is entirely unreasonable for ZBrush, (the files are 1 gb etc..) So when I'm there I simplyfied and the quality is fantastic.
Me, for comfort, I often interrupting the process of around one minute, the quality is already really good
Option 360 is required and I also like you I am requesting. But after study proves that it is very difficult. Everyone breaks the teeth above. Those who tried told me, it's just horrible, totally unusable, unimaginable even to talk to you sad!
So I chose to focus on the other option "Only 2 photos. With the final package of benefits:
- It is much more precise
- It is much faster
- It is much more reliable, the reconstruction is automated by the algorithm without human intervention
- There are already plenty of objects and scenery around us can be content with 2 photos
- It's easier for the photographer, the time saved is considerable.
- Ideal for making textures, UV map are rectangular always clean.
20 °: no no not at all a minimum. In fact it works quite well between 10 and 30 °.
Optimum: What is surprising is that the optimum varies with the subject. I recommend a slight angle when the subject is difficult or very complex like a tree depth.
Hype-O
Speedy Galerie
Top SketchUcator
Re: Photo sculpt
Postby remus » Wed Feb 03, 2010 6:23 pm
tasty, that ivy is particularly impressive.
I wonder how heavy the models are :roll:
remus
Re: Photo sculpt
Postby solo » Wed Feb 03, 2010 6:24 pm
You can set your LOD (level of detail)
solo
Global Moderator
Re: Photo sculpt
Postby pilou » Wed Feb 03, 2010 6:32 pm
See my previous post ;) (time and nombers of Polygons ;)
It's made more for Zbrush users so polys can be very heavy ;)
Speedy Galerie
Top SketchUcator
Re: Photo sculpt
Postby pilou » Wed Feb 03, 2010 10:27 pm
Translation done, sorry for the rustic result I am not good in this sort of thing! :oops:
I prefer the other way :mrgreen:
And maybe that the author himself will go here in a few time ;)
Speedy Galerie
Top SketchUcator
Re: Photo sculpt
Postby Gaieus » Thu Feb 04, 2010 4:21 am
I wonder how much it will cost. (Pilou? have you got any back-door info? ;) )
I could really use such a software at modelling all our (most of the times rather ruinous) archaeological finds. Making a reconstruction, with straight walls and such, as it "should have looked" would not be a problem but investing time and money into documenting ruins in 3D is generally not economical.
Re: Photo sculpt
Postby jolran » Thu Feb 04, 2010 7:26 am
Amazing!
Well I suspect a workflow similar to Zbrush. With lower-mesh to higher-mesh normalmap extraction.
And then using normalmap(or displ.) + textures on a basemesh with realtively low polygoncount.
Otherwise its quite useless.
jolran
PluginStore Author
PluginStore Author
Re: Photo sculpt
Postby pilou » Thu Feb 04, 2010 9:13 am
@Gaieus
Price is in study : you can yourself say how many you can put for this prog?
(we are waiting here as soon as possible Mr Hippolyte aka Hipe-O ;)
Speedy Galerie
Top SketchUcator
Re: Photo sculpt
Postby Gaieus » Thu Feb 04, 2010 10:25 am
Pilou wrote:@Gaieus
Me as unemployed almost for a year now? (just joking :D )
(Anyway, I have signed up for that 50% discount at launch - we'll see how much it is as well as how much I have ;) )
Re: Photo sculpt
Postby pilou » Thu Feb 04, 2010 11:23 am
So wait and see ;)
Speedy Galerie
Top SketchUcator
Re: Photo sculpt
Postby Gaieus » Thu Feb 04, 2010 11:35 am
Yeah, Hyppolite has just responded.
Re: Photo sculpt
Postby Mike Lucey » Thu Feb 04, 2010 12:14 pm
Pete,
I am surprised at you :o You must be slowing up in your old age :D I mentioned PhotoSculpt last week here, viewtopic.php?f=80&t=25509
Anyway I think hippo will be along shortly to answer the questions raised.
Mike
Mike Lucey
Mayor
Re: Photo sculpt
Postby solo » Thu Feb 04, 2010 1:40 pm
Mike, I'm sorry I missed that.
I must have assumed it was a Mac app, you are a notorious Mac fanboy after all. :mrgreen:
Does this work on Mac by the way?
solo
Global Moderator
Re: Photo sculpt
Postby Gaieus » Thu Feb 04, 2010 1:44 pm
Hehe...
Maybe I should merge the two topics and move the whole thing here?
Yes, Mike, that little subforum is kind of hidden from the sight. What do you think?
Re: Photo sculpt
Postby pilou » Thu Feb 04, 2010 2:11 pm
I am affraid that will be only for PC :roll: (wait the visite of Hipe-O ;)
But for mac exist some method (dual exploitation system, Virtual PC etc...
Speedy Galerie
Top SketchUcator
Re: Photo sculpt
Postby hipe-0 » Thu Feb 04, 2010 4:47 pm
Hi Guys,
my name is Hippolyte from http://www.photosculpt.net
I'm new to your forums and many thanks to Pilou and Mike for the multiple invitations. :)
I've used sketchup a lot last year. I'm a total fan of this application. :enlight:
I'm a design engineer, I know also most mechanical CAD packages (Catia 4&5, proe, ug, ideas, etc) and Sketchup blasted me as it was so userfriendly in comparison. I never thought this would be possible to design something that cool. Good job devs! :thumb:
To your questions :
Mac version: I'm sorry that's not possible now. I'm working full steam on the PC version. If this version work, they maybe I'll work on the mac version.
Price question: I'm doing a market study, that's really too soon to reply. Let's say I want the price to be 'normal'. Gaieus is right, what is 'normal' in every user's mind? That's a mystery now.
low/hi polygon extraction is a feature of PhotoSculpt.
Pressing the < > buttons on the PhotoSculpt interface divides or multiply model size by 2. You get immediate feedback on screen.
Additionaly a friend of mine have requested the 'save multiple' option. So you can now save whatever multiple polysizes with whatever maps in one go.
Archaeological use: That's a very good question, :thumb: I have contacted people that work in this domain, I really think as you do Gaieus that my software can help them documenting findings in 3D. Some of them actually do that already. Some are using high end lasers, other use cameras and beamers to project bars, but they usually all describe something really cumbersome and expensive.
On my side I have made some experiments on the site of Plagne, France, close to Geneva, where they recently spotted dinosaur foot steps. I got wonderfull results in no time as I shot the entire site in 12 minutes (about 50 shots). I can share that.
to Jolran: you seem to have a lot of expectations about PhotoSculpt. You or anyone else please don't hesitate to send me your wish list, I may not be able to do everything, but just keep asking, that's really the only way I can make the soft improve.
Any other question? Please do not hesitate!
Now my questions about sketchup pro, can someone help me?
1. What is the practical polycount limit of sketchup pro when importing obj files (or stl files)?
2. Can you use normal maps with sketchup pro? Can you do with another renderer?
3. can you use displacement maps to push geometry with sketchup pro?
Thanks everyone! Thanks for your invitation!
Hippolyte from http://www.PhotoSculpt.net
hipe-0
Re: Photo sculpt
Postby pilou » Thu Feb 04, 2010 5:47 pm
1 I am affraid to say that I believe that
SU PRO import only 3ds (so 65 535 polys max by objects) , dwg, dxf, Collada (Dae), KMZ, formats ;)
So maybe a converter must be used
and for the other I believe for the moment that is
2 No Yes
3 No
with the current version : maybe a day some plugs can makes that ;)
Speedy Galerie
Top SketchUcator
Re: Photo sculpt
Postby Gaieus » Fri Feb 05, 2010 8:46 am
Hi Hipe-0 and welcome (finally) :)
I would have a question about keyboard strokes you mention. You obviously know that non-English keyboards tend to vary from country to country. On my (Hungarian) keyboard layout for instance, I have to use the Alt+Ctrl (or AltGr on the right) plus some other letter keyboard combination in order to get the < and > symbols. Would this affect the use of the software? (Currently I am unable to use some of the features of SketchUp because of this).
As for polycount in SU - it can depend on a lot of things. A whole archaeological site could obviously not be presented this way but there are workarounds like TIG's matrix proximity or Fredo's GhostComp plugins to display more complex geometry when it's near and simpler versions when they are in the distance.
Photo-realistic rendering with bump and displacement maps are generally done in external apps (or apps that - though plugins - work in SU itself). These are not "interactive" however although LightUp for instance "bakes" such info into the SU model and the you can walk around or export to other applications - so there are endless possibilities.
Re: Photo sculpt
Postby hipe-0 » Mon Feb 08, 2010 7:08 pm
I agree with you about keyboards Gaieus, I have a french one and it's a mess sometimes. Concerning the < and > I meant the buttons on the interface, not the equivalent key on your keyboard.
I've just updated my web site with many more information about PhotoSculpt Textures plus about 70 images and free seamless textures.
Go to:
http://www.photosculpt.net and click menu/photosculpt textures/gallery
Let's discuss?
hipe-0
Re: Photo sculpt
Postby jolran » Mon Feb 08, 2010 8:00 pm
Im sorry. I must make it clear that I ment it would be hard to use for SU users with big polygoncountmeshes.
SU is 32 bit as well.
How are UVs made? Polypaint and then UNWRAP?
jolran
PluginStore Author
PluginStore Author
Re: Photo sculpt
Postby Gaieus » Tue Feb 09, 2010 3:09 pm
OK, thanks, Hippe-0! I will check out all those things, promise, before coming up with a silly question again!
:D
Re: Photo sculpt
Postby hipe-0 » Wed Feb 10, 2010 12:18 am
To jolran, don't be sorry that was a good question! :thumb:
UV:
This is simple: it's a regular grid flat projected onto the model, based on the camera main axis.
I like this as it basically gives best results: it always work, it makes no seams and all textures you create are directly fully usable onto the model.
UVs are automatically created when exporting the model.
So you don't really mess with them. If by any chance you need to change something, you can still do it within your own 3d app.
You cannot for instance polypaint or unwrap within photosculpt.
Hoping this made sense?
hipe-0
Re: Photo sculpt
Postby mitcorb » Wed Feb 10, 2010 12:34 am
I notice system requirements mentions DirectX 9. Here's my naive question:
What does this mean relative to SU's use of OpenGL, and some video cards? Does this create any limitations?
mitcorb
Top SketchUcator
Re: Photo sculpt
Postby jolran » Wed Feb 10, 2010 8:50 am
That make pefect sence. Its like "Cameramapping" in XSI.
Sounds great!
And for all people who doesent have PRO version(majority) import of obj might be problematic.
One can use Ultimate Unwrap3d or Okino. The mentioned first is cheaper and has UV editing, good companion to Photo sculpt
maybe :P
jolran
PluginStore Author
PluginStore Author
Re: Photo sculpt
Postby hipe-0 » Fri Feb 12, 2010 6:42 pm
mitcorb wrote:I notice system requirements mentions DirectX 9. Here's my naive question:
I'm not entirely sure to understand your question Mitcorb, sorry?
PhotoSculpt uses the DirectX9 api from Microsoft.
Those Dx9 functions are part of dx10 and dx11 too and run with no problem if you have them installed.
One limitation is if you have dx8 only, whitch is rare, then it won't work.
I have no plan to make use of opengl today, do you need that?
I hope to have answered your question?
hipe-0
Re: Photo sculpt
Postby mitcorb » Fri Feb 12, 2010 7:06 pm
Well, I did say it was a naive question.
I am not even sure if Directx and OpenGL have any compatibility issues or not, or whether some graphics cards are dependent on one or the other.
I just need to do some more research for my own understanding.
Thanks for your reply, hipe-0.
mitcorb
Top SketchUcator
Re: Photo sculpt
Postby hipe-0 » Fri Feb 12, 2010 11:00 pm
mitcorb wrote:Well, I did say it was a naive question.
Don't worry, there are no "naive questions". Hoping to have helped you or reassured you. I tested the software on xp, win 7 , vista, 32, 64 bits it runs on all configurations.
I don't know about graphic cards that are opengl only. That may well exist on pc or maybe only with unix workstations. Anyone knows?
hipe-0
Re: Photo sculpt
Postby pilou » Mon Feb 15, 2010 7:13 pm
Video of the Interface ;)
Speedy Galerie
Top SketchUcator
Next
Return to Extensions & Applications Discussions
Users browsing this forum: Bing [Bot] and 5 guests
