[Preview] Wrap-R Video #2
Re: [Preview] Wrap-R Video #2
Postby Rich O Brien » Thu Jan 12, 2017 10:59 am
This month we open up the beta to test as many OS as we can.
But here's a video I did for the current testers showing some of the new functionality...
3
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby rv1974 » Thu Jan 12, 2017 11:36 am
Will Wrapper feature some kind of 'render UV template' with alpha (3DS Max terminology)?
https://vimeo.com/151742771
My idea is to use Object Painter tool later (upon proper set UV map)
rv1974
Postby Rich O Brien » Thu Jan 12, 2017 11:38 am
Do you mean will it export the UV layout?
You can export the UVs to SVG so you can scale them to any resolution without pixelation.
User avatar
Rich O Brien
Administrator
Postby alsomar » Tue Jan 17, 2017 12:50 pm
Rich O Brien wrote:This month we open up the beta to test as many OS as we can.
Great! :D
User avatar
alsomar
Premium Member
Premium Member
Postby Gubermensch » Wed Jan 18, 2017 12:11 am
Very excited for this.
I suspect the Beta will be closed. I'd be happy to participate if you're looking for more users.
User avatar
Gubermensch
Premium Member
Premium Member
Postby jonorman » Mon Jan 23, 2017 6:53 pm
Second that, beta testing would be nice :-)
jonorman
Premium Member
Premium Member
Postby SJS66 » Sun Jan 29, 2017 2:31 am
Wow. Looks good. If you need a complete noob for testing, I'm in. Might be helpful.....can't blame a bloke for trying though :P
User avatar
SJS66
Premium Member
Premium Member
Postby SebastianSztyber » Thu Feb 02, 2017 1:49 pm
Could you upload part 2-3? =)
SebastianSztyber
Premium Member
Premium Member
Postby pinoy » Sun Mar 19, 2017 3:22 am
Hi Rich, Will we see Mac OS as well? Just downloaded but for Windows only.
Any news on this?
Cheers
pinoy
Postby SourceSkyBoxer » Thu Apr 13, 2017 7:12 am
Hello I can not understand why does wrapr not work for me :( If I marked seam lines as green lines than export to obj file. than wrapr doesn't work why?? I can not understand :( PLEASE EXPLAIN ME CLEAN! HOW DO I USE STUPID GREEN LINES.....????????????????????????
SourceSkyBoxer
Postby Gábor » Thu Apr 13, 2017 9:08 am
SourceSkyBoxer wrote:Hello I can not understand why does wrapr not work for me :( If I marked seam lines as green lines than export to obj file. than wrapr doesn't work why?? I can not understand :( PLEASE EXPLAIN ME CLEAN! HOW DO I USE STUPID GREEN LINES.....????????????????????????
Thank you for testing Wrap-R beta. Do I understand well that after you mark the seams in SketchUp, you export your model to .obj from SketchUp? The .obj exporter will not export the marked seams so of course you will not see them in Wrap-R. The preferred way to do it:
- Mark your seams in SketchUp with the Wrap-R plugin.
- Select in SketchUp the geometry you want to unwrap.
- Right click the selected geometry and from the context menu select "WrapR / Send to WrapR"
Other option:
If you want to use Wrap-R as a stand-alone application. You need to save your model in .skp format and open the .skp file in Wrap-R.
I hope this helps.
User avatar
Gábor
SketchUcation IT
Postby Gábor » Thu Apr 13, 2017 9:10 am
pinoy wrote:Hi Rich, Will we see Mac OS as well? Just downloaded but for Windows only.
Any news on this?
Cheers
Hi Pinoy,
Currently we are concentrating on the development of the Win version. If the Win version will be popular on the market we plan to make a MAC version as well.
User avatar
Gábor
SketchUcation IT
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: bambutec and 1 guest
Visit our sponsors:
