VisuHole punched stencil as component  Topic is solved
The ideal place for beginners to get help using SketchUp
Postby rafikius » Sun Nov 03, 2019 10:33 pm
Either the air pressure is too low or I'm getting old but I can not figure out how to make Fredo's VisuHole punch result to be a component.
I need to sketch a flange with 200 holes in it.
I used the Fredo's plugin to punch one hole and then wanted to multiply its copies around the flange with Copy Along a Curve plugin.
The results are faaaar from what I wanted.
Any means to dissipate the big black cloud that covers my mind and protects me from finding a solution?
rafikius
Re: VisuHole punched stencil as component
Postby Box » Mon Nov 04, 2019 3:02 am
Without seeing it we can only guess.
My guess would be that you haven't set the axis correctly to get the components to follow the path as you want.
Postby pilou » Mon Nov 04, 2019 11:54 am
Why not use directly Visuhole ? ;)
Here a flat top face, but you have an option for curvated ones! ;)
Speedy Galerie
Top SketchUcator
Postby rafikius » Mon Nov 04, 2019 12:13 pm
pilou wrote:Why not use directly Visuhole ? ;)
Thanks for your time.
I believe I'll have more sketches with that issue to do in a nearest future.
Therefore I balked at a sheer thought of repeated clicking even those 200 clicks.
rafikius
Postby rafikius » Mon Nov 04, 2019 12:19 pm
Box wrote:Without seeing it we can only guess.
So much thanks for replying.
Once I'm back home I'll repeat and recheck all the steps I did yesterday.
I have installed the liceCAP soft, tried to record what I was doing, but then... Sketchup hang up and... I gave up and went to bed.
rafikius
Postby pilou » Mon Nov 04, 2019 2:03 pm
No need to click 200 times ;) Just make your sections along a path then apply visuhole! :)
Speedy Galerie
Top SketchUcator
Postby Box » Mon Nov 04, 2019 2:58 pm
I didn't really mean we need to see how you do it, although that can be useful, but just adding the model is a huge help.
Postby rafikius » Wed Nov 06, 2019 8:50 am
pilou wrote:No need to click 200 times ;) Just make your sections along a path then apply visuhole! :)
I need to admit I don't get what is the method you are proposing :-/
I'm placing an example image to show what I need to obtain:
I need to have around 200 of such bolts placed in holes.
Placing bolts was not much of an issue, the hindrance is creating 200 equally spaced holes
BTW. Unfortunately LICEcap stil hangs my win7
rafikius
Re: VisuHole punched stencil as component  Topic is solved
Postby Box » Wed Nov 06, 2019 8:53 am
Are the two hundred holes in a circle?
Postby pilou » Wed Nov 06, 2019 9:24 am
And if you need models go there ...https://www.mcmaster.com for any mechanical pieces! :ugeek:
I suppose they have bolts Nuts & rivets! :)
For Sketchup use the Sat Format and the Free PCON Planner for make the SKP format! :)
You can use the free Real Time Render SimLab Composer Lite ;) (maxi 1920 * 1080)
Here with a Nurbs prog...
Speedy Galerie
Top SketchUcator
Postby rafikius » Wed Nov 06, 2019 9:55 am
Box wrote:Are the two hundred holes in a circle?
Gosh.. yes they are!
The simplest methods are the best. No need for any plugins.
I got my mind fixed in one way and you showed me another-simpler
rafikius
Postby Box » Wed Nov 06, 2019 10:24 am
Glad you got there.
This is why we ask to see what you are working on, if we'd known it was a simple array when you first asked we could have shown you then. I thought from your original reference to using Copy along curve that the flange wasn't round.
Postby rafikius » Wed Nov 06, 2019 11:04 am
Box wrote:Glad you got there.
I got familiar with the "golden rule" (posting the model with a post) right after I sent my post, only. Mea Culpa :-/
Box wrote:I thought from your original reference to using Copy along curve that the flange wasn't round.
And I solved one more issue that bothered from a certain time, ie. how to embed in one's post a google photos based image
and for future viewers of this post...
Thou my way to complete the task was a way around.
I still can not figure out why a hole made with fredo's visuhole extension & copied using rotate method does no result in copied holes but pipes with a blinded ends.
like that:
The "empty hole" is the one created with VisuHole. the rest are its copies
(I set the VisuHole plugin to place the result as a group.)
The one its left is a copy which I had to "intersect with model" with and only then I could manually remove the "blin end".
AFAIU the rotate tool shall allow copying a group/component.
What am I missing?
rafikius
Postby pilou » Wed Nov 06, 2019 11:33 am
I believe you can only move (and trim) automatically only all the holes in the same time!
or one or some of them but not a copy!
Speedy Galerie
Top SketchUcator
Postby Box » Wed Nov 06, 2019 11:50 am
Creating 'holes' in a thickness is often problematic, it is far easier to make the holes in one face and then extrude.
Postby pilou » Wed Nov 06, 2019 2:18 pm
For your problem of copy of an cutting VisuHole Object
Select your single or multiple result Visuhole Object(s)
Make a component with Everywhere Cutting link
Copy and move it from the background to the Face
Explode it (don't ask me why...:)
Kill the original
Use the Hole Punch Tool by Tig Regulate the deepth
You can now copy and Or Move anywhere you want on the face that will Cut the face Front to Back!!
That all :)
Speedy Galerie
Top SketchUcator
Postby rafikius » Wed Nov 06, 2019 9:55 pm
pilou wrote:Select your single or multiple result Visuhole Object(s)
Kill the original
My Lord..! :o
How did you come up to such scheme :-D ?
Have you been spending months playing with various methods :-)
Going to give a try to this "direct method" :D
Respectful hat tips
rafikius
Postby pilou » Thu Nov 07, 2019 12:47 pm
In fact that is because my original had a centered volume included face!
And the Tig Plug take only "extnernal surface" !
else it's not exactly perfect because the internal volume is not dupplicated! :( :)
I must dig that! :)
Speedy Galerie
Top SketchUcator
Postby pilou » Thu Nov 07, 2019 2:02 pm
Ok you have an easy solution but you must have a Pro version or better Booltools 2 ;)
Booltool2 works without the Pro Version of SU ! (it's not free but it's a very cool tool! :thumb: )
Make your Visuhole object module
(video begins here)
Move it out in the space from your global original Object
Scale it in One direction from Center (+ CTL) (not good works if you have just aligned objects faces)
Group it
Group your Principal object
You can now make any Boolean operations after any copy, move module ...
If you want make multiple Boolean objects group them before as follow!
White box is Object 1
Group of 3 groups is Object 2 for only one Diff Bolean Operation
(use second icon of Booltools2 )
Click on image for animation
Speedy Galerie
Top SketchUcator
Postby pilou » Thu Nov 07, 2019 3:12 pm
Else you have this cool opener by Didier Bur for simple multiple drills not intersected with existing holes !
(don't works on Group or component)
Select "only surface(s)" not the edges ! Menu Extension "Hole"
Speedy Galerie
Top SketchUcator
Return to Newbie Forum
Users browsing this forum: No registered users and 5 guests
