how to draw coil fin heater
The ideal place for beginners to get help using SketchUp
Postby l_yap » Thu Oct 24, 2019 6:00 pm
May I know how to draw this coil fin??
l_yap
Re: how to draw coil fin heater
Postby TIG » Thu Oct 24, 2019 6:13 pm
You can't attach a link back to your own computer.
I suggest that you attach an image directly...
User avatar
Global Moderator
Postby Box » Thu Oct 24, 2019 6:20 pm
Basic answer will be, draw the profile and use follow me, then array if needed.
User avatar
Postby Dave R » Fri Oct 25, 2019 3:13 am
What version of SketchUp are you really using? You put 2018 Make in your profile but that doesn't exist. Knowing which version you are using will make it easier for us to give you good direction. One thing is for sure, if you model the fins on that with geometry, it's going to slow your computer down. It would probably be better to use a texture.
How will you use this thing once you have it modeled, anyway?
User avatar
Global Moderator
Postby l_yap » Fri Oct 25, 2019 4:41 am
Thanks for your reply. Actually I'm using an online version from this website.
https://app.sketchup.com/app?hl=en
I'm new at SketchUp, may I know what's mean geometry and texture?
l_yap
Postby Dave R » Fri Oct 25, 2019 1:37 pm
Geometry is edges and faces. Textures are images that you apply to surfaces. Since you are using the free online version you will be limited as far as what you can do. No extensions so you would have to model it manually. I would suggest not worrying about modeling the fins and just make a smooth tube using Follow Me. Then apply a gray color or a metal texture to it. For your hobby application that should get the job done.
Here's a quick example drawn in SketchUp Free.
A path for Follow Me
Add a circle at the end.
Run Follow Me.
Extend the ends with smaller diameter circles and add a metal texture.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
cron
Who is online
Users browsing this forum: No registered users and 5 guests
Visit our sponsors:
