solar panels not dropping at desired tilt
The ideal place for beginners to get help using SketchUp
Postby ppelletier » Thu Oct 24, 2019 5:31 pm
Hello. I am new to the forum and look forward to learning from my time here. I usually have been able to work through problems I encounter with my models but this one has me stumped.
I am dropping solar modules on a 3D mesh with the tilt of 31 degrees. This is not a flat surface but a slope. After dropping, the panels end up vertical on my 3D model. It does not matter if I select tilt or relative tilt when placing the modules nor does it matter if I select "drop coplaner to the surface" or "drop without rotation". I have tried different modules, changing the camera perspective, deleting and replacing the modules to no avail.
I have been able to perform this function on other models but for some reason not on this particular model.
Thank you for any guidance you can give me.
ppelletier
Return to Newbie Forum
Users browsing this forum: anfedora and 4 guests
