Is there a tool or plugin that works like the 3ds Max Gizmo?
The ideal place for beginners to get help using SketchUp
Postby themistergato » Sat May 18, 2019 1:55 pm
I am transitioning from 3DS Max, and I find that moving objects is hit or miss, and can snap to near by objects too often. Is there a tool or plug in similar to the Gizmo that is in 3ds Max? Even Maya has one.
themistergato
Re: Is there a tool or plugin that works like the 3ds Max Gi
Postby Box » Sat May 18, 2019 2:55 pm
I'm going to guess you are trying to drag things into place. Don't.
Find an appropriate place on your object (the corner of a cube) with the move tool click and release on that point. This will attach the object to your cursor allowing you to zoom, pan, orbit etc until you find the point you which to place the object, then click and release to place it.
If you are having other difficulties it is better to explain your problem rather than ask about a tool in a program that others may not be familar with.
Postby Pixero » Sat May 18, 2019 5:41 pm
Thomthoms Vertex tools has a gizmo like 3ds max.
Pixero
Postby pbacot » Sat May 18, 2019 6:25 pm
You can lock into an axis or inference direction with the shift key. The axes directions can also be locked in with the arrow keys as well. I'm not sure how the gizmo is more helpful. I use ThomThoms vertex tools gizmo and it's OK for some things but it means you can't get the snaps (as far as I can tell). If you just try moving a little before you get a constrained direction it will tend to just snap where you don't want.Sometimes you have to move too far or the opposite direction first to find the axis direction. But no there isn't a native gizmo for SketchUp. Try some of the tutorials on the move tool.
Top SketchUcator
Return to Newbie Forum
Users browsing this forum: Manh Tien, Qazwsx1234321 and 3 guests
