How to make a mould
The ideal place for beginners to get help using SketchUp
How to make a mould
Postby ReneG » Mon Dec 24, 2018 11:18 pm
I'm a beginner.
I have created a cinder block (cement block) in Sketchup Make, the free web version, and now I need to create a mould.
Boy, it's not a straight forward thing!
Can anyone point to me where I could find how to create a mould? I created a plane and used the Push/Pull tool but it creates an empty box - it's not solid.
thanks.
ReneG
Re: How to make a mould
Postby pbacot » Tue Dec 25, 2018 12:33 am
If I understand correctly. It can easily be done.Make a block (the mould material) larger than the concrete block. Place the concrete block with the top side (the side that will be the open side of the mould) on a face of the mould block. Remove the face covering where the concrete will be and make sure the there are faces on top of the parts that will create center voids. Orient faces so all "FRONT FACES" are facing outward (contextual menu "orient faces"). Please see attached with the mould in transparent material (which I hope makes it clearer--the pink is all surfaces that will contain the concrete).
(If you are using a typical template your front faces are probably white and the back faces are blue. My front faces here are the pale yellowish color.)
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: No registered users and 8 guests
Visit our sponsors:
