Hello!
Is it possible to use 2 different points to snap a component into place? I have my first point in the correct spot and it snaps my component in the correct spot. Then I would like that point to stay where it is and then select another point and rotate the component (about the first point) to snap the second point to place. I do know this can be accomplished with placing the component and then using the rotate command to snap the component into it's proper place. I am trying to avoid using the rotate command and hopefully just placing components using 1 command and 2 snap points. Is this even possible?!?!?!!!
Using 2 separate points to snap a component in place
• Page 1 of 1
Re: Using 2 separate points to snap a component in placeSeems 2 points are not sufficient for place a 3D object in the 3D space following its own 3D axis!...
It's different if you have yet a surface existing! Maybe this can help you ?
Re: Using 2 separate points to snap a component in placeThank you pilou! I would like to explore that plugin. What is the plugin in the video called?
Re: Using 2 separate points to snap a component in placeBefore i find it you have PomPi for make many Pipes!
Re: Using 2 separate points to snap a component in placeThanks. I don't need a pipe plugin. What's in my screenshot I attached to my original post is actually sections of a tube slide. They are all modeled per the manufacturer.
Re: Using 2 separate points to snap a component in placeI'd just set the component up with gluing properties and appropriate insertion point but I'm guessing you've already explored and rejected that.
(THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: Using 2 separate points to snap a component in placeThis ChrisP_PutsCompOnFace destroys Profile Builder 2 and 3 (they don't generate geometry anymore). Wasted time to figure it out. Don't download!
• Page 1 of 1
