Problem with BezierSpline Curves on Macbook Pro
The ideal place for beginners to get help using SketchUp
Postby spdbl » Tue Sep 18, 2018 3:07 pm
Problem with BezierSpline Curves.mov
I installed Frodo's BezierSpline Curves and find some of them work and some don't. A short movie outlining the problem is attached. I tried switching styles, but the same thing happens no matter which style I use.
I'm on a 2011 Macbook Pro running Sierra 10.12.6, using Sketchup Make 2017.
Thanks in advance for any suggestions.
spdbl
Re: Problem with BezierSpline Curves on Macbook Pro
Postby fredo6 » Wed Sep 19, 2018 12:20 pm
Clear. Could you please open the Ruby Console while trying Polyline Arc Corner or Uniform B-Spline.
Normally, for these tow curves, you are prompted for a parameter, and obviously the dialog box does not show up.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby spdbl » Wed Sep 19, 2018 5:03 pm
Fredo
Thanks for your reply, Fredo. My apologies for calling you Frodo - too much Tolkien.
I tried again with the Ruby console open, and a short video is attached. I am heading for the country, and will be offline for a few days, but will check out the forum when I get back.
Thanks again,
Jim
text from ruby dialogue below:
true
Error: #<NameError: uninitialized constant BZ__BSplineU::Traductor>
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/BZ__BSplineU.rb:73:in `bz_ask_extras'
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in `call'
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in `call_ask_extras'
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:508:in `activate'
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2063:in `select_tool'
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2063:in `menu_creation_tool'
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2452:in `block (2 levels) in load_all_menus'
SketchUp:1:in `call'
Error: #<NoMethodError: undefined method `>' for nil:NilClass>
/Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/BZ__BSplineU.rb:112:in `curve'
spdbl
Postby fredo6 » Thu Sep 20, 2018 6:07 am
@spbdl,
Oop! For got one file in the packaging.
Maybe, the best is that you install LibFredo6.
Otherwise, just wait for me to publish an update to BezierSpline
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby spdbl » Mon Oct 01, 2018 4:54 am
fredo6 wrote:@spbdl,
Fredo
Hello again,
I installed the library and everything is working as it should. thanks again. I was using it to draw out the parts to laminate the curved mouldings for this sauna project, and it came in very handy.
spdbl
Postby jpreischel » Fri Nov 30, 2018 5:21 am
YES! Thank you!
jpreischel
Return to Newbie Forum
Users browsing this forum: No registered users and 5 guests
