FPS is too small
Hay, i have problem with graphics. I use a laptop for modeling in SketchUp. Laptop have two graphics cards and SketchUp used integrated. when running on NVIDIA graphics card fps is too small, does not it is possible to move the camera. I think it should be higher fps on nvidia but on integrated is higher. The integrated graphics card when placing trees or similar, fps drops sharply and it is impossible to continue to draw. Other specifications:
MSI ge62
i7-6700HQ
16 Gb DDR4
NVIDIA GTX 960m
Thank you for help -
Try updating the nVidia drivers and see if that helps.
Thank you, now works perfectly.
