Dave R wrote:What do you get when you set out guidelines at 3m from both the red and green axes? Try that and then run the floor tool using the guidelines as the reference instead of typing the dimensions.
Measure the distance between joists. Are they all the same? The last space should be narrower by the width of the joist.
Also, it would be useful if you upload the SKP file so we can see it.
Hi Dave, thank you for your reply!
I have created guidelines in blue and red axes.
Eventhough the axes are exact 3.0m the joists are total length of 3,03m
The first two joists are from endpoint to endpoint 0,35m the rest are 0,30m. Last joists are about 0,28m
This seems odd to me, why'd you even have to create a guideline?
Is there any way to change the numbers of lumbers in the plugin? It says 50x50, yet they're 45x45 and so on..
I'll add soem attachments
Thanks in advance
