Point Clouds to SketchUp
The ideal place for beginners to get help using SketchUp
Postby JaseBarr » Sun Feb 02, 2014 10:26 pm
I have a Faro FOCUS 3D. I am an experienced laser scanner, but I'm pretty new to modelling as most of my visualisations to date have been cloud based.
I would like to directly import cloud data into SketchUp to assist my modelling. Bentley Pointools used to have a plugin that would allow you to do this:
http://www.youtube.com/playlist?list=PL33B7560FDA0D1CF9
I've been made aware that this plugin was discontinued last year.
Does anyone else have a solution for importing cloud data into SketchUp from Faro SCENE or Bentley Pointools?
I can export cloud data as DXF, VRML, IGES, XYZ text, POD, E57.
Help is greatly appreciated
JaseBarr
Re: Point Clouds to SketchUp
Postby mitcorb » Mon Feb 03, 2014 1:59 am
Hi, Jase:
Investigate this: viewtopic.php?p=253563#p253563
By Didier Bur, Sketchucation Plugin Store and at Ruby Library Depot.
This seems to have some relation to your question.
mitcorb
Top SketchUcator
Postby JaseBarr » Mon Feb 03, 2014 2:35 am
Thanks for your quick reply Tim - this looks very interesting.
The instructions for the Plugin look very comprehensive and I will be trying it out as soon as I get chance.
I look forward to seeing how it deals with massive clouds...
Thanks again
JaseBarr
Postby framed » Sun Mar 30, 2014 11:55 pm
Did it Jase?
framed
Postby JaseBarr » Mon Mar 31, 2014 8:16 pm
framed wrote:Did it Jase?
No. No it did not. It is meant for much smaller cloud sizes. I'm still experimenting with subsampling of data.
It's a shame. With Trimble being a FARO re-seller, you think they would see the benefit of bringing pointcloud data into sketchup to asist modelling and make a decent plugin for it...
JaseBarr
Postby Jim » Mon Mar 31, 2014 9:19 pm
Your best bet would be the ascii xyz format. It is fairly easy to plot points in SketchUp read from a file. Is that all there is to it, or is there more to your request?
Jim
Global Moderator
Postby AndrewS » Fri Apr 18, 2014 9:22 am
Andrew S.
SketchUp Release Engineer
AndrewS
SketchUp Team
SketchUp Team
Postby kaas » Fri Apr 18, 2014 10:12 am
...No. No it did not. It is meant for much smaller cloud sizes. I'm still experimenting with subsampling of data.
I had the same experience with a large data set with Didier's plugin this week.
I ended up doing this to get the terrain into Sketchup:
1) import 350Mb laz terrain data into CloudCompare
2) crop dataset to desired area in CloudCompare
3) export area as asc data (about 1 Gb)
4) tried importing with Didier's plugin. No crash but just no result after a while.
5) import asc in MeshLab and convert points to mesh(used some steps found on internet: 5a-5e)
5a) Open Layer view (next to little img symbol)
5b) SUBSAMPLING: Filters > Sampling > Poisson-disk Sampling: Enter Number of Samples as the resulting vertex number / number of points.
5c) COMPUTE NORMALS: Filters > Normals/Curvatures and Orientation > compute Normals for Point Set [neighbours = 20]
5d) TRIANGULATION : Filters > Point set , Marching cubes.
5e) SAVE MESH save as obj file
6) import obj into Sketchup using Tig's obj importer
Due to the large dataset several steps take quite some time. To speed up the workflow, crop the area as small as possible in step 2.
Because the original laser data was on a 0,5m cloud interval ,in sketchup I sliced the terrain to get some isolines and used Fredo's Toposhaper afterwards to try some settings to get the to the desired resolution of the grid.
Tips to reduce the number of steps are very welcome!
kaas
Postby jdagen » Fri Apr 18, 2014 1:18 pm
Kaas,
Excellent work! Is there any way you could supply more detail on your process with Mesh Lab of converting points to mesh? I have been experimenting with downloading point clouds from Earth Explorer. I did try the Trimble extension. Unfortunately it only loads Trimble's file format, I am assuming, from scans from their equipment. The Global Mapper program allows you to crop your model, and it allows you to separate topo points from vegetation and building points. But I do not think it allows you to create a mesh. It costs around $500.
jdagen
Postby mitcorb » Fri Apr 18, 2014 1:32 pm
@AndrewS:
Thanks for posting that announcement and link. Good, clear video :thumb:
mitcorb
Top SketchUcator
Postby kaas » Fri Apr 18, 2014 2:05 pm
jdagen wrote:Kaas,
Hello Jdagen, sure. Steps 5a-5e are in MeshLab. Which step would you like more information on?
I did see a video of Trimble's extension and I would like to try it in real but I'm afraid such a laser scanner is above my budget. Will use my Stanley TLM100i in the mean time :roll:
kaas
Postby jdagen » Mon Apr 21, 2014 9:30 pm
Kaas,
My apologies, your explanation is fine. I can follow it and will give it a try. Thanks again!
jdagen
Postby Miner_Jeff » Sat May 09, 2015 3:29 am
Hi Folks,
I went through a similar process recently. Had a LiDAR point cloud with over 33M points. Ended up using CloudCompare's dxf output to decimate the data to evenly spaced horizontal contours. It's a recent feature addition. Subsequently used Jim's [Plugin] FreeDXF Importer http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=22199%26amp;start=15
to get the dxf file into Sketchup. Each contour is created with an individual layer which is kinda messy in Sketchup, with some elbow grease the contours can be reallocated to layers by elevation.
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=20633%26amp;start=15
Worth a look for anyone trying to work LiDAR data.
Creating and coloring numerous layers is easily handled by TIG's [Plugin] TIG-LayersFromList
http://sketchucation.com/forums/viewtopic.php?p=566286#p566286
Cheers,
Miner_Jeff
Miner_Jeff
Postby dchar » Sat Feb 18, 2017 6:42 pm
dchar
Postby MariusP » Tue Jun 11, 2019 2:02 pm
https://extensions.sketchup.com/en/cont ... t4sketchup
Use any scan data directly in SketchUp :knockout:
MariusP
Return to Newbie Forum
Users browsing this forum: No registered users and 4 guests
