ROUND CORNER LIBFREDO
The ideal place for beginners to get help using SketchUp
Postby skytrooper » Sat Apr 13, 2013 9:23 am
:sketchstatic: Hi y"all. Will someone tell where I can find the Round Corner LibFredo so I can install it to my sketchup. I have windows 7 and I am on a laptop also please tell me how to install it Thank you.
skytrooper
skytrooper
Re: ROUND CORNER LIBFREDO
Postby massimo » Sat Apr 13, 2013 9:36 am
viewtopic.php?p=171721#p171721
You need to install also this one:
viewtopic.php?p=144178#p144178
Unzip the folders and put the content in SU's plugins folder. Read the Fredo's posts and be sure to observe the footprints.
Or, easier, use this fantastic new tool:
viewtopic.php?p=467479#p467479
massimo
Postby skytrooper » Sat Apr 13, 2013 11:22 am
Friend. I still can not find the ROUND CORNER LIBFREDO plugin.I downloaded the two you sent but its only a manual and a banner
skytrooper
Postby massimo » Sat Apr 13, 2013 11:29 am
There is no "ROUND CORNER LIBFREDO plugin" as you say. There is a "round corner" plugin and a "libfredo" which is nedeed to use that plugin. So you have to download and install both.
Anyway try with the last link I posted. It's a lot easier.
massimo
Postby skytrooper » Sat Apr 13, 2013 10:31 pm
Hi massimo. I just tryed to install the LibFredo to su and got this message SketchUpn was unable to install the Extension you have chosen for unknown reason
Consult your Extension's documentation for additional help
I dont have a Extension's documentation or I dont understand what they mean will you help me
Thank you
skytrooper
skytrooper
Re: ROUND CORNER ; LIB FREDO
Postby skytrooper » Thu Apr 18, 2013 7:04 pm
Hi y'all. I hope everyone is doing well today. I need help could someone help me here is what is going on. I just tryed to install the Lib Fredo to Sketch-Up and got this message Sketch-Up was unable to install the Extension you have chosen for unknown reason
I don't have a Extension's documentation or I don't understand what they mean will you help me
Thank you
skytrooper
skytrooper
Postby Dave R » Thu Apr 18, 2013 7:22 pm
I bet you still haven't gone back to the thread where you got Libfredo6 and read it. This has been covered repeatedly.
Set all of the permissions for you in the Plugins folder to Allow. then try reopening SketchUp.
Inspecting mirrors is a job I could easily see myself doing.
If you are the smartest person in the room, you are in the wrong room.
Global Moderator
Postby skytrooper » Sat Apr 20, 2013 5:00 am
Hi Dave R. I can not find the thread you are talking about can you help me please. The Round Corner and LibFredo6 was sent to me so I don't know where the thread is.
Thank you
skytrooper91
skytrooper91@yahoo.com
skytrooper
Postby pbacot » Sat Apr 20, 2013 5:26 am
Just so you know, here's what you do. There is a "Plugins" menu item under "Resources" at the top of this page. Choose that and it takes you to a page that lists many plugins. Use the "find" function on your browser to search that page. Type in "round" and it will eventually show the link you want (third result).
viewtopic.php?t=20485#p171721
MacOSX (El Capitan) ShetchUp Pro v16 Layout Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby skytrooper » Sat Apr 20, 2013 7:35 am
pbacot. I have found under Fredo a long list of plugins but how do I download them or put them in a zip folder so I can download them .Can you tell me how to set properties permission . I am on a laptop with windows 7 home pre
Thank you
skytrooper91
skytrooper
Postby TIG » Sat Apr 20, 2013 10:24 am
Billy
You seem to be misunderstanding how plugins work - downloading, extracting, installing and then using them...
First of all - permissions.
To be able to add files to your Sketchup Plugins folder you need to have its security-permissions set to 'FULL'.
By default Windows limits it to read-only [i.e. no 'write'] because the folder is inside the 'Program Files' folder.
To fix this select the Plugins folder icon, right-click > context-menu > Properties > Security > Edit...
Give everyone listed FULL permission.
OK to apply/save changes.
You will need admin-rights to be able to do this...
So now you can add things to the Plugins folder.
Plugins come in several forms - single .rb/.rbs files and for more complex files archives containing typically a.rb loader file and a subfolder of 'helper' files helper files - these are ZIP/RBZ archives. When extracted they need to go into the Plugins folder in the same relationship as they have in the archive - i.e. all files must stay inside their subfolder [if any] when added to the Plugins folder.
Some tools require you to have also downloaded and installed a folder of 'helper' files - usually called a 'Lib'[rary] - Fredo and Thomthom do this the most. A few other tools also need a helper, obtained from an external url - like 'progressbar.rb' from Smustard.com... These 'dependencies' are clearly explained in each tool's page.
Now for the good news... SketchUcation have recently launched a 'Plugins Store' that includes most of the Plugins that are available on the forum - to use it within SketchUp [v8M2] you'll need to download and install it from an RBZ archive - but that is clearly explained on its page... Once installed the tool allows you to search through hundreds of available Plugins, by keyword/category/author, it includes descriptions/links-off the more info... etc AND best of all it has an Auto-Install button... So provided that you have sorted out your Plugins folder's permissions to FULL, it will download/install/load the chosen Plugin[s] for you... See this page viewtopic.php?p=467479#p467479
Global Moderator
Postby pbacot » Sat Apr 20, 2013 4:14 pm
skytrooper,
The link I posted is the place you need to go to. You read the first post and download from there (it is always the latest version). The post may have additional plugins that are required or may have links where to download those. TIG has explained the rest above.
Peter
Top SketchUcator
Postby skytrooper » Sat Apr 20, 2013 9:53 pm
Hi pbacot . Tell me something LibFredo6 mention putting the plugins in the Sketch-Up plugin folder is this something that come with SketchUp8 or do I make a new folder and place the plugins in it. When I downloaded the Sketych-up 8 I didn't get a Sketch-Up folder.
Thankz you
skytrooper91
skytrooper
Postby Dave R » Sat Apr 20, 2013 10:07 pm
Billy,
There's is a Plugins folder under Google/Google SketchUp 8 (the SketchUp folder) which you must also have if you have SketchUp installed and running.
It sounds like you need someone to help you out with this personally to get this straightened out. If you want that, send me a PM.
Global Moderator
Postby skytrooper » Sun Apr 21, 2013 1:17 am
Hi. Can someone tell me how to fix this error
There is no program associated to perform the requested action . Please install a program or, if one is already installed, create an association in the Default Program control panel . I type in the window that open up when you click on the start button this google/google sketch-up 8. and I still can not find a sketch-up plugin folder and I have a thing call a B1 free Archive and I try to extract plugin to put in a folder that I made I get can not creat a target file how can I fix this and how do I pm you
skytrooper
skytrooper
Postby TIG » Sun Apr 21, 2013 10:16 am
There is a PM icon below each poster's avatar/details.
If you do not understand the most basic functions of your PC then we have an uphill struggle :?
Do you understand how to use 'Windows Explorer' to open a window, which will show you the contents of the folder ?
Then if you double-click on a subfolder's icon, then that opens and so on until you have opened the folder you want... Double-clicking a file icon opens the file in it's designated application if any.
You are looking for:
C:\Program Files\Google\Google SketchUp 8\Plugins
The folder will exists if you have let SketchUp install itself in the default manner - if you did a custom-install its folder could be anywhere, but the Plugins folder will still be automatically created in that folder-tree.
The 'Programs Files' folder name might be named slightly differently [+ (x86)] if you have a 64bit OS...
You do not 'run' anything :roll:
Global Moderator
Postby skytrooper » Mon Apr 22, 2013 2:51 am
Hi TIG. I reckon I have the c:\program files (x86)\google\google sketchup 8\plugins the reason I think so is that the B1 free Archiver reads at the top c:\program files(x86)\google\google sketchup 8\plugins. I didn't know that I had this. and would you know what is causing this error . I just tryed to install the LibFredo6 to SketchUp and got this message SketchUp was unable to install the Extension you have chosen for unknown reason
Thank you
skytrooper
8-)
skytrooper
Postby TIG » Mon Apr 22, 2013 10:49 am
SO you can find your Plugins folder :D
Next... that error-message suggests you have insufficient security-permissions to add files to your Plugins folder. :(
By default Windows limits security-permissions to folders within the 'Program Files' folder to be 'read-only'.
You need to have 'FULL' [read/write] security-permissions to the Plugins folder to be able to add files into it.
So... to fix the folder's settings you need 'admin-rights' - it's a good idea to give yourself admin-rights in the Users Control Panel...
Now highlight the Plugins folder's icon: right-click > context-menu > Properties > Security > Edit.
Give everyone listed FULL rights.
OK to apply and save changes...
From now on you should be able to install plugins manually... OR by using the much easier v8 'installer' features available when plugins come packaged in RBZ archive format... :)
In passing... can I suggest you also 'fix' the permissions for the SketchUp Components, Materials and Styles subfolders, because from time to time you will want to add files into those too... :?
Global Moderator
Postby popfunky » Sat Sep 21, 2013 8:21 am
NEED PLUGIN NOW.IT TIME
popfunky
Postby cotty » Sat Sep 21, 2013 9:21 am
popfunky wrote:NEED PLUGIN NOW.IT TIME
cotty
Top SketchUcator
Postby Tombstone » Mon Nov 18, 2013 11:52 am
Hi guys.
Will it work for SketchUp 2013 ? Or is there a similar plugin in extension warehouse?
Thanx
Tombstone
Postby Dave R » Mon Nov 18, 2013 12:50 pm
Yes. It works in SU2013. Why would you think otherwise?
Global Moderator
Postby beatweber » Sat Feb 01, 2014 1:18 am
Dave R wrote:Yes. It works in SU2013. Why would you think otherwise?
Hi.
I get the Message 'Module RoundCorner requires Sketchup version greater than 5.0.160. Current Version is 13.0.4812'
What to do about?
Beat
beatweber
Postby Box » Sat Feb 01, 2014 11:32 am
That is the error message you get when trying to install an old version of the plugin. Where did you get it!
Go to the PluginStore at the top of the page and install the latest version from there. Also install the latest version of Libfredo. Better still, install the pluginstore tool itself and auto install the plugins you want from within sketchup.
Return to Newbie Forum
Users browsing this forum: rogwhi and 5 guests
